AndyL Posted April 2, 2008 Share Posted April 2, 2008 My entry - No idea if I'll get it finished...the insignia, serials, etc are moulded onto the kit, so the whole bloody thing will have to be rubbed down. My bet is Jen will have hers built before I have even started sticking mine together! Oh well... Regards Andy Link to comment Share on other sites More sharing options...
dswoofie Posted April 2, 2008 Share Posted April 2, 2008 Another Bulldog... they're popular suddenly now... there was me saying that you don't see that many... Welcome on board Andy! Sounds a bit of a pain having the markings moulded on the kit, does it have any decals? Karl. Link to comment Share on other sites More sharing options...
AndyL Posted April 2, 2008 Author Share Posted April 2, 2008 (edited) Karl, The decal sheet looks pretty good, and gives two options for a 17 and 19 Squadron machine - J9587 and K2159. Dunno which one to go with yet. Andy Edited April 2, 2008 by AndyL Link to comment Share on other sites More sharing options...
AndyL Posted April 2, 2008 Author Share Posted April 2, 2008 And see what I was on about regarding the moulded on markings...going to have fun removing them! Link to comment Share on other sites More sharing options...
dylan the rabbit Posted April 2, 2008 Share Posted April 2, 2008 Oh dear. Maybe it should be called the Smeg Bristol Bulldog. Makes the Airfix kit appear like the best kit on the planet! Good luck there fella. Link to comment Share on other sites More sharing options...
dswoofie Posted April 2, 2008 Share Posted April 2, 2008 Removing those markings carefully look like as much fun as hearding cats! Definitely good luck for this one! Karl. Link to comment Share on other sites More sharing options...
AndyL Posted April 2, 2008 Author Share Posted April 2, 2008 Dylan - You hit the nail on the head there...Smeg it is, but I'm going to have a crack at trying to get it looking like a Bristol Bulldog. Karl - the markings have come off the fuselage halves a treat, and the underwing ones too. The upper wing ones are a pig to remove. I might get them down to an acceptable level then put a few coats of Halfords primer over it to see whats showing through. Then I'm off to try to herd a few cats, just for the experience! Link to comment Share on other sites More sharing options...
dswoofie Posted April 2, 2008 Share Posted April 2, 2008 Then I'm off to try to herd a few cats, just for the experience! I've got three if you want to try... it's not fun, they are worse than children at times! Karl. Link to comment Share on other sites More sharing options...
AndyL Posted April 2, 2008 Author Share Posted April 2, 2008 Right, after much sanding, I've got the fuselage, underside, and most of the top wing surface cleared of the moulded on markings. The upper wing was a pig to sort, and after attacking it with sanding sticks, I sprayed a light coat of primer over it to show up the imperfections. Now it's more or less sorted... Link to comment Share on other sites More sharing options...
dswoofie Posted April 2, 2008 Share Posted April 2, 2008 Nice one! It seems to have come up OK doesn't it! Sanding seems like all I've done today with my Lightning... sanding, more CA filling, more sanding, repeat, repeat!!! Karl. Link to comment Share on other sites More sharing options...
AndyL Posted April 2, 2008 Author Share Posted April 2, 2008 Karl, All that sanding has driven me potty today, however I managed to finish my 1/48 Airfix Spitfire I just to give me a bit of variation. Next step will be trying to make a functional looking cockpit in the Bulldog. However, I might just go for a pint instead! Link to comment Share on other sites More sharing options...
AndyL Posted April 9, 2008 Author Share Posted April 9, 2008 (edited) Just a quick update - progress has been hampered due to the loss of the compressor, so I'm going to have to wing it with rattle cans and paint by hand...ooh err... Done a bit of dry fitting, and seems ok, but still more sanding to do. We'll see how this one pans out! Edited April 9, 2008 by AndyL Link to comment Share on other sites More sharing options...
perry Posted April 9, 2008 Share Posted April 9, 2008 This looks to be going very nicely Andy! Link to comment Share on other sites More sharing options...
AndyL Posted April 10, 2008 Author Share Posted April 10, 2008 Cheers Pez! I decided to attempt to add the distinctive exhaust pipes that run from the cylinders to the collector ring. I bent plastic rod over a candle and cut to size. The end result looks ok, but will need a bit of fairing in to the collector ring, which I'll do with white putty thinned with a little liquid glue. Link to comment Share on other sites More sharing options...
Erwin Posted April 10, 2008 Share Posted April 10, 2008 Good progress so far. BTW,I like your avatar. I'm also a great fan of the series Navy NCIS. Abby is my favourite. Link to comment Share on other sites More sharing options...
AndyL Posted April 10, 2008 Author Share Posted April 10, 2008 (edited) Cheers Erwin...nowt wrong with our Abby...though the OH would certainly have something to say about that! Just tried to put a few decals on the assemblies - the kit offerings look lovely, but they either refuse to come off the backing sheet, or those that have, have simply fragmented... Looks like a grovel in the wanted section beckons.......... Edited April 10, 2008 by AndyL Link to comment Share on other sites More sharing options...
dahut Posted April 10, 2008 Share Posted April 10, 2008 Abby Rules. Grovel - hah! Link to comment Share on other sites More sharing options...
desmojen Posted April 10, 2008 Share Posted April 10, 2008 That's looking well nice Andy, actually looks quite a nice kit as well. Liking what you've done on the engine a lot Jen. Link to comment Share on other sites More sharing options...
AndyL Posted April 11, 2008 Author Share Posted April 11, 2008 Thanks Jen...I see Hannants have the Smer kit on at a whopping £3.99! In general, it's basic but buildable. Here's a little progress... Link to comment Share on other sites More sharing options...
AndyL Posted April 22, 2008 Author Share Posted April 22, 2008 (edited) Sadly, this just won't get done in time - no decals, no compressor and no darn job. Shame as I was quite enjoying it. Wings are on, but it's just sat there gathering dust. Bah. Edited April 22, 2008 by AndyL Link to comment Share on other sites More sharing options...
Potato Pete Posted April 22, 2008 Share Posted April 22, 2008 Andy, I have the Model Alliance Wings of Silver decals. Ain't gonna use them all, so if you want one of the Bulldog sets, let me know Pete Link to comment Share on other sites More sharing options...
AndyL Posted April 22, 2008 Author Share Posted April 22, 2008 Pete, Thank you for the kind offer, but there's no way I could take those from you, not when I won't be able to complete the kit in time. But I sincerely appreciate it. Kind Regards Andy Link to comment Share on other sites More sharing options...
Osher Posted April 22, 2008 Share Posted April 22, 2008 Looks good so far! The SMER Camel is very similar, also with moulded in markings. I believe both kits are Aurora kits from the 1950's. Link to comment Share on other sites More sharing options...
Red Arrow Jag Posted April 23, 2008 Share Posted April 23, 2008 Bulldog's looking good!! I love their Avro 504...perhaps you should take a look at doing one of them next also? Link to comment Share on other sites More sharing options...
T-Tango Posted April 23, 2008 Share Posted April 23, 2008 Shame you won't get it finished Andy, cos it's starting to look good. Link to comment Share on other sites More sharing options...
