B-2 Spirit - Testors 1/72
Skii
John ,I see that like Arthur Dent and Ford Prefect you can't travel far without your towel !! nice colour scheme and texture ,where did you get it ?, I had a similar one about twenty odd years ago, never went anywhere without it ,( love the weathered and used look of it!!! )
...oh by the way plane looks nice too ..... :whistle:
Sorry John, I still think it's rubbish... I'd get yourself some nice stamps if I were you... philately is supposed to be a nice relaxing hobby that requires no skill whatsoever! ^_^
Just be careful you don't take up Philology by mistake, or you're liable to end up as the lead character in a CS Lewis novel....
Oh, nice model btw :whistle:
Thankyou peeps, actually the masking didn't take THAT long, most of it is cut up into fine strips and small triangles/oblongs which you can do suprisingly quickly when you get into the swing of it .
Melchy, I think the towel is older than me to be honest, well at least it saves the floor from a coat of gunship grey :D
J
Thankyou peeps :)
Now here was a minor set-back. I unmasked the windoews in order to check if the inside glass had stood up to the rough and tumble of all that sanding and scratchbuilding....not very well unfortunately! Small bits of sanding dust and flakes had settled on the inside of the glass, can't really see it in this pic but it needed sorting.
So, with the circular saw on the dremel I cut open the roof.
This allowed me to get an Isopropryl soaked cotton bud inside to clean the glass and restore the glazing to a nice transparency :)
Next I re-sealed the roof wedging some styrene card around the edge and carefully CA'd in place
Finally some very careful sanding and painting
Sorted :)
Nice job John , It's a royal pain when that happens , had the same thing with my Victor , but as the cockpit had all been sealed up I fed a tiny bit of tubing through the porthole into the cockpit and blew very low pressure air into it to remove offending dust . Not always possible but you seem to have saved the day with this one !! Looking very nice...... :analintruder:
Final stage of the repair work on the cockpit roof, hatch markings re-sprayed and tidied up, even i'm quite suprised how clear the cockpit glass is. Time to re-mask and press on with the underside of the aircraft :)
more progress on the belly of the beast :)
Lower surfaces prepped with a coat of lightened gunship grey, undercarriage and bomb bay doors fixed in place and sealed with maskol , and then the whole lot masked in the same old painstaking way
Then a slightly darkened layer of gunship grey with some subtle weathering touches, de masked -
et voila
