Heritage Aviation Mosquito
CLICK... Graham = Lancman - got it ;)
Keep up the good work chap.... Lost track of this topic over time, and I'm glad to see it back. The Mossie is my favorite plane of all :D
Glad to have you here too :welcome:
hi Graham. I must say your doing a bang up job on that. The cockpit is paticulary good, very impressive. And having seen this kit in the flesh at SMW, I can appreciate all the work you have put in to attain such a high standard.
Nigel.
I know from first hand experience how much work it is to scratchbuild the amount of detail you're putting into this bird...but to have to make EVERYTHING from just-about scratch is truely admirable. That cockpit really turned out beautifully. Keep it up and I'll be following your future progress very closely.
Here is my attempt at scribing and making rivets with a drill, the exhausts are from the Revell kit and are drilled out and they don't look to bad as when the shrouds are on they will still be seen.
Graham.
Aah! Was hoping you'd pop up again soon with some more progress :)
You used Revell exhausts? Pardon my ignorance if I've missed summit - is this off the 1:32 mossie? Won't they be too small? :hmmm:
Mike they will be covered by the exhaust shroud and when that's in place you can only see the stubs, it's so I would have some detail in there rather than a hole. ;)
I'm with ya... I suppose it's cheaper than finding a 1:24 scale kit with similar exhausts just for those 4 parts. What's happened to the rest of the Mossie kit? Did you kill it? :(
It does look good, doesn't it? Nice scribing job on those nacelles too.
I can't tell from the pics, but the Revell 1:32 Mossie was criticised for not having the scooped/sculpted/sloping nacelle sides. How're the nacelles on this? :hmmm:
Mike they are flat as per the Revell kit but I think in the instructions it says that the slopes should be formed using Milliput so I am using the Tamiya kit as a guide and I will use Milliput fine (white).
Graham.
More scribing done and the other wing marked out :who-let-rip: Mike those are the mastercaster sponges and they are a god send, Sean this is my first real attempt at a vac, I previously tried a 32nd Lanc but it was just to big but this is the furthest I have gone with one.
Graham.
