Bennygman
Members
  • Posts
    790
  • Joined
  • Last visited
Posts posted by Bennygman
  1. Another Iwata fan checking in!
    I have the Eclipse CS and Sprint Jet Compressor, and am very pleased with both. A good and lightning quick supplier can be found here... http://airbrushes.com/index.php?osCsid=7c5...6eb04ecfdddf348
    About the easy cleaning. I found that with the supplied .35mm tip and needle it became unusable for acrylics after a short space of time, spluttering and eventually clogging completely. As a result I've got into the habit of stripping it after every session (but not every colour). Every time I take out the needle it has some paint on it - can't imagine that'd be good if I let it dry in the body.
    The problem has been solved by switching to a .5mm tip, which works fine, though I do still note paint on the needle, even after spraying cellulose through. I just think that not cleaning it properly is asking for trouble eventually. That said it now takes me about 2 minutes to do so it's no problem really.
    I have no spraybooth, I just use a sheet of cardboard and throw it away every now and then. I work at fairly low pressure so the overspray is very minimal anyway, and I always work by an open window to let the worst of the fumes out. That said, if I was designing a custom work are I'd probably include one. A good investment is a spray mask from Halfords, I have a twin cartridge type which works well and wasn't particularly expensive - it's also great for scaring the cat for some reason!
    Steve.
  2. Not much wrong there mate ... and you've retained more surface detail than I have on the Do-335 I'm building for the ARC GB!
    Picking up on Mike's point about the tanks and missiles, I read once that you should treat them as individual models that are then added to the whole. It's the approach I take, though not always successfully. But as they say; "don't do as I do..."
    Nice result at the end of the day :thumbsup2:
    Steve.
  3. I fear the steep wing overs will be a thing of the past.
    Wouldn't it be great though? That's one of my abiding memories of my first Air Tattoo at Greenham, the other being the noise the Harrier made. How Ironic if the Vulcan returned the year the Harrier disappeared from the circuit.
    A few years back I bought some merchandise form the Vulcan stand and my uncle was telling me how 'it'll never happen'. Don't think my contribution will have made a huge difference, but all credit to the guys involved.
    Steve.
  4. Hey Steve
    I've got a mint s/h 300mm F4 L IS in stock.....might be able to save you a few bob as well!
    Richard@t4cameras.co.uk 01793 523332
    Thanks for the offer Richard...but it arrived at 9am this morning. If only I was less impulsive :banghead: .
    I'll keep you in mind for next time though (and we know that once you start down this road there will always be a next time).
    Steve.
  5. Ooh no Steve... you're a very silly boy, and should have bought a toilet roll with a magnifying glass taped to the end instead
    Tried that, but I couldn't find a magnifying glass with a filter thread!
    Currently trying to work, but in fact hopping around with anticipation...and it isn't even coming 'til tomorrow.
    Steve.
  6. Hi All,
    In preparation for this year's assault on the airshow circuit I've just ordered a Canon 300mm f4L IS Prime lens.
    Reasoning was that although I lose the flexibility of my zooms and may miss some shots as a result, the image quality of this lens is apparently very good, or as one poster put it ..."Quality vs Quantity". Having looked at last years shots, most flying pics were taken at 300mm which was a bit 'soft' on my 70-300 zoom. Hopefully the prime will improve on those at the long end and I still have my trusty Dynax 7D and 70-300mm combo for runway / taxying shots.
    All very exciting - just wanted to share it with a few like-minded souls (if only to prepare me for when the girlfriend finds out :analintruder: . First test will hopefully be at Biggin this weekend ( I say hopefully because of the dubious weather forecast). Anyone else going?
    Steve.
  7. Paul, this may or may not help, but I was having just the problems you describe with my Iwata too.
    My solution has been to get the larger nozzle (.5mm rather than the .35mm it came with) and since then it's worked beautifully even with Acrylics. My Xtracrylics even go on glossy now rather than the matt effect I got before which I assume was due to too high a pressure being required.
    The penny dropped when I read a post on ARC that mentioned that the small nozzle is really designed for artists inks - even thinned paint is much thicker than that. I think the replacement nozlle. needle and cap cost about £26 in total from Airbrushes.com.
    As for cleaning, when I looked through the small nozzle after spraying it was always blocked until I cleaned it out, the larger one can be seen through straight away. I've been using a long thin brush loaded with Cellulose thinner to wash it out then drying with a scrunched up corner of a paper towel. Touch-wood, it's worked without a stutter for about six weeks now, obviously the paint flow is higher and needs getting used to, but being able to work at lower pressures without clogging means that close/detailed work should still be possible. I've got a vietnam camo F-105 coming up which should be the acid-test!
    Steve.
  8. I can recommend the Detolf - got a couple from Ikea a couple of weeks back. Very good quality for £34 each, me and the missus put 'em together in about 25 mins each and they feel like they could withstand a small bomb blast. You can get an extra lighting pack too, but the dopey woman in the store sold us the wrong one which dosn't fit into the hole in the top. Fortunately it comes with a blanking plate 'til we can get the proper one.
    Only thing I'd say is that it'd be nice if there was maybe one more shelf with a smaller gap between them, but the models look great in all that space and light. I'm hoping they'll take a 1/72 Lanc or 1/32 Mustang, but each shelf will comfortably hold 4-5 1/72 prop fighters or 2 1/48 equivalents without being too cramped. One other thing is that they're not dust tight, they have about a 1/2 inch gap at top and bottom (and no, that's not just our assembly work! :D )
    Oh, and they come with [sic] an 'anti-toppling device' (piece of cord with a screw on the end), but they feel pretty stable to me.
    Steve.
  9. Looking really good there Karl - great job mate! :thumbsup2:
    I know what you mean about being scared with your first airbrush job. It's silly really 'cos you can just do it again, but you SO want your first one to be good, fortunately yours is.
    As for mine? Well ... that's enough about me! :)
    Steve.
  10. Jake: cheers mate, sorry we couldn't get the group visit sorted out. I didn't have high hopes for the GR4 shot, but it was such an impressive sight I had to include it.
    Nev: I'd like to say it was due to good planning and a detailed network of contacts - but in truth I was just a right jammy B*****D :lol:
    Geoff; looking at your location I'd say you know your way around CBY? (came through Sleaford on the way up).
    Re the dust spots, a mate has recommended something called (I think) green sensor swabs? Apparently you apply a liquid, let do it's work then take it off with a clean dry swab. This guy is pretty obsessive about his kit, so if he says it's easy I'm inclined to give it a go.
    Steve.
  11. i've a number of Fujimi Scooters........sad they're still not producing kits..........(or are they?)
    NICE touch, Steve :clap2:
    Yep they are (though somewhat intermittently) check out the Hobby link Japan web site for current availability.
    Steve.
  12. Thanks guys.
    I'm not aware of anything happening on those dates Kev', the only scuttlebutt I picked up was that the Spanish are back for a proper exchange visit in June and that there is a similar exchange planned for possibly 2008 with the Italians, but not sure if they're coming here or the RAF's going to Italy. Judging from what I saw and the locals describing it as 'a bit quiet' I'd say that if you avoid Friday's you'd get a fairly decent show. Pays to take a book though as there were some fairly lengthy gaps between the action. Fortunately there were a few people to chat to yesterday.
    My next planned trip is to Lakenheath on June 22 to hopefully see some Spangdahlem A-10's.
    Dean, I noticed that, but only after I'd posted it. Most of these were taken with my girlfriend's Dynax 7D which only has the odd spot. The 20D is almost out of action until I can get some sensor swabs.
    Steve.
  13. Well, as the RAF kept playing silly buggers with the Jag retirement dates and upsetting our plans for a meet-up I took myself off up there yesterday to see what was what. To say I had a good day would be an understatement.
    Weather wasn't the best, but at least it didn't rain at all at the base. On arrival around 08:30 I was directed to the 25 end and sure enough the caravan was there and the lights burning indicating I'd come to the right place. Quite a few people around waiting for the Spaniards but I managed to park in the layby by the traffic lights (in the middle of a huge puddle - glad I bought hiking boots!).
    I set up shop at the fence in the farmer's field and waited...and waited...we got some based movements, then at about 11 the Spaniards taxied out...
    Some more base gear then the Lossie Tornados went out to play, arriving back in impressive style...
    After lunch 41 sqn got into the act with some Tornado action...
    rrrrrrrRRRRRUMBLE!!!
    This has to be experienced, when the afterburners kick in you can feel you internal organs rattling :analintruder:
    A few more base Tiffie movements, then the highlight of my day, three Jags making their way out of the HAS complex...
    3 ship departure...
    Now, I don't consider myself no nancy boy...but I had a lump in my throat thinking they were off to the knacker's yard...but I was wrong. The fly out had been scrubbed due to the weather at Cosford and these three came back later in the day. By then the light was a bit pants though so I won't bore you with the arrivals. Must say the 6 sqn guys were quite friendly, returning waves and such.
    What a day. Thanks to Dean (J35 Draken) for recommending the field, I didn't get to point R after all - the field seemed to be fulfilling mt needs quite nicely. The ground was a bit soft for a ladder with my weight on it so these were mostly shot through the chain-link fence in the interests of safety :)
    Hope I've not killed anyones dial up connection, as this is a longish post I've not posted any based tiffies, but there are a few if anyone wants to see them.
    Steve.
  14. Nice pics Kyrre - I especially like the Texan/Harvard and the abstract shot of the Swedish Roundel.
    Sometimes close-ups are the way to go, there's a wealth of textures and details to be found on parked aircraft (especially if the weather is against you).
    You made the best of a bad day.
    Steve.
  15. Nice :thumbsup2:
    How does it go together? I've been meaning to get one of these as a kind of 'where it all began' type thing. I like the figures in classic pose, will you be replicating the photo as a diorama?
    Completely unprompted by me, my girlfriend took this pic' at Old Warden last year which I think echoes the Wright's first flight quite nicely...
    Steve.
  16. :( Hi Troffa, have just checked the stash, and find that I must have built all the Fujimi RAF Phantoms, and I only have the F4C/D 'Vampire', F4S 'Black Bunny', and RF4B 'Spectre', I also found that I have a Fujimi OA 4M 'Outlaws' Skyhawk. :rolleyes:
    Robin.
    I have a 'vampire' box in front of me now Robin - unfortunately full of spare stores rather than kit :weep: . I nearly bagged a couple of those as they were also re-issued recently but I was suffering from 'spending guilt' at the time and passed on them.
    Steve.
