Bennygman
Members
  • Posts
    790
  • Joined
  • Last visited
Posts posted by Bennygman
  1. Well, if we're posting up Matchboxes...
    All from the ARC Matchbox Madness GB 2006 (another coming next year), apart from the Seafox which was part of the 'Splash' GB hosted by our very own Doc Fester in happier times.
    Steve.
    PS Neil, that is a wonderful job on what is often considered a right bugger of a kit.
  2. Thanks mate, I thought that was a hot day but then you mention 35 degrees and I think "oh, ok then".
    A funny thing is paint, it seems there'll always be some exceptions to any rule (eg I've had dire warnings about Alclad on unprimed surfaces, but for me it's been fine). The guys you mention all know their stuff, but sometimes it just doesn't work out for someone else.
    If I was in your position I'd;
    1. get a very cold drink.
    2. prime it and leave it at least overnight.
    3. give it a light rub down if silver is going over the top (shows everything)
    4. Spray from the same distance but in cooler air.
    I'd give you a link to the ARC thread, but my work firewall doesn't let me go there (another advantage of Britmodeller), it was in the Matchbox GB and my build of the P-47. From memory he went into a fair bit of detail about spraying in hot conditions.
    Good luck,
    Steve.
  3. I know it's an obvious and probably unhelpful comment, but have you sprayed this paint onto an unprimed surface succesfully before? I tend to prime before using car paints, but then again I've also used Alclad (which is nasty stuff) directly onto plastic with no ill effects. Is it actually attacking the plastic or just drying badly on the surface? If the latter then is it the air temperature? If so then try spraying from closer in, but if it's attacking the plastic then that will apply a heavier coat and probably make things worse.
    The only other suggestion I can offer is to repeat what Aussie Thommo from ARC told me about rattle cans, which is to remember to "shake the crapper out of it first, Mate"
    Steve.
  4. Think the worst I've come across was some sheets for girlies on the upper nose of a few F-105s with a strategically placed in-flight refueling probe receptacle. Guess it gave the boom operators something to concentrate on.
    Said machine is also included on a new sheet from Zotz decals - review in SAM this month.
    Steve.
    PS must post those cycling pics I promised you - one of em's an absolute killer!.
  5. It would be good if we got all of the available kits built. I'll volunteer for the Matchbox T2 in 'Ripple' and their original single seater with the 'pointy missiles' if I can find one.
    Steve.
    PS I agree about Antics and the cheap Jags - added advantage is that it'll probably be with you the day after you place the order!
  6. Wow, thanks for all the feedback guys ! Glad to bring you a taste of the day.
    Dean; the Spit's my favorite too - just relieved to get a pic' that did some justice to his display.
    Gundy: Could be, I was about thirty feet back from the fence and had the hind starting up directly in front of me.
    GCN: PM coming.
    Nev; Yeah, just a little bit ;) what with Waddo Saturday and RIAT Sunday, I think I sort of earned some sunshine this time around.
    Thanks for looking,
    Steve.
  7. Took the girlfriend and a picnic down to old Warden for the day. Once we'd recovered from the shock of £20 each to get in it was quite a good afternoon.
    First of all the German connection...
    And some welcome visitors...
    Peter Teischmann (sp?) gave his Spitfire a right old seeing to! The first time he dived in for a low fast pass I thought "what a great way to end the display", by the third or fourth time I was completely lost for words - absolutely fantastic.
    An inspired formation ...
    And finally a few from the home team...
    As has been said elsewhere, few things beat Old Warden in the sunshine, especially now they've increased the size of the viewing 'lawn' by parking the cars further back - really good idea that and congrats to whoever thought of it. Oh, and the draught bitter went down very well on a hot day!
    Steve.
  8. with the blutac in position you are suposed to spray along one side of it from a vertical position keeping the brush very close to the blutac, you defeat the object opening the needle, make several steady passes until the colour builds up.
    Well, I never thought of that!
    I've always masked the original colour with tape in between the Blu tack, but the method you describe would make the process less of a hassle as long as i could control the line width. I could have gone on for ages without realising that - thanks Ted.
    Steve.
  9. Hi Derek, I was wondering the same thing a while back. I'm not sure what the RLM 01 looks like when applied, but if you don't mind enamels then Xtracolour has a newish High Speed Silver in their range. That's the route I took in the end.
    There are a few other acrylic silvers around (eg Tamiya) that might fit the bill if you're planning to spray, and if you're brush painting then Games workshop do a few different shades in their Citadel paints range which behave well with a paintbrush. The Tamiya aerosols are also a pretty reliable way to get an all-over silver finish without too much trouble but it's a more expensive way of doing it.
    Steve.
  10. It seems to me that washes and drybrushing is a much more effective technique.
    For me the three techniques are complimentary and the combined effect can be quite interesting. Leaving aside the 'authenticity' issue, I think they all contribute to breaking up large expanses of single colour on a model.
    Just a personal view, but I think solid blocks of colour on a model (eg all over olive drab or grey) can sometimes make it look a bit boring to my eyes and the variations in tone make it more interesting by giving the eye more to work with, if not always being a 100% accurate reproduction of the real thing. I guess it's the old reproducing reality vs. creating a pleasing effect thing again?
    The best technique for the individual is the one that gives them the result they enjoy looking at, no?
    Steve.
  11. As above I fill the thing with Blu-tack or similar for strength then use a strip of masking tape along the join between the part and the stub as a sort of guide line for cutting with a scalpel. Trick seems to be lots of gentle passes rather than one agressive one.
    Note, I've only done this twice, but with reasonable success.
    Steve.
  12. Generally use airbrushed Xtracrylics with their own thinners, but I've also had good results from Games workshop's Aerosol Satin ('Purity seal' in GW speak). Regettably the last time I checked their web site it didn't seen to be available any more.
    Steve.
  13. I still don't get this 'problem' with the decals. Mine is printed very nicely, the only dots I can see are the roundel centres!
    peebeep
    When I first looked at mine in the bright Duxford sun I thought the matrix was quite pronounced, but they were certainly still fully usable. Looking again just now in electric light I can make it out on the sky and grey from about 6 inches away, but probably only because I'm actually looking for it. I must say I was beginning to think I was going mad, but it's interesting to see that Brett has picked up on it too.
    They certainly still look very usable, and I intend to do so...for both schemes.
    Steve.
  14. Speaking as someone who dropped a huge wad on two of these buggers this is a bit interesting :wacko: to say the least. Actually, because of concerns over the stability of resin I've been storing mine in the spare room which is the most temperature stable in the entire house, rather than in the loft which is like a freezer in Winter and a furnace in summer.
    Not sure what else I could be doing?
    Steve.
    PS just checked the older of my examples (me worried - Pah!)- doesn't appear to be showing any banana - like tendencies as yet!
