Selwyn
Gold Member
  • Posts
    3,934
  • Joined
  • Last visited
Posts posted by Selwyn
  1. 22 hours ago, Julien said:
    Oh dear!
    The guy who did the first review on hyperscale thinks because the original design was done by Sikorsky that it was originally a Russian helicopter!
    Don't think this guy is the man to be doing reviews somehow.................
    Selwyn
    • Haha 4
  2. 1 hour ago, elger said:
    Hello all,
    Does anyone have any information regarding the dimensions of aircraft launched mines used for "gardening" operations in late 1941? (Which types would have been used around that time most commonly?)
    Elger
    RAF Mines dropped from bombers were approximately 9 feet long by 17 inches in diameter (including a wood or metal fairing). Weighing in at around 1,500 pounds (680 kg), each mine held 750 pounds (340 kg) of amatol or minol explosive. As mines were often dropped close to one another, a device was attached that prevented mines being detonated by one exploding nearby.
    http://www.rcaf434squadron.com/gardening/
    Selwyn
  3. 2 hours ago, billyharry2000 said:
    Hi There
    Wonder if someone could please help is there a aftermarket replacement for part No,s E10,E11 the gunpack out of the Airfix Lightning Fmk6.The reason I ask is I have lost my kit parts have been moving my model room to loft .. Kind Regards Craig
    The F6 did not have a gunpack, the only aircraft marks that had gunpacks were the F1, F2, F2A.
    The F6 had two guns mounted in the front portion of the ventral fuel tank.It was not a separate gun pack.
    Selwyn
  4. 3 minutes ago, JOCKNEY said:
    Well as co-host my finger being withdrawn is long overdue.
    20221013_170833
    Here's all the bits
    20221013_170931
    20221013_171034
    As its from 1986, can I apologise for bringing something so outrageously modern to the GB on this occasion.
    I promise to return to my normal habitat of the 1960's and 70's kits at the next opportunity
    Cheers Pat
    I assume you mean the issue you have is from 1986, The kit was originally issued in 1970!
    Selwyn
  5. 12 hours ago, Mike said:
    We've reviewed a couple here:
    I like the 3D printed ones best, as they're easier to crumple, and look a bit like the material used for the real ones.  In answer to your earlier question, both types are printed on both sides.  The 3D ones are printed have printed text on the "decal" side, which is logical really, but quite a shock when you first see them :shocked:
    The ones with "Remove before Flight" on them are American and not generally used on UK Jets. You will see them on the safety devices of American weapons such as sidewinders in UK service but never on pylons. If the original US RBF flag is damaged it will be usually replaced with a British red/white RBF flag.
    Selwyn
  6. 33 minutes ago, Harry Lime said:
    George,
    Going at this from another angle, the NF13 was a tropicalised version of the NF11 and was flown by 39 Sqn and 219 Sqn from Kabrit in Egypt's Suez Canal Zone from March 1953. 219 Sqn disbanded at Kabrit in September 1954 but 39 moved to Luqa in January 1955. Having checked all the other squadrons listed by Jefford as operating the Meteor NF11, none were based in Malta.
    Mark.
    IIRC 39 did operate at times a few NF11 to supplement the 13's when there was a shortage of NF13 airframes.
    Selwyn
  7. 10 hours ago, exdraken said:
    Is it the same as on the Jaguar nose actually?  The GR5-9 Harrier  did have it as well, no? Or was that only a camera?
    The LRMTS on Jaguar was the same equipment as fitted in the Harrier GR3 dolphin nose.  Not sure about the one fitted in the Tornado.
    Selwyn
    • Thanks 3
  8. 5 hours ago, John Laidlaw said:
    That's the Laser Range Finder and Marked Target Seeker for laser-guided munitions.
    Its actually nothing to do with laser guided munitions, Its designed to provide a laser range for delivering unguided weapons and and also gives a visual cue in the HUD as to the location of a marked target  which is indicated  by a ground based troops using a laser marker, again to deliver unguided munitions.  A  LGB uses a different laser system that actually guides the bomb after release. This can be a aircraft laser designator or ground based.
    Selwyn
    • Thanks 3
  9. On 9/20/2022 at 9:42 AM, Mr T said:
    I have a couple of Matchbox Meteor Night Fighter kits in the stash, and the C Scale TT20 conversion, and fancied building a TT20 and NF14(T), as a way of using them up.
    What I want to know is what model paint (preferably acrylic) matches the yellow TT stripes found on Fleet Air Arm TT20s. I have seen it named as Saturn Yellow, but that has really not got me anywhere.
    I am sure it has been discussed here before, but I can't find anything.
    Thanks in advance, Martin
    The correct colour is BS381c 355 Lemon yellow.
    Selwyn
  10. On 8/12/2022 at 10:09 PM, Corsairfoxfouruncle said:
    True but if you have a 1:1 scale build I think we can definitely make an exception for it. Though do you think you can get it done in 90 days we might need an extension.
    Needs a lot of work on the paint job as well!
    Selwyn
  11. 4 hours ago, Andrew D Jolly Rogers guy said:
    Are there any aftermarket gun barrels that would work for a 1/72 Mirage F.1?  Found the Quickboost ones for the Mirage III but they're 1/48.  Have also found the Staghound metal ones but not sure they're correct for my build.  Maybe I could cheat with A-4 guns?
    You are looking at something tiny, 30mm calibre works out to 0.41mm in 1/72 so you are looking at  less than 1mm external diameter of the barrel in 1/72. I would go for  a hypodermic needle as well but even that is probably oversize!
    Selwyn
