John R
Gold Member
  • Posts
    1,631
  • Joined
  • Last visited
Posts posted by John R
  1. Lovely job Melchie. Do you do anything else but build models? Your output puts mine to shame!
    As to the SST, I actually stood under the full size model when I worked for Boeing in mid-sixties and my thoughts were along the lines of 'I DON'T BELIEVE IT'.
    This was also the time when someone decided to test the American public's reaction to supersonic bangs by subjecting Seattle to quite a few of them. They were not well accepted and probably contributed to the demise of the SST. If you were outside they were acceptable but inside a big building like Boeing's assembly hall or an apartment block the place shook.
    John
  2. I built one of these a few years ago.
    The panel lines are a bit deep and I had a little trouble with one of the intakes where the lip had to be built up a little but otherwise it went together quite well.
    Be careful with the decals as they are rather thin. I also reckon that they are not quite the right size but it depends on how picky you are.
    Enjoy - it makes a nice model
    John
  3. Progress - but slow and now I need more help - please
    I was about to add the 'USAF' decals supplied with the kit but realised that they used a different font so it looks as if they will have to be home made.
    Does anybody know what colour was used - black or dark blue (Insignia blue)? The same goes for the colours of all the other markings.
    Also the top of the fin appears to be a lighter colour. Was it a different shade of metal or was it some kind of resin like they used on radomes?
    John
  4. You might be better off starting with a Sea Hawk for the fuselage. The Hunter was a much slimmer a/c.
    There was a post some time ago from a chap in Australia who assembled a P1081 from various bits.
    I've got a P1052 and P1081 in 1/72 scale currently stalled until I can find out how the u/c doors and legs are arranged. If you are at all picky this is the most difficult area to sort out
    Good luck!
    John
  5. North American YF-100 Super Sabre prototype
    I had hoped to have this finished by now but somehow life got in the way!
    It started life as a partially built ESCI F100D left at the club last month
    Modifications include :
    Re-profiled fin with a strange, and so far unidentified, thing on top
    Removal of the inner wing extensions and flap lines and re-scribing ailerons
    Removal of what looked like strengthening plates under the wing
    Addition of the upper nose probe.
    Reduction of the wingspan
    The extreme rear end is also significantly different to production types and requires fabrication of a new exhaust ring.
    The worst moment came quite late on when the forward undercarriage bay became loose and fell inside the fuselage. Fortunately the fuselage was sufficiently empty to enable it to be extracted via the hole for the afterburner ring. After cleaning up it was possible to re-insert via the gear bay hole but holding it in place whilst re-glueing provided some considerable amusement!
    One interesting item is that this kit, by ESCI, is supposed to be one of the most accurate but the intake shape is wrong. It appears to be a perfect ellipse whereas the actual shape is not. I do not feel up to trying to correct it.
    I am wondering what paint to use for the upper surface panels of the wing which are not polished metal. Any advice would be appreciated.
    I wondered if the YF-100 logo appeared on both sides of the nose but all the photos I have seen show it on only the right side. Some photos show FW 754 on the left but a poor quality first flight photo appears to show neither.
    Ah, the joys of research!
    John Rieley
  6. I intend to use Alclad Polished Aluminium over Alclad Black Base for the shiny bits.
    I did wonder what would happen if I used a grey primer over the black on the 'anodised' section and then used the polished aluminium over the lot.
    John
  7. Which paint should I use to represent the greyish bit that looks like anodised aluminium on the the topside of the wing?
    At Scalemodel World a couple of years ago the Alclad stand had just this combination of shiny and grey and I wonder how they did it.
    John
  8. Don't know if this quite on topic but I thought that it might raise a few nostalgic smiles.
    Looking for something to occupy a 5 year grandson I wondered if he might like to make a model.
    Yes please! So I dug out an Eastern Express Hunter from the stash, bought and saved for just such an eventuality.
    I managed to keep the knife away from him as we got the parts to fit. He wielded the glue brush and after brief wait for the glue to dry, on went the decals as he didn't want to paint it.
    Start to finish in a couple of hours - Remember those days?
    Have I just started another youngster on the road to ruin?
    John
  9. Well Tim, thishas long been an interest of mine.
    The B.2 prototype was used for tests for a few years, including evaluation of the tanker system, then incrementally destroyed in the humiliating role of "ballistic target" for ground gunnery.
    Melchie
    I was always under the impression that it was lost due to an in-flight fire whilst it was fairly new, Mutt Summers having to bail out.
    Correction/enlightenment please.
    John
  10. Any advice? My main problem is that the subject is always slightly blurred, no matter how fast the shutter speed (1/1000 to 1/1250) and how steadily I track the aircraft's movement with the camera. I'm amazed that someone suggested to you to slow your shutter speed - how would you get sharp pictures then?
    Jeffrey
    You might condider getting a stabilised lens. Canon call it IS (inertial stabiliser), nikon call it VR (vibration reduction)
    John
