Neddy
Gold Member
  • Posts
    674
  • Joined
  • Last visited
Posts posted by Neddy
  1. That's precisely the situation I was in earlier this year when I joined the forum.  I graduated from 1/24 scale due to age-related eyesight issues and now stick mainly to 1/16 scale (with the odd - and I mean ODD - exception!).  I've also just acquired a VERY basic airbrush and spraybooth setup which I'm currently getting to grips with, so I can imagine where you're coming from.
  2. I've started spraying the 'shell, getting used to the new spraybooth, airbrush, thinners and paints all at once which is quite a steep learning curve!  Having prepped and primed it I started on the main colours, only to discover that (a) white primer over white filler means undiscovered blemishes, and (b) whilst the two colours chosen (Mr Hobby Aqueous metallic blue and metallic green) went on well and the blend worked as well as could be expected, the colours are so similar it's a bit of a waste of time!
    Oh well, you live and learn (as the Dalek said, climbing off the trashcan).  I now need to deal with the aforementoned blemishes, re-prime and re-spray in a single colour.
    I must say in passing how good Mr Hobby Aqueous acrylic paints are, best I've found yet.
  3. Ooh, this one's going to be interesting in many areas.  Before you get too far into the build, have you compared the wheelbase of the two-door and the four-door?  I looked into doing precisely this with an Audi A3 and discovered they were totally different 2-door to 4-door which really bit me in the bum.  If this is the case with your model Golf there's all sorts of additional fun, like shortening the bodyshell, interior module and chassis.  😆
    I hope for your sake they're the same dimensions!  🤞
  4. Hi Matthew, welcome on board!  I remember 23, I was there once - mind you, I have a VERY long memory... 🧓
    Although mainly a car builder now I built many ships and aircraft back when i were a lad - Canberra, Bismarck, a B17G and a Lanc being the high spots.  Looking forward to seeing your builds.
  5. Quick interim update:  bodyshell primed and would have had a few coats of paint on it by now if not for a slight annoyance...
    I bought two Revell Aqua metallic colours with the intention of producing a fade-in effect from one to t'other but when I opened them I discovered nothing but crusty-looking moonrock-like substances inside.  They're going back to the shop tomorrow as they must be extremely old stock.  I'm going to try Mr Hobby Aqueous acrylics this time.  More when I can get the paints replaced.
    • Sad 1
  6. I've already enough to see me through the greater part of next year.  First finish the Santa Pod Rod (now on the home straight but lots to do on the bodyshell), then the 1/16 scale AMT' 64.5 Mustang coupe that's currently paused at the spraypaint stage.  After those will come the 1/16 scale BMW Isetta and finally the 1/16 scale Bandai Lamborghini Marzal I was lucky enough to land a month or two ago.  Re-learning to airbrush will also occupy quite a bit of time!
  7. Blimey!  Words are inadequate, either in English or Polish, to express the sheer quality of this build.  Every last detail beautifully executed, totally realistic and amazing looking model.
    It makes me want to give up modelling and take up knitting...  :blush:
  8. Swift progress report:-
    Slowly but steadily I'm getting there.  The engine bay, front springs and firewall are now in place,  Smart air cleaner fitted but that god-awful chrome fan just had to go!
    At the other end, rear suspension now complete with anti-tramp bars fitted.  I've scratched an endplate for the shortened fuel tank from 0.5mm Plasticard.
    ...you can see it a little clearer in the next photo which also shows the bodyshell work creeping closer to the next milestone which will be primer.
    Thanks again for your interest and patience!
    • Like 11
