Posts posted by spike7451
I have a mate who works for MBDA,I can ask him if you like...
Great work by the way,your MACE lugs should be a golden color & not silver tho.
Dry fit the wings & glove boxes,then cover the insides surface with plastic card,cut the notch for the wings to shape.Assemble the model,then cover the outer face in filler,finish it with a wet finger & scored detail onto it...
It's just the standard centerline pylon,these were'nt fitted before Granby in 1990 & they're not fitted to the GR1A/GR4A as they sort of interfear with the camera blister....It's just the camera perspective that makes it look shorter...
- 2
Steff,
Don't forget those yellow pipes connect to the pipes on the seatheadbox..
PS,you going to Blackpool in Sept?
Right, I just found some more pictures I should have put on
Starting with the seats...As can be seen on page 1, the back cushion was rectangular, where on the real one it has a half circle (ish) cut out, to allow for the pad to go around the neck and over the shoulder, no over, not off the shoulder!!!
So I started with removing as much of the resin pad as I could...
Then I cut out a piece of Wine Foil (Cheers Fritag) thats about the right size
Then make some indents to give me an idea where I'm cutting
Then, taking a steel ruler, a pin vice and a sewing needle I echted out, very gently, the piece I wanted to remove
Then stuck the Eduard seat straps to the back of it...
Stuck the straps to the seat head box and then the rest to the seat itself...
Then some Mr S (500)
Then give it a paint...And pop it in the Office to see what it looks like....First though a pic of the open office, notice blue arm restraints in place, a couple of strands of cotton, then the white (Dirty...Bloody grubby handed growbags) leg restraints (not in yet) draped over the sticks, front and rear...
So that brings me upto date...
Thanks for looking in, comments, ideas are most welcome...
- 1
I'm about to start this kit as a GR4 Dambusters conversion.
I'm not 100% sure, but is the rear chamfer on the BOZ pod the wrong way around i.e. the chamfer should face away from the fuselage?
Cheers.
And finally BOZ and ECM Pods...
Nothing major carried out, just slowly slowly at the moment, will update as soon as I done more to this
Thanks for looking
Zone19
It is facing the wrong way,but I think that's because Revell must've used a GAF Tornado as an example &,as I've just found out,they have a Boz for each outer pylon...The kit one's also too rounded,should be more pointy...
- 2
Inner pylons are from the kit and the Paveways are from a company online called L'arsenal..
My mate Scoobs say's it's a cracking job!
L'arsenal make cracking stuff,I have a couple of their TERMA pods for Tornado & they're excellent!
- 1
Hope you don't mind me posting one of the pics to my FB page,a good friend of mine is a SNCO TM on 6sqn.Brilliant work as always!
Fixed that for you......................
That's because they were banging off us Stroked Beagles at Al Kharj.
- 3
Come on Spike...Update
Sorry,been a busy month,my 47th at the start,running around trying to sort out the Mod & my pension,Hospital check ups (Leukemia's still in remission ) rehoming a couple dogs & cats for a couple animal rescues I'm involved with on FB & my last uncle passed away last week,so my mojo's sort of stalled as I'm exhausted!
Doing a quick build of a Academy 1/72 SR-71 to try & get it back!
- 1
Flare carts BOZ Pod on the Tornado are white.
I suspect purely for display purposes as Gary says above.
You suspect wrong,,,,
http://www.aviation-picture-hangar.co.uk/xp696.html
Backs up what my mate said above,who was a SNEC Armourer on Lightnings before he went to the dark side (Commissioned)
- 1
I've asked on our RAF Armourer's FB page as the's a few old Lightning crusties there who should know...
Got a lot us us stumped...But the view from the Frightning experts is it.s not a real or drill missile,but a mock up missile which was locally made, or it's a Red top experimental development Blue dolpin or blue jay. Semi active homing radar.. would explain the nose and longitudinal sensors on the side.
Sniper is a combined targeting & reconnaissance pod.
http://en.wikipedia.org/wiki/Sniper_Advanced_Targeting_Pod
DJRP is another type of reconnaissance pod
https://www.thalesgroup.com/en/united-kingdom/defence/digital-joint-reconnaissance-pod-djrp
TERMA is a active Countermeasures pod that supliments the BOZ Pod on Tornado GR4's
There's not so much a raised line, but a band of raised rivets.............
http://data.primeportal.net/hangar/luc_colin2/tornado_gr4/Tornado%20GR.4%20Maple%20Flag%20010.JPG
Beat me to it mate,it's riveted sections...
It's one of the directional vents for turning the leaping heap when it's hovering,the's identical vents in the tail boom & wingtips
Spike
From the comparison of the Kit parts and the resin there look to be some size differences. The tanks in particular see rather short, are they supposed to be the same size/capacity? Whose resin parts are they?
Looks to be some challenging fit issues as well.
The IP is looking sweet though. I'm looking forward to seeing more
Thanks Calum,
I measured them in my build thead,the resin ones are by Dave Parkins update set & are 1/5mm wider than the kit tanks,so I think someone at Revell made a booboo there with the measurements.
Using a micrometer,the diameter on the Revell drop tank is 10mm while it is 110mm long & the diameter of the Flightpath tank is 11.5mm & 132mm long.
HTH
Spike
I've just assembled my fuselage and the area around the intakes that you have problems with is fine on mine
Scott C
I must have a short mold then..as everything else lines up perfectly.....bugger!
Good god this looks like a tough Cookie!!
It's complicated,maybe a tad too over complicated,especially for modelers without much experience.The spring actuators on the flaps are going to be a nightmare!
Like others have said,some of mine have been broken off in transit & even picking up a sprue can break them off.I'd have liked them to have not attatched to the main sprue but to a sort of guard sprue,like Italeria did to protect the lightning dispersers on their F-16 kits.
Lots of dry fitting is needed before you finally glue down,I think on my next one I'll dry fit then run modelers super glue along the seams.for me,the nightmare bit's going to be the main canopy,with all the add-ons....Next thing to do today is tackle the wings,fin & seats....
AND be careful handling the sprue's that have the wings on,I broke off a couple of the flap springs just by lifting up the sprue!
nice! thanks for showing!
one question on the tanks:
are they supposed to be the big 2250l tanks? they look short but the same diameter....
strange!
Just noticed that as well!
No I gather they're the smaller versions & not the Big Jug 2250's.
Ah good man, I wondered when the first WIP would be along, just need to finish my harriers for the GB then I'll crack on with mine!
That's some gap by the intake!
On both sides mate!..Can't move it or the undercart doors won't line up! Also I wouldn't bother drilling out the holes for the IFR probe,if you look at them,where they are,they are quite prominent inside the pit.I'd also block off the back of the APU exhaust as well.the full intake trunking & faces are a waste of time as you can see bugger all down them!
ps,my Harriers on hold till I get the cockpit set...
It looks good so far. How are you going to do the LMRTS window?
Sean
Rob one off an old kit...AND be careful with the flap springs,I've just snapped 2 off jut by picking up the bloody sprue!!!
- 1
Looking for Storm Shadow logo
in Aircraft Modern
Sent Bilvers a request & your photo so he can see what it's going on.
Merv
