Farmer matt
Gold Member
  • Posts
    332
  • Joined
  • Last visited
Posts posted by Farmer matt
  1. Not really my thing, but heading south on the A23 this morning, an uninterrupted close convoy of (at least) 10 Audi TTs. There were a few stragglers too, but the run of them all together looked quite impressive.
    Then, taking up most of the local BP, a tidy but faded 1955 Cadillac 2-door in white with black roof. A (classic) mini pulled in as they were leaving, it would have been interesting to have had them at adjacent pumps.
    Matt
  2. @John_W it does have this...
    52345998945_116765251d_c.jpgc30.18 by Matt Farmer, on Flickr
    @Malc2 The low parts count is largely responsible. It is the construction part of a build that interests me so I tend to crack on. Detailing and painting I find frustrating, and usually serve to stuff up a good build. Being on here has motivated me to make more effort and stops me just sidelining a build thats going awry. The ASK would have been consigned to the shelf of doom at several points in the latter stages for example. The Jodel (not forgotten but a bit stalled) would probably still just be a vague idea if I wasn't sharing.
    I will probably now try and get more if they turn up, and the financial director allows. That was certainly never my intention previously.
    With a bit of luck the postman will be bringing something very special quite soon!
    Anyway enough rambling.
    After some cleaning up, some more filler on the port side, some more cleaning up, and a few smears applied before the pics, we have
    52345569061_5fee7f1480_c.jpgc30.16 by Matt Farmer, on Flickr
    52344611507_9865e012d4_c.jpgc30.17 by Matt Farmer, on Flickr
    Once those last smears of filler are cleaned up that hopefully will have cracked it. I will get some primer on then to make sure as I don't want to be cleaning up around struts and things.
    Matt
  3. @ianwau This is just Humbrol model filler, I find it works just as well on the metal as anything else. It looks dramatic here, but thats why its masked so I can be a bit heavy handed with the application.
    There are not so much gaps as mismatch steps.
    @TEXANTOMCAT, you are not really missing much with the decals, assuming you were doing G-ACUU you only get the reg and some stripes. EDIT the civil scheme is G-ACWR
    Cleaning up showed a bit more of a step on the port side than I would have liked but nothing too dramatic. Will have another look at it later.
    Matt
  4. Time to join the fuselage halves properly. A bit of adjusting showed that filler would still be needed in most areas so I just aimed for straight and level and taped her up.
    52343081235_a7b37a5f2a_c.jpgc30.12 by Matt Farmer, on Flickr
    As you can see, the tail in particular will need some work
    52342896518_879f277844_c.jpgc30.13 by Matt Farmer, on Flickr
    An odd feature, presumably for aerodynamic reasons, is that the port stabilisor is set higher than the starboard.
    52342957134_94d9e1bf9a_c.jpgc30.14 by Matt Farmer, on Flickr
    And so on with a large quantity of filler. I find that masking tape is helpful to control the first heavy application, otherwise you just get filler everywhere and lots of unnecessary tidying.
    52343086900_886f5e91e5_c.jpgc30.15 by Matt Farmer, on Flickr
    Hopefully it will clean up ok, we will find out later.
    Matt
  5. Giving the battered one a new lease of life is the way I would go, the Dinkys do have far more charm. I spent many years re-finishing various diecasts as a sideline, and I was always a bit loathe to interfere with anything that was in really good nick.
    I do like these personal connection projects, they give a bit more emotion to the model.
    Matt
  6. Attaching the undercarriage is something of a juggling act. You need to hook the casting over the front of the lower fuselage which is easier said than done and most probably how the part became damaged. Any fettling to the location and test fitting means hooking and unhooking again. Great fun.
    52340803880_5417ffb37e_c.jpgc30.10 by Matt Farmer, on Flickr
    As an added bonus, you cannot properly align the u/c without the upper fuselage in place, but you cannot attach the upper fuselage until the u/c is located.
    So the solution was to position the u/c and then strap the upper fuselage down over it whilst it set.
    52340676089_2e08e98b3b_c.jpgc30.11 by Matt Farmer, on Flickr
    There will be a bit of filling needed to tidy up around the locations once the fuselage halves are properly joined, which is the next task.
    Matt.
  7. Inevitably I could not resist fidgeting with the Cierva, so first task to remove the rear seat to leave room for Johnny pilot.
    The hole in the front of his plinth is for the rotor control to fit in from above.
    52337194557_f838e3413e_z.jpgc30.7 by Matt Farmer, on Flickr
    Then front seat in to lower fuselage, Johnny into upper
    52337196152_f1165e1b80_c.jpgc30.8 by Matt Farmer, on Flickr
    Not much will be seen once the pieces are joined
    52338457039_7d90ae08d8_c.jpgc30.9 by Matt Farmer, on Flickr
    But the u/c needs to be attached before that happens.
    Matt
  8. Oddly rare considering its a modern Ford, a  tatty Mk1 Scorpio saloon in I would say dark grey rather than black, on an L- prefix. Not special? It was a Cosworth 24v. Driver looked old enough to have had it new on his retirement, well done to him if so!
    Matt
  9. Closer inspection tempered my enthusiasm slightly, as it transpired that the u/c is not only potentially irretreivably twisted, but snapped at the starboard axle.
    52330985196_88aaa7afd6_c.jpgc30.6 by Matt Farmer, on Flickr
    I suspect this would have happened during a test fit, as you have to hook this piece over the nose in a particular way to locate it.
    Of note is that this is an early issue of the kit, and the u/c casting was changed to zinc later. Also, the wheels are cast in place for this release but were seperate on the later issue.
    I decided that discretion was the better part of valor and will leave the pylon joined together, and clean up the glue residue.
    Removing the seats revealed whatever adhesive was used to be pretty tough stuff.
    @KayFranz, the decals are not exactly comprehensive, did you mean lacking in things like werknumber or potentially inaccurate? As a civil scheme pre-1936 would have had stripes on the starboard tail - not provided-, but post '36 a swastika both sides would be correct.
    I would also suggest that the G-ACUU decals should be silver, that has been discussed elsewhere on here, but that airframe carried many schemes it seems. EDIT don't know why I made this reference, the civil scheme is G-ACWR.
    I do not intend using any of the kit decals anyway, I will probably do a later civil scheme.
    Matt
  10. The triangle patterned car looks to be based upon the January 1925 Vogue cover illustration featuring the 'simultaneous' fashion design style of Sonia Delaunay.
    Not sure if that one was just a picture, but there was a real car with rectangles rather than triangles.
    Matt
  11.
    Hello and Welcome to another LDM white metal build.
    I know I haven't finished the Jodel yet, but look what the postman just brought, thankfully whilst Mrs F was out doing Mrs F things.
    52328087962_218370411c_c.jpgc30.1 by Matt Farmer, on Flickr
    52328089582_41ec62607c_c.jpgc30.2 by Matt Farmer, on Flickr
    52329473175_a403062a2b_c.jpgc30.3 by Matt Farmer, on Flickr
    52329474740_015b05ec98_c.jpgc30.4 by Matt Farmer, on Flickr
    52329476410_5aeab75a43_c.jpgc30.5 by Matt Farmer, on Flickr
    Correctly described as 'complete but started', luckily they didn't get too far with it. There is enough glue on the pylon to hold the entire kit together, the wires attached to the rotor hub need trimming, and the seats are at an interesting angle. Beyond that, happy days.
    An early boxing with the German markings, and also two very poor pilot figures (well, head and shoulders) of which the less said the better.
    Probably won't start it just yet, but looking forward to it.
    Matt.
  12. I was briefly puzzled just now by an immaculate pale blue -K suffix VW Beetle passing by in silence without the customary chug of such things. Explained by the window vinyl proclaiming itself to be 'fully electric'.
    By coincidence last night I passed in traffic what appeared to be a resto-mod VW camper, also sans chug, but what first caught my eye was that it was on a modern 65-plate.The 'spare wheel cover' mounted on the front seemed perforated like a cooling grille so perhaps fully modern underpinnings, or that was electric too. It was full size, not one of those silly K-car replicas which I think are Daihutsu based.
    Matt
    • Sad 1
  13. The Bebe has a very basic undercarriage, but I am struggling to create anything that looks OK, let alone might take her weight. This is the current attempt.
    52327538525_62cc9f2dea_z.jpgbb27 by Matt Farmer, on Flickr
    Those wheels are from a 1:72 Fw190 in case you were wondering.
    So to distract myself from this, along with the other major task of trying to create a prop and spinner - never tried that before, not a clue what I'm doing - I turned my attention to a colourscheme. My initial choice was of an airframe registered G-AZBL, as BL was my dad's initials so it seemed appropriate.
    The first pics I saw showed it in a dismantled state in red and white with black letters, but then I found an earlier shot of her in blue and silver which looks much smarter. To which end we have this...
    52327540415_86db9cc605_c.jpgbb28 by Matt Farmer, on Flickr
    Ford Moondust Silver , which at least shows the Chilton would have looked OK after all. Fuselage will be blue in due course.
    Matt
  14. Parked up on the A217 just beyond my usual turn, a W123 Mercedes 280 saloon on an -S suffix. It was very nice and all that, but the reason I noticed it and had to drive past for a closer look, it was orange. Wouldnt really have been my choice.
    Also yesterday looking completely ridiculous, an absolutely spotless new Defender 90 in retro pale green and cream, with a full snorkel kit and extras in equally spotless matt black.
    I know their money, their car, but....
    Matt
  15. Short drive back from the afternoon dog walk yielded an immaculate blue/cream Austin Healey 3000 on a -B , a wire wheel and chrome bumper MGB in cream on an -M , and a very clean looking G-prefix Toyota Corolla, which I suspect is probably the rarest!
    Matt
  16. Pulling away in a cloud of fumes from the local BP, a G-prefix Reliant Rialto in faded light blue. Best summed up by my passing neighbour as ' what the hell kind of an excuse for a car was that? ' . Presumabely they were spared them in his native SA.
    Matt
    • Haha 3
  17. Now baby's chin is done, and a look at her belly for a change. The gap at the tail is to hopefully enable a robust tailskid, although it probably should be a wheel.
    52311000803_b27eaa0641_c.jpgbb21 by Matt Farmer, on Flickr
    52312908015_6ea69aa0d0_c.jpgbb22 by Matt Farmer, on Flickr
    So with the nose pretty much done, I now really must get some primer on her to see what the real state of play is, but first just to show the engine bits roughly in place.
    52312467626_a9cab5eb7d_c.jpgbb23 by Matt Farmer, on Flickr
    Assuming the primer doesnt throw up anything too nasty, all I need now is the prop, undercarriage, a seat for Johnny pilot, and a windshield. And a paint job, scheme as yet undecided.
    Matt
  18. Well used maroon Triumph Dolomite on an N- plate outside Halfords this lunchtime. I don' t know which variety it was, but it had black c pillars and rear light/ reg surround if that narrows it down. Just said Dolomite on the back, no numbers or letters.
    Oh, and (presumably the owners) initials on the door in gold, which is both really sad and now quite quaint.
  19. And so to baby's nose.
    First some bearers
    52303794450_651db94f30_c.jpgbb17 by Matt Farmer, on Flickr
    Then the side walls
    52303793305_21c3569e71_c.jpgbb18 by Matt Farmer, on Flickr
    The bright idea then was to make two engine pieces, joined by a stretcher across - partly so they actually protude from rather than attach to the sides, and partly so that way they should actually be aligned. This worked brilliantly, so well I forgot to photograph it. However, there was an obvious flaw to that plan. The top piece would have to fit perfectly with no cleaning up, and it was soon clear that was not likely to happen.
    After a couple of failed efforts the decision was made to build in situ. A random piece of furniture trim proved a saviour, sealed with resin.
    52308436200_aaee689073_c.jpgbb19 by Matt Farmer, on Flickr
    And after some packing and filler and sanding, we get
    52308432605_c10e5b853c_c.jpgbb20 by Matt Farmer, on Flickr
    I also added a shim to the lower edge pieces to reduce their angle a bit, as it was too steep.
    Plenty more to be done, but she is starting to look aeroplane shaped now.
    Matt.
    • Like 9
