Neil
Members
  • Posts
    929
  • Joined
  • Days Won
    1
Posts posted by Neil
  1. Hi Neil,
    The picture you show of the "fence" embedded in the wing tip was infact part of a guard rail from a weapons range watch tower !!
    Whilst I was on Jags in Oman, the story I heard was the pilots wife was at the range watching hubby drop some weaponary. He decided to show off his flying skills and did a low level flyby of the watch tower......and the rest as they say is history !!
    Andy
    I wondered what that thing was!! :D
    B)
  2. Currently reading a book from my local library on the F-86,and its kinda got me interested in building one.
    With all the overseas operators aswell as USAF jets,i wondered if anyone would be up for a GB?
    You're actually going to BUILD something? :D
    B)
  3. Hi Neil;
    Where exactly did you get the Cooper Details set from??
    Pete
    Tell the truth, I had that set kicking around for ages, Roy Sutherland (Cooper Details) gave me that set with a bunch of others quite a few years ago. So it was a long while before I actually did anything with it (I think most of us are guilty of that, where model stuff is concerened!! :whistling: )
    B)
  4. I have a 1/72 highball belly here if anybody wants it. Not sure if it is a complete conversion as it is just the bomb bay and bombs
    That one is now well out of date, been superceded by something more comprehensive.
    B)
  5. Just for Mike, when you get the bits in the post these two pics will show you where all the bits go, because the instructions are not finished yet.
    This is the Narromine one, if you do a UK based one leave off the 4-blade props, arrestor hook, tropical intakes and the second reinforcing strip from the left fuselage side.
    B)
  6. ...and jolly glad we are too. Who else does so much for the bestest plane in the whole wide world? :D:thumbsup::worthy:
    With a bit of luck I should be putting a Highball in the post in the next day or two. Dont forget there are no instructions yet tho :whistling:
    B)
  7. Im jealous the way you guys do your weathering, any hints and tips for a newb like me? :D
    The weathering on the panel lines was a coat of black sprayed on them before the top coat of camo colours. Worked out quite well. A little bit of thinned Paynes Grey oil paint was put on here and there after the camo colours were dry too, though not too heavily.
    B)
  8. Gee thanks Neil...
    I'm building this kit at the moment and I've heard there is something wrong with the dimensions. Can you say how you did the resin plugs?
    With my build I decided it looked like a spitfire so I was determined to avoid AMS and build it out of the box. But now...... I'm kinda interested in what the main issues are. So can someone enlighten me.
    Now I don't want to re-open any old wounds or start a war on what kit is better :D But I'm just interested in what is (or is perceived to be) wrong with this kit
    Plus those flaps look good, so I'm considering having a go at something similar
    I don't know all of the in's and out's of the faults with the kit, but the extended section I put in is about 4mm I think. I made a sort of 'L' shaped cut in the rear fuselage and just slid the tail back and filled the gaps with small scraps of resin that were laying around. Piccy below:
    And the flaps are the kit parts cut out and the ribs are sliced from a piece of paper which had been soaked in thin superglue. (Had no plasticard at the time!). Another piccy below:
    B)
  9. Ta for the comments, peeps. :) . The Spitfire is such a nice shape, dontcha think?
    Flaps down? On a Spifire?
    Looks very, very good Neil. Now go do one in 1/72...
    It was, ahem, in for maintenance that day :whistling: :D
    That is definately one of the better Spitfires I've seen Neil, you are really quite good at this modelling lark aren't you! :whistling: :winkgrin:
    Jen.
    Results of a mis-spent youth on my part I think Jen. I was always faffing around wih model 'planes as a kid.
    He should make a acreer out of it :unsure:
    Now there's a thought .... :P
    B)
  10. Built from the 1/48 Hasegawa kit, a jolly 'ole Spitfire! Built with a Cooper Details resin cockpit set and some scratch built flaps. I heard about the length/shape issues with the fuselage and did a little bit of modifying to it. It isn't the perfect solution to the fuselage errors, but it looks like a Spitfire to me :whistling:
    First pic shows the scraps of resin inserted into the cut rear fuselage to gain a bit of overall length, also some scraps inserted into the lower fuselage and around the lower fin/rudder area. Not an ideal answer, but good enough at the time ;)
    B)
  11. Obviously most of you have seen this before, but what the heck .... :D . Jaguar T4 converted from the Airfix GR1/3 kit using, er, somebodys resin conversion and add ons. Not to mention Ed Granthams funky auxiliary inlet door hinge decals and crew names.
    B)
  12. Another one from the way-back-when list! More or less straight out of the box, except for being rescribed. For the life of me cannot remember if they are kit markings or not though. Used some of my 60lb rockets under the wings, which I think is the only aftermarket stuff on it.
    It was airbrushed using Extracolour enamels, thinned with cellulose thinners. Dries nice and quick that way.
    B)
  13. Built this many years ago, the Cooper Details multi-media Whirlwind. Main airframe components are vac-form, with resin cockpit/detail components. I think there may be some white metal bits in there too, such as u/c legs, and also some photo-etch bits and pieces. If I remember correctly, it was quite an enjoyable thing to put together.
    I always liked the 'look' of the Whirlwind, it's probably those closely grouped cannons in the nose that does it. :)
    B)
  14. Great shots Neil - any plans to produce these in resin (I know you've probably been asked this a lot )
    John
    Thanks Neil,
    I hope we'll be seeing them from you :pray:
    Stephen
    If I had enough time spare I would certainly give them a go. My hands are a bit full with a bucket load of those new Mosquito bits at the mo I am afraid.
    B)
