Toftdale
Members
  • Posts
    952
  • Joined
  • Last visited
Posts posted by Toftdale
  1. Good luck on spraying the body, those side vents look like they could be a bit tricky - Andy.   PS I'm sure I read somewhere that the early cars only had one mirror as this increased the top speed by some ridiculously small amount (but it meant they hit some vanity target),  however I can find any where on the Internet to back this up 😅🤣
  2. On 31/12/2022 at 16:28, Anteater said:
    Seeing as you've already filled the hole you're halfway there
    The hole was filled,  but as soon as I started flating the filler just fell out! So I ended up building up with primer.   The green now looks a treat,  the only problem being the tape started to lift so there was a small amount of green on the louvers in the yellow stripe, which I managed to remove with a cocktail stick,  but also removed some yellow paint at the same time 😬.  So I'll let it dry for a few more days and spray the yellow again!!  - hope everybody else is having better luck - Andy
  3. 18 hours ago, Spiny said:
    Ultimately, I'm sure you'll end up with something invisible to the real-world viewer whichever way you go about it.
    Hi Spiny,  thanks for suggestions and faith.  I've already gone down the filler route using some perfect plastic putty, let it dry slightly and then using a chisel made from a cocktail stick removed the excess filler, Hopefully leaving it flush.  The repair does look flush,  but as we all know surfaces always look good until the paint is applied.   The reason I chose this option is that experience has proven that I'm not very good at not burning through the paint when polishing.   Once again thanks for you advice,  it's always welcome.  I hope you gave a great 2023 - Andy
  4. 20 hours ago, Fnick said:
    That's a bummer Andy. After such a good save...😟.
    If it was me I would try and fill that hole with primer,sand gently and then a few mist coats of colour again sanding down very gently in between coats to try and blend it in with the surrounding area.
    That is however not based on any experience whatsoever...just a hunch it might work!
    Nick
    9 hours ago, Bengalensis said:
    Depending on what type of paint you have used you could perhaps slowly fill the mark with green paint until it's proud of the surface, then lightly sand and polish.
    8 hours ago, Noel Smith said:
    Bengalensis idea seems best as it is a small hole.
    It the paint is acrylic it should work well as it will dry out fast.
    If the paint is enamel or lacquer I would go the fine filler route, smooth and touch in.
    Thank you Gents,  the paint Lacquer (Zero) so once rectified will require a clear coat.   It never even dawned on me to use filler, which is the approach I think I'll take as I believe I can level the surface this way with less risk of further damage - thanks again - Andy
  5. Thanks @Fnick @Windy37 @keefr22 @Spiny @heloman1 @Noel Smith for the advice using a combination of your combined wisdom the nose cleaned up a treat and I managed to remove enough green from the louvers that I could respray the yellow and completely mask the overspray.
    p?i=4fa0ed8c24e22491cb316f50b0edc508
    However what the modelling God's give with one hand they take with the other!   As I sprayed the yellow I completely masked the entire bonnet and upon removing the mask a piece of paint about 1mm square came chipped off; including the primer.
    p?i=2d1f9799b08fb5a190c0766ce7e16cd6
    So once again if anyone has any ideas how to remedy this without striping all the paint off and starting again I would be incredibly grateful.
    On a happier note,  I had been putting off the wheels as I thought the masking would be a nightmare.  In the end I sprayed the entire wheels tyre black (after priming).  Then using a cocktail stick I was able to  define the edge of the wheel, which then allowed me to cut the mask using a fresh blade.  I also masked the rear of spokes at this point.  I then sprayed the anthracite.  Next came the tricky part as my wheels have diamond cut rims.  I managed to cut a circle of thick paper so that it it was just held in the wheel with friction allow me the to spray chrome.  The the paper was removed and gloss applied.  Hopefully the pictures make more sense than my ramblings.
    p?i=9568f4991604efc11cf062b79ccd51b6
    I printed my own decals for the wheel centres and used  1.5mm punch to cut them out.  However these proved just too fragile to use, so I have just stuck the decals (still attached to the backing sheet) using white glue.
    p?i=bd2df542da71da6ac851b7c63d302d66
    Thanks again for looking - Andy
    • Like 13
  6. 37 minutes ago, Vesa Jussila said:
    Audi S1 Beemax
    - Lancia 037 Tour de Corse Hasegawa
    - Lancia Stratos Safari Hasegawa.
    - Audi Quattro Gr.B reneisance resin body + Tamiya
    - Peugeot 205 Evo 2 based on Tamiya +Tamiya 405 + reneisance parts
    A model every 10 weeks is very impressive,  me I'll be over the moon just to finish the 1/24 Caterham I started in 2021!  Hope you had a great a Christmas and a happy New Year - Andy
  7. 45 minutes ago, Windy37 said:
    Errr , I usually just put the end in my mouth ! It seems to reduce the friction a bit . Sorry to sound rude ....
    Gary .
    Hi Gary, I'm glad I asked before rubbing the bonnet with thinner soaked cocktail stick!
    41 minutes ago, keefr22 said:
    Rather than sanding the nose overspray I'd try T-cut or Tamiya polishing compound if you have any, as they'd be a bit gentler. If you're as clumsy as me, if you sanded it you might go straight through to the plastic...!! I'd do the same using compound on a cotton bud for the overspray on the stripe.
    Keith
    Hi Keith,  that definitely makes sense for the nosecone.  I think I'll be using a combination of this and a cocktail stick on the bonnet.
    Cheers both - Andy
  8. 18 hours ago, Fnick said:
    Amazing what a bit of colour does! Looking good. On the overspray yes I would imagine the nose can get sanded off. On the louvers is it worth trying scraping it of gently with a needle?
    Nick
    11 hours ago, Windy37 said:
    I find a cocktail stick , slightly moistened , removes small areas of overspray . Rub gently of course !
    Gary .
    Hi Gents thanks for the suggestions.  Just one question Gary, when you say slightly moistened, do you mean with thinner?  Thanks Andy
  9. Well it's beginning to look alot like a Caterham!
    p?i=ff08d8b0fc447142de160568cc6c9b14
    On my 1 to 1 scale car the yellow stripe is painted over the racing green, however on this one I opted to paint the yellow first.   Primarily because I don't think the yellow would be opaque enough to cover the green and secondly I thought it would be easier to mask this way around.
    However I did get some bleed through of the green , due to the fact it was very hard to mask the louvers.  So I guess I'm going to find out whether the yellow will cover the green, unless anyone has a cunning plan to remove the unwanted over-spray.
    p?i=80bc9338d8ddcd2a4c7f1deee44e34d5
    Plus I also failed to mask the nose up 100%, so there's a faint green line on the top to the right when looking from the front.  I'm hoping this can simply be sanded off.
    p?i=f5cf2d34db197c240c8ee9c8f5883785
    This is also the second Christmas I've been working on this so I sincerely hope that next year I will be on a new project.   Whilst on the subject of Christmas I suspect this will probably be my last update before the 25th, so hope you and your loved ones all have a merry time - Andy
    • Like 14
