Toftdale
Members
  • Posts
    952
  • Joined
  • Last visited
Posts posted by Toftdale
  1. 8 hours ago, johnlambert said:
    Nice work on the doors, just watch that the thickness of the paint doesn't result in the dashboard sitting too high and preventing the body from fitting properly.  I remember having a bit of a battle getting everything to fit nicely.
    Hi John, thanks for the encouragement and especially the tip.  Knowing these little things can make a huge difference to the finished model and my sanity 👍
  2. Well I seem to be build this in a very unorthodox order, but I sprayed the door cards at the same time as the body, hence I thought I might as well finish them, although of masking latter there done.  The reason I build new winder handles is because I tried to be clever and run a razor saw just down the back of the handle (leaving the central section untouched) to give a more 3d appearance.  Let's just say it didn't work a planned, however yet again I think I have benefited from my mistake 😅.   The winder was made from a bit of sprue, plasticard and a pin head.
    p?i=93db8435793b17ec7e3521cf12363e99
  3. Hi Nick,  I'm predominantly a car modeller but occasionally dabble in the darkside.  I tried to build this kit a couple of years ago, but gave up trying to get the droid to stand on the STAP.  I have just had a look at your Flickr account (very impressive, absolutely love the Turbine Combat Racer) so I am sure this will be just a good as the rest of your collection.  The main issue I came across was the amount I had to splay the droids legs apart would mean you would need to position his feet ar 45 degree angles to make them stand on the foot controls.  So I thought I would be clever and move the footrests in towards the centre,that did not work either.  I'll be watching this with interest.   In the end I scraped the STAP and now the droid stand centery of my desk. Andy
    p?i=f229db0768f140367ad8f448f19c4820
  4. Today my pot of Zero Paints French Blue turned up.  So now the racing stripe is completed, this was a fairly simple step, however if you could see me I'm sure you recognise my smug face 😏.  Bizarrely I think me making a mistake on the white stripes width actually looks better as there is a clear demarcation between the body colour and the stripe.
    p?i=4e3e3b5012920d7b92d6020c0e525c5b
    • Like 15
  5. The first stripe is on, it my not look much but it took me ages.  My new plan after my initial c##k up was to have the central white stripe at 4mm and the outer blue and red at 3mm.  However after a bit of thought I decided to try to get all three at 3mm with a half mm border each side.  I devised all sorts of elaborate plans to get the half mm gap using tape, rulers and technical drawing pens and then scraped it all and did it by eye.  Also I'm not brave brave enough with the air brush just to mask around the area to be painted, so I had to mask the lot.  Anyway the main thing is I'm really happy with how it came out 😁.
    p?i=50f2eb5e6fbd4bf2936b9f909cd7cd7b
    The only non metallic blue I have is a Ford Olympic blue, which is a lot lighter colour than I really would like.  Does anybody know of any other approach other than adding black to darken it as I think I would end up with a grey 😏
  6. Just started a little detailing on the engine,  some of the photos I've seen show the exhaust being wrapped.  I used some 3M tape (I think it came from a first aid kit, but can't be sure) painted Tamiya white (too see through unpainted) cut into thin stripes wrapped around the exhaust and secured to ends with photoetched cable ties.  Not necessarily hard, but very fiddly.  Plus also made a dip stick (also quite obvious on some photos) from brass wire (0.5mm) and a photoetch washer.
    p?i=902f54e55aaad4f4d4527bb5b81d5563
  7. Hello, the only two tips I can give you is make sure you rough up the surface with some very worn wet and dry to give the primer a better chance of sticking and make sure you wash the model thoroughly to remove any greasy finger prints before spraying and then avoid handling were possible.  Oh and as Andy says leave it at least a couple of days between spraying the the primer and colour.  - Andy
  8. Oh dear, (that wasn't the exact phrase I used) some how I used 10mm tape instead of 6mm for the stripe😳.  So perfectly dividing the stripe in 3 will 2mm tape is not going to happen.   Just ordered some 3mm tape so I'll end up with the red and blue at 3mm and the white central bit at 4mm.  I knew it was going too well!
  9. Well I promised slow progress.   I pretty much exclusively use Alcad micro-filler primer on my bodies and this was no exception.   The paint was fairly old so was not as smooth as I hoped, however will some well worn wet and dry this was remedied.
    p?i=c76f9ce27ef1940818f579088704551b
    After some consideration I have decided to paint the car blue (as per virtually every one😀).  But with the twist of adding an offset French Racing Stripe, so first painted it white (Zero paints gloss white) and them using 6mm Tamiya tape to make a stripe.
    p?i=e267b0a443e56ddc2ca11de5db627fd5
    The plan is now to use 2mm tape to add the red and blue sections, wish me luck - Andy
  10. 19 hours ago, Marco F. said:
    Cool looking little red 7!
    The cycle wing conversion looks great. Can you please show us the mountings of the wings
    Marco F
    Hi Marco,
    On the early sevens the front cycle wings did not turn with the wheels.  The top mounting was connected to the front light bracket and the bottom mounting attached straight to the side of the car (presumably to a chassis rail).  As mine was going to be a track car I cut off the lights leaving the part highlighted in yellow, then drilled up the end of this part allowing me to insert a bracket for the wing made of wire.  Hope this helps regards Andy
    p?i=32890cbddfa76cb3ee08859f60700fc7
  11. On 30/12/2015 at 22:23, stevepni said:
    Does anyone know if there was a kit of the S4 made?
    I have only just joined the forum,  hence the answer almost 4 years late 😅.   Nichimo made one, however it is a fairly crude model designed to be motorised.
    p?i=bd0c5fa4d93ff7c3d673833ced5ac41a
  12. Considering my obsession with the car it strange that I have only built 1, about 15 years ago, hopefully my modeling skills have improved since.  Although it the first car I painted using an air brush and was proud at the time that I converted it to cycle wings.
    p?i=8226639bf0d5171e74895d9c67ffdb83
    I also too have all three 1/12 caterhams and the detail set from Replicas of Maryland which includes photoetch to make working bonnet catches!   However my favourite is my 1996 1400 supersport below, photographed on last years holiday to Spain 🇪🇸
    p?i=c1453c4af16a12f1b7f3e2ffe3e6fb39
    It only makes 128 bhp, and Torque is also quite modest at 100 lb foot, but it only weighs 520 kg, so it is more than quick enough.  My car also has the 6 speed gearbox (Caterhams on design) which is effectively a 4 speed with 2 extras slipped in so you can always be in the power (5k plus).  The change up light comes in at 7200 and if your not quick enough on the up change the rev limiter comes in 200 rpm later, It not relaxed or refined, but it talks to you and rewards you in away that I have never experienced in any other car.
