Posts posted by Toftdale
As ever the model looks spot on, but really impressed with the plaque. You must have a really steady hand.
1
Very neat crome, especially on the headliner
1
Some very nice touches, looks like something some undesirables would be driving in a TV cop show back in the day!
Learning a lot from watching your work, thanks for sharing
1
As the others said its really coming to life now, really enjoying this thread. Thanks for sharing
1
Just caught upon this, great work. Especially the flocking, this is something I've never really had any success with, but after seeing your results I might be tempted to try again. - Andy
Top work
1
Just found this, there's only 3 photos but it shows an engine out of the car so you get to see detail you can't normally can't. Ideal if you've just brought the re-released tamiya lotus 7 - Andy
3
1
Had a go at making the bonnet today from a coke can (other soft drinks are available
). I knew it was not going to be the finished product, just to see if it realistic for me to do. So I made a pattern using masking tape over the kit part stuck it to the can and cut it out. It is not very clear on the photo, but I let a edge of about 1mm to give me a return on the side edges of the bonnet. I then used a photoetch bender to get me a 90 degree bend on both edges. Then shaped the can over the kit bonnet by hand. For a 1st attempt I'm quite pleased, however if anyone knows a better way to achieve this, please let me know
The most valuable lesson I learnt was that if you take you pattern from the outside of the kit and then transfer it to the inside of the new part you end up with a bonnet for a crossflow!
Again thanks for the interest - Andy
11
1
1 hour ago, Pascal said:
I used spraycans for primer, green and clearcoat. The clearcoat gave me a very big run at the rear of the body. The run was sanded and a thin layer of clearcoat was sprayed over it, it's no longer visible :
Sincerely
Pascal.
Hi Pascal, thanks for sharing, fantastic paint. I am sure no Lotus 7 ever left the factory with that deep a shine. Between Anteater's recent caterham build and yourself you've set me a very high standard to try and achieve
6 hours ago, Pascal said:
Nice project. Build this kit some 15 years ago. Added some details to the engine compartment, wooden dashboard, bezels made from wire, etc. And, I had a big paint run on the rear of the body. If you're interested, I think I still have the photos.
PS : great idea to finish it with an aluminium body. I would give kitchen foil a try. It comes in many shades and is a lot cheaper then BMF. Check out some of the WIP's of the airplane modellers for inspiration and how to's.
Sincerely
Pascal
Hi Pascal, some photos would be great Plus its brilliant idea to check out the aeroplane WIP and one that I would have never thought of - Andy
I don't normally like making more than 1 model at a time, because for me its a recipe to not complete anything. However the Alpine is suitably near completion (as long as I do not screw up reducing the paint run) that I know it will be completed and with 2 more weeks until the clear is suitable cured to be sanded I have started on a 7. I have not done much, just enough to show the direction I am going. I have often wondered how I could manage to make one with an aluminium body and painted wings. It would be nigh on impossible to mask. It is very easy to remove the wings, but the trick is getting them back on. But I have com up with a cunning plan
. On the model the vertical surface of the front wings touch the body are so thin that they disappear when the wings are cut off. Therefore I have glued some thin strips of plastic below, then used stretched sprue between this strip and the wing to reinforce the joint. Then a small amount of filler. Next Drilled two holes on this new strip straight through into the body before cutting of the wing. Now I can use pins to locate the wing back in place after either painting the body or using Bare Metal foil, still not decided.
10
The only thing I would criticise is the title of your thread as you are really underselling your superb work
1
With work this good, I'd be very tempted to display this as an 'exploded' view - Andy
Roll bar and engine cover finished
So this means I have now trail fitted the body and chassis together
Fits perfectly, and more importantly the engine cover fits as well
So whilst I wait for another couple of weeks for the clear coat to fully harden before attempting to reduce the run, I got a great idea for a Lotus Seven! Again thanks for the views, comments and likes there al very much appreciated.
5
Fantastic model, looking forward to see with what you come up with next. - Andy
1
I can only echo what everybody else has said, fantastic work in every aspect.
1
You have obviously been very busy during your IT issues, it looks great. I especially like roof rack.
Your level of patience for the smallest of details is mind-blowing
1
Superb paint, it looks great all round
1
Looks good, but don't fall into the trap of rushing the last details. I've done this several times and always end up regretting it!
1
Just a little update got the wheels finished. Originally I was going to paint them gold, but decided not to as I associate this scheme too closely with an Impreza (before anyone gets upset, I'm am not saying I don't like the Impreza it just that this is not one
). Plain aluminium seemed, well to plain. So I managed to find a photo of the same 4 stud wheels supplied with the kit and copied this. Using Tamiya semi gloss black, liquid masking and AK aluminium. Thanks for looking - Andy ps the wheels are now fitted and all 4 touch the ground!
8
I wouldn't have a clue how close to real life the throttle linkage is. But from an aesthetic and engineering viewpoint they look absolutely spot on. Great details
1
Absolutely stunning work
1
Lotus Super 7
in Work In Progress - Vehicles
Hi Nick, thanks for the comments. The only additional tip I can give at the moment is that 6.5mm is pretty much spot on the radius of the bonnet. So after the initial forming I used a drill bit to tidy up the radius. - Andy
