Redboost
Gold Member
  • Posts
    978
  • Joined
  • Last visited
  • Days Won
    3
Posts posted by Redboost
  1. Spad: the Malcom hood comes from Squadron canopy set which I guess is intended for the Monogram kit, but the Malcom fits perfectly.
    Ali: I used Gunze Mr.Color flat laquer thinned with original Mr.Color thinner in 1/10 ratio.
    Libor
  2. Hi,
    thanks, I'm trying to check that site but for unknown reason the page still crashes; I'll try later on.
    I know about the bomb rack(s) on Republican machines. As far as my poor French allow to understand the Airmagazine article, the passenger seats were removed from the cabin and replaced with six vertical bomb racks (I guess something like Italians used on SM.79 or Germans on He 111). Don't forget on the fixed machine guns, one per wing and one synchronized mounted on fuselage side (not sure about its exact position as the period pictures are not clear enough on this).
    Grey color scheme sounds good, not sure seeing such, but quite possible I guess. Or it might be mismatched with dull NMF.
    Libor
  3. Ok gents, time to start my first contribution! :pilot:
    I would like to build this kit in the Nationalists marking. The kit contains only the Republican options, so it is up to me to make own decals or paint masks.
    At the beginning, here is the overview of the box content, the machine I intend to built and the draft of the masks done in Corel I 'll be cutting on a plotter.
  4. Hi walrus,
    good luck with this one! Actually, I am going to join this GB with the same kit :D
    Do you have the French mag Airmagazine? No. 18 and 21 includes articles with lot of photos (unfortunately the text in a strange language I ca'nt read) :smartass:
    You mentioned the markings are for Nationalist aircraft, what is obviously not the case. :)Btw, the Nationalist used captured V-1's and their camo is sexy too.
  5. Hi there,
    Recently I finished the Academy single seater kit. The colors are AII Green (lighter version), AII Black and AII Light Blue. I used Gunze paints for upper colors, H312 Green and H12 Flat Black (with little white to tone it down). The Light Blue comes from Aeromaster range, but it could be find in the Gunze too, if required.
    May I add some hints, please ingore the instructions as the camouflage pattern and recommended colors are wrong. The Brown/Green combination was never used on single seat Il-2's. The very early machines very Dark Green over Light Blue, later the Black/Green patterns were inntroduced. There were also some other variants using "emergency" colors in case the regular colors were temporarily unavailable. The Il-2's were manufactured in three factories and each factory usually used their own "standards" (it is simplified, but basically true...).
    Of note is fact that some of the machines featured in the kit could have had wooden fuselage rear and wing outer parts and different armament (Shvak cannons instead of Vja located inboard). For example, the Il-2 I built had wooden fuselage with external stringers I made of plastic profiles. The best way is to look at the photos, albeit they are very rare...
    Good luck with your Shturmovik!
    Libor
  6. It is unofficial, but Mr.Sulc from Eduard mentioned that on a Czech modelling forum. It is a part of their plan how to overcome the recent economic issues, they want to utilize the know-how from already done attractive models (e.g. Trumpeter works in this way too) to scale down (or maybe up?) some kits and the Bf 110 in 1/72 will be one of them. Release date is of course not known yet, but considering the Eduard's release schedule it may take a year or so.
