Faraway
Gold Member
  • Posts
    2,805
  • Joined
  • Last visited
Posts posted by Faraway
  1. And so, I've got to bend the railing to fit the platform.
    p?i=36cfe406ae8cf2f1ba77c0b8563d2dd7
    It worked, and a lot better than I was expecting.
    p?i=5d27075bb05536ff4e3896a4ecdf24a4
    So, now I can fit most of the remaining bits to the mast.
    p?i=d7569e92093ecada7930728e7a300583
    p?i=31bcfea17d9f7c12a0f5c01536c3de66
    There are still a couple of bits to fit below the platform, but, they must wait until the mast is in place as the mast goes through a part of the bridge.
    I'm just waiting for the glue to dry and then give it a coat of paint.
    There is also a radar antenna to go right on the top, but that will be the very last part after this build is finished. For the obvious reason.
    Jon
    • Like 11
  2. 7 hours ago, ArnoldAmbrose said:
    Gidday Jon, I used to use an epoxy glue (5 minute Araldyte) as a re-inforcing glue but I've switched to PVA glue as a re-inforcing glue/filler because it's more convenient to use - I don't have to mix it. But I don't know how it compares to Epoxy strength-wise. Regards, Jeff.
    Jeff. PVA is a thought, araldyte is good but wasteful when end up mixing four times more than you need.
    Jon
  3. The midships has filled up nicely.
    p?i=add483fbc1c034d851371d1be2ec93ad
    p?i=e3c507ebaf545340b337f0f8c8e30f45
    So, for a slight change in direction, I thought I'd make a start on the masts. Can't beat the smell of hot soldering iron on a Sunday afternoon.
    p?i=c66bf7ab9ba5ccdfa8364552d8ef6ed5
    Now, I've got a bit of build planning to do.
    These are the instructions for the main mast.
    p?i=0021b62db7e761d8ccb744dab7e69b72
    As you can see, there are one or two bits to fit to it.
    The first part, simply because the mast goes through a hole, is the searchlight platform.
    p?i=4eb8cbc39008491ea76a97d9e8f1e9bd
    I've pinned it down, as you can see, but I need to support it somehow, as the mast doesn't go through the centre, but is slightly offset.
    And sadly I can't solder plastic to brass, so the first go is CA.
    p?i=169e57163c59b7d5e257b6782114ff4b
    I might have to resort to Epoxy, as this platform has railings fitted to it, and I'm not sure how good the CA bond is going to be, to stand much handling.
    That's it for today, but everything is coming together nicely.
    Jon
    • Like 10
  4. 2 hours ago, ArnoldAmbrose said:
    Thanks guys, much appreciated. Jon ( @Faraway), have you considered giving it a go? It's basically building up techniques and methods, tools and jigs etc, starting simple and learning as you go. There's nothing magical about it. Regards, Jeff.
    Jeff. I wouldn’t know where to start, I’ll stay as I am.
    Jon
    1 hour ago, Bertie McBoatface said:
    There are two sort of modeller. Those who scratchbuild and those who haven't done it yet.
    Actually there are three, you missed those who have no intention.
    Jon
    • Haha 5
  5. 16 minutes ago, Torbjorn said:
    Mine is asking me why I don’t build some nice ships instead of all the stupid planes :(
    This was supposed to be above the quote: nice, another one! I’m amazed by all the wee detail.
    I think we all start with aeroplanes, simply because there is a HUGE selection of them, next is AFV another HUGE selection. But when you get to ships, then the selection starts to thin out a bit.
    But having watched some of the builds of ship models, take shape on here, I tried one and haven’t looked back, which is becoming a slight problem.(see photo above)
    Jon
  6. I recently built this.....
    I’ve looked at this kit a few times, I’ll be interested to see how it comes out.
    Hope this is of some help, should you need any, that is.
    To get a good finish on the wood and sail, lots of dry brushing.
    Jon
