Days Won
1
Posts posted by ERK
Morning all, a bit more progress - I decided it was time I worked on the Hull - first step after giving it a soapy wash down and dry, was to get my airbrush out and put down a couple of thin layers of Vallejo Black Dirface Primer, this went on quite well, I then put it aside and left well alone for about Three days.
It was earlier that I decided I could mask up the Boot Line as the primer had been given enough time - so I cut Two corresponding strips about 1.8mm wide to represent the Eight feet wide boot, this was then smoothed into position with some careful alignment both sides - its ready to start pying down AP507 above the boot - then masked for the bottom Dark Grey.
Erk.
9
12 hours ago, agyoung33 said:
Some mean work there Erk - looking very cool!
Gary
Thank you kindly.
Erk.
9 hours ago, mick said:great work
Thank you.
Erk.
I saw Tiger at the Portsmouth Navy Days back in 1976 I think - I Loved the shape of her outside of Bulark she was the largest surface ship there.
Erk.
1
22 hours ago, Marcello Rosa said:
My introduction to HMS Tiger came from a card game we played as early teenagers. Each ship had different “powers” and we played until one took all cards from the others. Same concept as Pokémon cards and no doubt other games.
Top Trumps?
Erk.
3 hours ago, ArnoldAmbrose said:
Gidday, superb work on those boats, and the model in general. Regards, Jeff.
Thank you kindly.
Erk.
Love these - I was very much into hifi when I was younger - Rotel, Q Deck, Denon, Celestion, Something Solid, Monster Cales etc
Erk.
1
44 minutes ago, Boydie said:
I really like the detail you've went into those tiny boats.
Thank you kindly.
Erk.
Really nice work - takes me back to building the old - very old Airfix 1/72 kit of her.
Erk.
1
Good day all, a wee bit more progress making and fitting a couple more boats -
Erk.
9
Makes me question adding the PE railings in kits at 1/350 or 1/700 scale as I dont think from viewing range they would be seen - and they are over scale anyway.
Erk.
1
Evening all, Two more boats - made, painted and washed.
Erk.
6
Evening all, more progress - little boaty time in the form of Three motor cruisers that were made painted and washed then glued down.
Erk.
7
8 hours ago, S-boat 55 said:
She's coming up lovely
Thank you kindly.
OC.
Very nice tidy work.
Erk.
1
Hi all, so I have painted the quad mounts and stands on the rear boat deck, and also painted the wood details in the boats/floats, I then started some shading using my dirty Brown wash - portholes/vents etc.
Erk.
6
Evening all, so after airbrushing my sub assemblies - next to be done was to paint the lower conning tower deck corticene, this was done with a fine brush, then put a side to dry - then I started assembling everything togtether before gluing all to the deck.
Needs some touch ups.
Erk.
4
3 hours ago, Boydie said:
Enjoying the build? Anything you don't like about the kit? I've been toying with buying the flyhawk Hood for a while. I made their Agincourt kit and enjoyed that even though the PE was pretty unforgiving in terms that it breaks easy.
Thank you kindly, Its a beautiful kit so well built however some areas like the conning tower sections are fiddly to get ligned up, and as you say the PE is paper thin and hard to handle, but over all its an amazing kit, so worth getting the delux kit and the optional wood decking.
Erk.
1
Evening all - Happy New Year to all, A bit more progress - I got my airbrush out and attacked the sub assemlies with a coat of primer, then after drying I put a few thin coats of AP507A over, I then put them a side to dry.
Erk.
12
9 hours ago, Faraway said:
There are a a few scales for ships, 1/350 is my favoured size. Although 1/144 is a nice size. 1/700 for me is far too small for my eyesight, but there are a lot of 1/700 kits out there. Have a look around the Maritime WIP & RFI forums and you’ll see what I mean. As an example, have a look at this superb build.
Jon
So kind of you to say that Jon.
Erk.
1
On 29/12/2021 at 09:08, agyoung33 said:
Wow, what a beauty - and what a tremendous job you're doing as well! I'm going to get one of these sometime - I think it blows every other 1/700 scale 'Hood out of the water!
Happy holidays to you!
Gary
Thank you kindly Gary, and the same to you.
Erk.
1
2 hours ago, Adm Lord De Univers said:
Braver than me, especially at that size, I would've done that the other way around? Not that it impacted you here, but I would've ended up painting the deck...
Happy holidays to you too, glad to see she's progressing well over the break!
David
Thank you kindly David.
Erk.
Thought I should give my experience - I ordered one to go with my Flyhawk 1/700 HMS Hood, after looking at the wood sheets (and having used Pontos in 1/350 scale before) I decided it would be best to try to keep the sheet/s as strong as possible as they are so thin, so after cutting all the holes for the various obstructions I then used my Gorrilla Wood Glue - slightly watered down - this was then painted all over the bottom of the sheet and placed down.
Thinking was - not only a wee bit more strength to the wood sheet - but also a bit of wiggle time to place it correctly.
I understand Gorrilla Wood Glue is great for fixing down anything from Clear plastics - wood - and even PE, so thats what I did and its still stuck now several weeks later - famous last words.
Erk.
Evening all, hope everyones holidays went well - a bit of an update, I fitted a few bits to the rear section of the boat deck, some of these are Resin pieces, they where glued down then painted with one of my fine brushes.
Erk.
8
On 19/11/2021 at 21:53, Modelholic said:
Could you remove your airbrush from the compressor's pipe and tape the pipe to a piece of wire (or something stiff and thin) and gently thread it forward from the rear doors and give it a quick blast? (virtually on then off) There'll not be much pressure (test first on palm of hand).
Tom
Sorry for the late reply only just seen it - alas the kit was binned.
Erk.
1
Flyhawk 1/700 HMS Hood Dio after she Blew Up.
in Work in Progress - Maritime
Thank you kindly Jeff, not easy to do at this scale.
Erk.
