Days Won
11
Posts posted by Habu12
I normally would say it’s not dirty enough, but it being the prototype..
Love the gold!
- 1
This is dedicated to my friend of 27 years, who we lost earlier this week. Clear skies and tailwinds, George Louis Creed...
- 26
- 1
1 hour ago, Alex SZ1996 said:
looks super nice. i plan to build my F-14D in same scheme with VF213. there isnt really many schemes i like for the D version, but this Black Lions scheme is just the scheme for me.
Well, there’s really only six squadrons that flew it, so it’s limited. But there’s still several version a of each. Thanks!
1 hour ago, colin said:What a cracker, have the A and from what I read the fit of the parts and the way it's engineered is on another level to anyone else out there
It’s nanometer sharp! As good as Bandai’s.
- 1
It was easy to roll right into this one after the GWH 😎
I had to rescue this one for the SoD, after finishing the GWH kit. Aires cockpit and exhausts, and Speed Hunter decals.
- 21
8 hours ago, Gremlin said:
amazing Strike Eagle, did you used new Two bobs decals (maximum effort eagles)?
well done
I did!
11 hours ago, Courageous said:
Never heard of it but it looks rather cool and purposeful. Is this a drone then?
Stuart
It’s a UAV, not a drone. Drones fly a preprogrammed mission, with little to no input from the pilot or operator. Or an RPA, remotely piloted aircraft.
- 1
Ok, after a long type up, I got this review done. It’s modeled in the forms of Doug Memuro’s Doug Score, if you’re familiar with it. Without Further ado:
Great Wall Hobbies 1:48 F-15E Strike Eagle
The D Score
In The Box
Packaging/Decals/Pubs:7
The box has attractive and colorful boxart, andportrays the aircraft in a dynamic setting. The box is a standard, top opening box of good construction. The instruction sheet is laid out in standard, isometric drawings and exploded views, which are mostly accurate, except for the few details I’ll explain later. However there is a mix of 3D artwork for the ordnance, that isn’t present in the rest of the sheet. Perhaps because earlier releases just needed tweaking of the instruction sheet for this aircraft. The puzzling thing about the main instruction sheet is that it wasn’t stapled together in booklet format. It was just folded over and kept loose leaf. This was a nuisance throughout the build. It also included separate decal placemnt and color guides which were of good quality, color and register.
The decals only come with one aircraft from RAF Lakenheath and is the only option you can choose. Aftermarket is well stocked for Strike Eagles, and except for the tail flashes and refueling door, should have little issues getting those to fit this kit. The quality of the kit decals falls well short of current state of the art, and brings the overall score down. They are of the matt finish type and had trouble laying down and not silvering without a lot of setting solution.
Sprues: 8
The sprues are laid out mostly logically, with each subassembly on an according sprue. Some parts you do have to dig for, and are on another sprue you may not have opened the bag to yet, which is kind of annoying, but common in most kits nowadays. A couple of very annoying issues were that while the instructions show a center belly pylon, and a Sniper pod pylon, neither are included in this release. So if you want to add a JDAM on the belly, or the standard fitted Sniper pod, like I did, you have to source it from another kit or a weapons set. I had to pilfer a centerline pylon from the Revell kit, and the Sniper pylon from a Hasegawa weapons set.
Speaking of weapons, you get the standard sprue for GWH kits which includes one AIM-120B, and AIM-9L and AIM-9X, with a couple GBU-12s and GBU-38s. They focused on the GBU-39 SDB JDAM and if you want to outfit it with a full complement of them, you can. You get the rails and SDBs. As I was using the TwoBobs sheet, it called for six GBU-38s, which I sourced from Eduard Brassin sets. I also added a GBU-31 JDAM, AIM-120C, and AIM-9X from a Tamiya Viper kit, because they have crisper detail. Since the GWH kit uses previous iterations, their detail is a bit softer.
Shape: 9
The shape, as far as I can tell is pretty much dead on. I tale appoint away for the softness of some of the detail, such as aerials and RWR bits and bobs, It just doesn’t haver that extra sharpness that other manufacturers have. GWH fixed their oblong nose shape issue a few years ago, and finally have it correct, and this release includes that new nose. The canopy, however still has the flat spot on top. It doesn’t match the distinctive bubble cross section of basically every fourth generation fighter.
Subject/Cool Factor: 10
The subject is a favorite among modelers, and enthusiasts, and I don’t think anyone grumbled that were getting “another” F-15E kit. While the Revell kit is still readily available and still holds up well with time, there are still some shortcomings to that kit. However, I will mention this kit again later. Many called for this version when the B was released several years ago, and GWH answered. As for the subject, it’s been an important asset in recent conflicts and was a popular subject just after its combat debut in Operation Desert Storm. It’s been a favorite ever since, and with all the new versions out there (I,K,SG, X), it’s still going strong in the 1:1 world with no signs of slowing down anytime soon. Important, common, popular, and cool!
Engineering: 8
The kit contains many large pieces to eliminate panel lines, which shows a lot of forethought. However, some of the panel lines show inconsistent depth. This may be to show more prominent panel lines, and subdue others, so you don’t get the much maligned “too much rivet detail” complaint. The large pieces do make sense, with the top wing piece as one large piece, the bottoms another. The fuselage sides, control surfaces, and CFTs all one pieceitems. Where it does disappoint, as I’m sure it has been pointed out before, is the thickness of the control surfaces. They are simply as thick as a brick! The trailing edges can be sanded down, if you wish, but I see that as a waste of time. It’s just inexcusable, given the effort made to correct other issues, how was this missed, again?
Add it all up, and the Box score is: 42.
Build
Fit: 9
Because most of the major parts are large parts, fit wasn’t an issue. You weren’t adding parts to parts to parts to build a subassembly. The major airframe was really onlysix parts, not including the CFTs. It goes back to the engineering of this kit that those all came together nicely. The CFTs, as a mater of fact, had no issues. Just place, and add some Tamiya Quick-Dry Superthin cement, and you’re golden. Some of the seams were a bit wide in places like the rear RWRs, the vertical and horizontal tails, and the control surfaces. So that drops it down a notch.
Detail: 8
The ACES II seats were a disappointment. I ended up using the Quickboost seats, as they had better harness and overall detail. Where the detail shines is in the engine exhausts. The fit was excellent, and the one-piece actuator bloom was a stroke of genius. I had originally planned on using a resin aftermarket piece for each, butdecided to go with the kit exhausts. But because the ordnance was used from earlier kit, where the detail was soft, the score gets dropped another place.
Effort: 8
The kit went together quickly, but the sheer amount of parts, other than the large main airframe did get a little tedious, especially with the eleven items of ordnance and pods. It’s not the fault of the manufacturer, however as the Strike Eagle is a complex subject.
Value: 5
At an MSRP of over $90, this is not a cheap kit. Is it worth it? Yes and no. The amount of engineering that went into this kit sure warrants such a high price, but the Revell kit, is almost up to par with this kit, at a third of the price. While you do get a lot of SDBs, you don’t get much else for ordnance in this kit, and the little else you do get, is a rehashed sprue. I ended up using all external options for the ordnance. You only get one option for decals, and the decals themselves aren’t of great quality. Partnering with an aftermarket for decals may be the way to go in the future, if they don’t make the effort o fix their decals now. Not to tomorrow, not today…now. The missing pylons are inexcusable. These are staple parts of the jet, and not many fly without them.
Fun Factor: 8
Despite its few shortcomings, this was a fun and enjoyable build. The subject is popular, and provided you use aftermarket decal and ordnance options, you can build just about any F-15E in the fleet. I had no real frustrations in the build, and never once had the urge to bin the whole lot. But the fact that I had to go aftermarket for a few things does bring this score down a bit.
Add it all up and the Build score is: 38
For a grand total of: 80 out of 100
- 1
11 hours ago, whiskey said:
Awesome work. How were the TB Decals? I've got the Caracal set and still debating on whether to get them as a supplement.
Superb. No issues.
I always check for adding noseweight. Even on builds that shouldn’t need it🤷🏼♂️
Standard fare. OOB with Eaglecals.
- 42
22 hours ago, Bill.B said:
They’re delicate and the weight of the wings bent them. So I do have the pogos, they’re just not in the pics.
- 1
12 hours ago, Rod bettencourt said:
Very nice!! How was the build?
Rod
Mostly painless. There’s still some work that AFVC still news to do on fit and fidelity...and that weird plastic. There were lots of gaps, mainly on the wings, and bottom of the fuse. In fact I did have to shim the seam by the lower periscope opening, and the Q bay side seams.
Dir-ty!!!
- 1
3 hours ago, CaracalModels said:
It's a beauty - thanks a lot for sharing. I hope you enjoyed using the decals.
I did! Like I said, there was some tweaking I had to do to the walkways, since it’s not specifically sized. Thanks!
2 hours ago, franky boy said:Very nicely done sir!
What is the measurement of the wingspan? I ask as I'd love one of these kits but haven't probably got the space for it.
Thanks
Jamed
Uh, well the box info had the dimensions, so I’m not sure🤷🏼♂️
But I can say that it won’t fit inside the IKEA Detolf display cases I have. I had to set it atop the case.
- 1
40 minutes ago, Farmerboy said:
That’s a great looking model, superb paint job, I would imagine that the wing walkway decals were a challenge!
Not as much as you’d think, since they’re broken up and not continuous. That being said, I did have to cut it to fit this kit as it wasn’t designed for it initially.
50 minutes ago, neil5208 said:
Very nice, don't see many ealy model U2's. Is the cockpit canopy a kit part?
The howdah, yes it is. It’s a simple, but well detailed 5-part affair.
New AFV Club kit, Caracal decals.
- 73
So dirty and so pretty
- 1
Hey the old mold is still a good one!
What conversion was used?
10 hours ago, GREG DESTEC said:
Yep, superb finish, well done 👍👍
Whose kit is it?, And what scale?
Cheers Greg
Airfix 1/72.
- 1
Xtradecals and some antennas from Eduard.
- 31
This one’s for George... 1/72 Tamiya Bf-109G-6 Jg54
George built a little of everything. His latest builds were some Bandai Star Wars kits, and adding to his train layout. Then he worked on a military vehicle. One of his last posts was in his empty workbench with the caption “What’s next?” It gave me the idea of dedicating the next one to him. So my next one was this Messerschmitt.
