S-boat 55
Members
  • Posts
    926
  • Joined
  • Last visited
Posts posted by S-boat 55
  1. 12 minutes ago, Terry1954 said:
    Bill's post reminded me that that I have a recent picture showing that HMS Victory still stands proud close to a much newer generation of fine ships. I'm hoping you won't mind me sharing this one Crisp.
    Victory can just be seen bottom right, with R08 sitting neatly in the centre.
    Love the photo, if my eyes don't deceive me I spy 4 of the Type 45's there at present, talk about eggs in a basket lol
  2. Apologies progress has been very sparing/slow but I've been trying to work out how to go about getting ti done rather than bit here and there when i could do it more quickly if a little bit of coordination came in.
    So with a view to that i figure get all the little bits built as far as possible to allow 'mass painting t occur - which by brush isnt quick, the replacement barrels for the secondary guns came out well, couldnt have been mor easy to line up at they come with resin mounts.
    y4mp2KEpBA48Ruc4eltKdRsho7fu_uERhH2-nBDj
    Apologies the photo isn't great, this in turn led to the turrets and I found the photo etch details that go around the openings are slightly too large, not sure there's much i can do about it now though,
    y4m2t-K9Ai3Z1fVlQSDa6DOO8awWgkq2fDZbIm52
    I'll need to tidy up around them pre painting of course,
    Lastly tried adding a pre painted ladder to the side of a rear bit of s/structure, I've noticed how others' builds these seem to stand away from what ever they are mounted on a bit so i tried chopping a small bit of some spare railing to pack behind to rungs and see if it came out, Im pretty happy with the look i think but boy was it fiddly, maybe there's a better way but i cant think of one right now,
    y4mhyI3EzvsS6S4mED-d2P1ARnxlFtc2kU8280Gt
    y4mufEkhm2__Joyf69NGNyjg4apHJsSX7aiaXtig
    And good golly gosh close ups aren't kind are they!
    More hopefully soonish, I have been working on finishing the hull off but that's a few days away,
  3. 9 hours ago, PolarisPrime said:
    This is true for almost anything that comes from the Trumpeter factory.  It's the same issue with the Hobby Boss 1/32 B-24.  While they do something that is Iconic that no one else has done - and it is mostly top notch - there are glaring errors that are head scratching.  And some of the glaring errors are in major locations.
    But like you say, no one else has produced a 1/350 scale Ark Royal.  If they could just produce a 1/350 scale Nelson/Rodney instead of those 1/200 giants I would take it, bad engineering and all.
    Yes they've been promising Rodney for a while, the LHS in Gloucester has started showing it on their website as coming soon so I don't know if it will finally be appearing but I hold little hope
  4. 7 hours ago, murfv said:
    As above, I have had no problem using W&N Galeria Matt & Satin varnish over a number of paint types including enamels, Humbrol amongst them, but I make sure that they are well cured before doing so.
    Also I ensure the W&N get at least 24 hours to cure before going near it.
    Thanks for the replies both, last question I should have said I'd be using with a brush, any tips tricks with applying it or is it generally idiot proof?
  5. 4 hours ago, ArnoldAmbrose said:
    Gidday, I thought that was a brilliant (no pun intended) idea with the lights to locate those holes. That round breakwater just in front of 'A' turret looks awfully close to the barbette. It must have been a nightmare to paint in there. You'd think that French naval designers would show more consideration for future generations of ship modelers. 🙂 Regards, Jeff.
    You'd of thought but clearly they didn't, it wasn't too bad to do, but then as it's so close a wobbly line in the inside doesn't notice lol !
    Evening,
    So tried my first pin wash to bring out the detail a bit, I realised that I may need to do some of this as I go rather than all at the end. I'm pretty happy with the results, Just used a thinned bit of humbrol black satin, the pic is merely to show the contrast with it applies against not.
    y4mF9EnvdMr9-GXjDnQguFDUdQlTLZz_bE6scNqo
    Having done that I thought why not try it with the deck as it was still to be finished and fixed to the hull. It turned out to be more of a mix an match of an area wash and pin wash as it didn't always flow where I wanted it to go. Any thoughts, comments or friendly critique welcome as I'm looking to improve from project to project. I think I'm happy enough with this one though, although I've toyed with the idea of a very pale grey or almost white wash over all of the deck.
    y4mWOdUsBP0NR2uE0yCzJCr1YHGl4jXm3DTt7Fkv
    y4mrAXC_EYopvS1B-mjPPYMUHAtm466AdgboscFo
    So having done that the the fore and quarter decks were finally fixed in place. At which point i promptly realised that the last thing i had meant to do was open up the fixing holes for various little bits in the foredeck. Ooops! Not wanting to end up doing it by eye or be beaten i took to using the wifes reading light (small sun level brightness LEDs) to show where the thinned areas were and then open them up from the top. Worked a treat. The only confusing thing is some of the holes are doubled up to allow for positions for the sister ship. The instructions show this but not very cleary so it took a few minutes to work out where things were to go and which holes to open.
    y4mEr3Y_jmF6VaOOCR-xb8K1lb4J9UJ9CKsAH0JZ
    Putting the main deck in place I finally discovered a small alignment issue, its the first one of the kit that i really remember and its not exactly huge. Had I of joined the decks to each other before sticking them to the hull this wouldn't have been an issue as all it really needs is a good squeeze.
    y4m5J8oaKB6efgaY5IeBjtXMh_WzbbbO06ZEaOCA
    The issue is there is a limit as to how hard you can press on the lower deck. So my solution was to open out the area under the forward superstructure to give me access to literally squeeze it together when it comes to it. I wont fix it down quite yet as I'll need to check the rear bulkheads align okay first and its getting a touch late.
    y4mQ-YnqiEAIUXaSUz_xNPKhoXZ97Seu0_Afp4_w
    More soon
    S
  7. So life has been lifey and stopped me doing much, but progress at last - the photo etch has begun going on to some bits,
    y4ms1hTJYqlCrZ45nzQ_c250BI5adLQbAZRpgBgU
    Bending curves is fun! the platform has varying degrees of curve and so it took about 15 minutes to do, i'm hoping I get a bit quicker. much much more to do,
    Sam
  8. 3 hours ago, thekz said:
    I thought so too. Berwick is a little easier to make, although there are also a lot of small differences, and most importantly there is little photographic material on the basis of which they can be noticed.
    To be honest, I'm afraid that my so-called Berwick 70 percent will remain a repainted Cornwall.😪
    The lack of photos must be frustrating, stick with it I'm sure you'll get there,
  9. So given it was the festive period I thought I'd get a lot done, .... never mind!
    The reason I was hoping to get Dunkerque finished was I was fairly certain there was something on its way to me;
    y4mkYXEKsNJeOPbvCTohuRtV2224VI4scMeo4IjK
    As you see there was, - I already have an itch but will be 'good' and get Dunkerque finished. My only thought is Revell went a little overboard on the box! I'm really enjoying building dunkerque, the fit is exceptional and her lines are growing on me, so much so that I came very close to picking up her sister ship Strasbourg as well - still might.
    y4mKsb_liZda6ah8NDKYsRAlW3iqlljNy_UD-Vga
    I decided to tone the red down as had been hinted at, very pleased with the end result. There's still a little touch up to do on the water line but that shouldn't take long. I have at least stuck the lower section of the tower on and the funnel, rest of it is just dry fitted.
    y4mCdtTTRPRstcFcY3u56llRa8CIoAhBNKDXG5Yw
    Aside that its been a case of slowly pre painting the etch, its slow but hopefully by the end of the week I can start tackling getting real progress on the smaller bits as the deck is nearly ready for a wash. First up will likely be these;
    y4mTkXW1kyhfGbFR1ShYmRoF82fRy6zLyc8IVc9T
    More later,
    Thanks
