Posts posted by S-boat 55
Very nice, like the addition of the crew having a bit of fun on the bow planes,
2
Been doing a little here and there on Taiho, started more of the planes, decided the seats should be a different colour, some types black, others tan, does that make me a little crazy
This is how much you can see when they are fitted into the planes - not a lot, rather frustratingly I noticed there is a small blemish/raised dot on the front seat but not until id put a few in, Im not sure if it will notice or not when the canopy is in place,
Aside that Ive been fitting various small ready use lockers etc to the platforms, think they are starting to busy up nicely,
Anyone happen to know what these are supposed to be? The parts themselves have a major sink mark on one side so im hoping i can fit them in a way that doesn't show as it dont think its really fixable without loosing the detail,
Thanks
Sam
7
This thread has got me watching these kits on evil Bay, my wife may well divorce me if I give in, this really is coming together phenomenally well judging by your work so far the finished article will be exemplary
Great output from a tricky project you set yourself, hope you're proud of her,
1
Thay bowsprit is a thing of beauty, looks really impressive
1
5 hours ago, ArnoldAmbrose said:
Gidday @S-boat 55, as soon as this is done I want to get back to HMS Glamorgan in the Falklands GB, which was put on hold. I find it very difficult to do two models simultaneously. My mind is not all that agile, switching between them.
Do you have a whiff in mind yourself? If so, do tell.
Thanks for your interest and comments. Regards, Jeff.
Hi Jeff,
I'm keeping it close to my chest for now until I make a firm start, it'll be a very long show burn thing running here and there so as to not get in the way of my other project at the moment, fully expecting it to take a couple of years or more,
Sam
1
Another very interesting what if Jeff, you've rubbed off on me with an idea for something that'll be an in the background thing, once you finish off Minotaur what's on the list next?
1
32 minutes ago, MRMRL said:
Been a while since I looked in on these bad boys. Really nice progress being made, they are starting to take shape really nicely and contrast each other really well. From a fellow ship builder struggling to progress a destroyer, this joint build is a bit too bold for me, although I do fancy both ships at some point (probably won't be so brave to run them alongside each other).
Thanks for the compliment, I'm trying to get them finished for Telford in November in case I'm brave enough to enter one so I may have to pick one to focus on as I'm already at the 9 month mark we'll see, don't know that I want to pressure myself,
2
9 hours ago, Martian said:
Some of the best PE work I have seen in a very longtime.
Impressed of Mars
Thank you,
Not a massive update but wanted to share a pic or two, got the first coat of paint on the flight deck so did a dry fit of things, the deck plank detail is very fine, much thinner than trumpeters for example so I'll need to work out how to go about creating the variation across the deck as with Dunkerque I highlighted plank by plank in places. Thought this showed how bonkers her funnel was though,
This is certainly the most interesting of the two side, not that either is 'plain',
Still thinking of darkening the flight deck, supposedly it was stained black just prior to her loss, question is if the deck markings would likewise have been toned down or not? I've seen comment that likely they wouldn't have as the pilots by that point were newer recruits and inexperienced.
thanks, Sam
8
Rigging the old ships isn't what you could call simple is it, coming up a treat though,
1
3 hours ago, ArnoldAmbrose said:
Gidday Sam, that's superb work on those support frames. Waaaay out of my league. Very well done. And as a matter of interest, that little suspended cabin - any idea what it's for? Regards, Jeff.
I'll not lie.....no, the one thing I'm finding with this build is there is so little about the ship it makes it less 'historically engaging' for want of putting it another way. I quite like reading about the subject as im building it but there is so little on Taiho there's not much to read aside a couple of Web pages
Finally - finally, finished the support structures for the port and starboard platforms - all 42 of them. Its taken a wee while (the largest ones took about 3hrs each as one had 49 parts) and as half of them are now covered in (what has become red primer) they stand out less that the other side. Curious - do other people do their etch like this - lay it all out and then have one session sticking it together?
Did enjoy putting together this little cabin though, it hangs under one of the platforms, still need to add a ladder but not yet for it. It was my first attempt using photo etch scuttle details, It comes as one peice bar the door, scuttle and railing, including a section to fold under to detail the bottom of the floor,
This didn't all go without a hitch, i mentioned red primer - well in the process of attaching the etch i managed to splatter super glue across parts of the hull, some of course then smudged, others dried as blobs, murphy's law dictated that the worst parts would be on/around fine raised detail like the degaussing cable and hull plate lines. I knew when i did it that it was foolish to do it before completing this section of the work but I was impatient. I'll look for the positive and use it as an opportunity to do some wider improvements that the paint shows are needed. The eagle eyed will notice also that there is one section where the gussets are missing in two places, this is as there are two number 62's and 63's on etch sheet J or whichever it was. Means I've used those elsewhere, so I'll need to sort that as well. Broadly though for the most part it doesn't let you use things i the wrong order, the insets are on opposite sides etc to push you in the right order. Didn't mean that i didn't have to heat up several pieces more than once to de-bond and redo them having realised i was doing it the wrong way round or mirrored to what it should be.
Quite looking forward to seeing how she looks dry fitted together with them all in place.
Any who that's all for now, not sure what bit to tackle next on her, likely her enclosed bow - did they have a specific design name? I've heard them rereferred to as a hurricane bow?
Also any advice on painting her now there are all these etch areas, conscious that you can get funny effects caused by air buffeting around when airbrushing corners and there are now hundreds of them under the platforms, would it be better to use a 0.15 needle and get in close, or stick with a 0.4 and do wider coats?
Sam
17
Coming together very nicely indeed,
1
A real beaut Jon, she looks great, certainly done her proud,
Also love the angle of the last photo, really captures her sleek elegance,
1
Coming together very nicely so far, what colour did you use for rhe antifouling?
1
I've said it before and I'll say it again, she looks great, think I've settled on doing my model of Hood next after my carriers are done....probably about 2024 lol
2
I've never found flyhawk stuff on amazon UK, I always have to rely on the slow boat making its way here from China
Re flags, a while ago someone commented on a build log of mine about a company called AMP that are based in Australia, they no longer ship to the UK post Brexit but may well to the EU, if not there was a company up the road from me in Hereford that did some but I can't think of the name, if it comes to me I'll post it in the thread,
That's one big Kitty
1
7 hours ago, Baron Vaderham said:
Ended up ordering the Graf. It’sa little more expensive than the Peter Strasser, but simplified the build process a little using the mk.1 design set.
I received the Graf last night, and the kit looks good!
The mk.1 design set is held in customs - I’m in Germany at the moment - (can of worms, don’t get me started on that process).
The Scharnhorst I should be getting next week or the week after. I ordered a flyhawk detail set for it, but won’t get that until august most likely. That’s ok, I got a ton of models to work through.
You and I appear to be echoing each other lol, I'm just about to order flyhawks scharnhorst set, but have held off and thought maybe get the mk1 for it, was there any reason you chose flyhawk or was it purely due to availability? (I can't find the mk1 in stock anywhere for scharnhorst)
1
Looks great and very unique, really like this one of yours, makes me contemplate a diorama at some point,
1
Thanks for taking the time to research these things, with all the variety of shades etc it maybe spreadsheet time lol
1
55 minutes ago, Adm Lord De Univers said:
That they do Steve, the camo on the Zep has come out particularly well, but methinks no amount of camo is going to hide that funnel!
David
Between Taihos leaning one and the size of Zeppelins I did contemplate calling the thread Funny funnels in 350, it seems appropriate,
Hi, Sorry for the delay, pics below;
Screenshot of Peter strassers super structure
Pic of Graf Zeppelins superstructure
Where I think the changes are,
Its pretty different but in areas that I think wouldn't have much covered by the photo etch kit, the biggest issue may be the length of the superstructure and the affect that will have on the wooden deck you mentioned as part of the mk1 upgrade. The work around would be to scratch build a longer superstructure, patch the deck or change scratch build an upgrade aa suit at the front , depends on how much faff you want to have or avoid.
Hope that helps
Sam
1
Revell Mississippi riverboat named after a certain Southern General
in Work in Progress - Maritime
These riverboats have have such a charm to them which I think your recreating brilliantly
