nikos
Members
  • Posts
    641
  • Joined
  • Last visited
  • Days Won
    1
Posts posted by nikos
  1. Thanks guys. The name Blinder gave by NATO becuse it has low visibility throught the pilot cockpit. It is an impressive aircraft with many problems. F.E Pilots cannot ejected from upper side exept of one. Many engines problems was the cause for many accidents. It was a" heavy pedals" aircraft,
  2. Thanks guys. I decided not only to construct the models but to give them life solutions with electric triks. Specially the TU 22 M has the half pieces lost. So it will be dead in "darkness" The owner of  second hand kit told it to me but I decided to buy it and give to the kit second life chance. I was very happy with the result when I calculated and scratched correct the pieces lost.
  3. Listen my friend bar side. The problem is to calculate correct the voltage spending. I have two parallels  lines (+,-) each 9V. In that case (to Sunderland) I calculated Left side 2 motors X 3.5 V + 2 exterior lightsX1,5V+ 1 interior lightX1,5V = (total) 11,5 V the left line. The voltage conumption is good, now I will play to the left line with in trail or parallel connect f.e the wing lights,to approach a voltage 10V. It is a good voltage it will not burn something. In parallel connect does nt dead all the circuit. I will test and with a small resistance. If it will  works good there is nt problem. Now to the right circuit I have 2 motors X3,5 V + 1 led interiorX 1,5 V total voltage =8,5 volts So the 9V volt battery is big For that reason I will put a resistance to the right circuit to make bigger the consumption. But first I will try to testonly with 9V battery, if all the circuit can operates with lower rpm to the motors and lowest brightness to the leds.I will decide for one or two 9V batteries. This will be the result of test
