chrispisme
Days Won
1
Posts posted by chrispisme
It's a bit of a mundane topic compared to the fighters and jets on here...but it's progressing.
I used a ton of masking tape and had a devil of a time getting that tape to stay down with all the rivets (A smarter man would have sanded them off)
Thanks for looking
- 7
I sprayed the model with Tamiya fine white surface primer (rattle can) then acrylic white and finally with Tamiya lacquer gloss white, much masking to do yet to get the green stripes on the engines etc. as well as remove a seam on the nose before the flat black goes on.
Thanks for looking
- 5
moving along at a fair pace;
some of the tons of filler...not
after sanding
Thanks for looking
- 7
Started a day or two ago and, in progress;
Thanks for looking
- 9
beautiful work!!
- 1
coming along nicely already!
By the way that vac. kit isn't ugly...not even close...that kit is looking at ugly in the rear view mirror, ugly is a long ways behind it!
This looks like a great kit! I may have to hunt one down. Someday.
- 1
Thanks very much guys!
23 minutes ago, TheyJammedKenny! said:Beautifully done! Did you already clear-coat it? If you dare, you might consider masking the green hull areas where you got a tiny bit of green seepage onto the white along the line of demarcation, and use a cotton rag and plastic polish to gentry remove the green paint. Or just leave it the way it is, as it's most striking! I especially enjoy the contrast between the flat, exhaust-stained areas, and the gloss white / green of the aircraft.
oddly enough I didn’t see the paint creep until after I posted the pics! Since it’s acrylic green over lacquer white I buffed it away with Tamiya polishing compound on a Qtip, sharp eye there! Thanks!!
- 1
Thanks very much mates
Built from the box, kit decals little to no upgrades.
Constructive comments welcome
Thanks for looking
- 37
10 minutes ago, Moa said:
That's a truly beautiful model! And in record time! And of a plane that does wonderful things and renders a very useful service!
Excellent job and ably dealt with the tricky parts.
Now I REALLY want one of those 😁
Thanks! Coming from a true master of civil aviation I’ll definitely accept that!!
6 minutes ago, dnl42 said:That looks outstanding!
thank you very much!
4 minutes ago, dogsbody said:Wow! That came out great, even with those Saskatchewan markings! ( sorry, as I've been in Alberta for 40 years, I couldn't pass up a dig at our eastern neighbour ).
Chris
Ill take that , thank you, at least you didn’t say from the province you can watch your dog run away from home for 4 days, 5 if you stand up!
Maybe the 415 now...
- 1
all dressed and first flight to the shelf completed
The kit decals were used and performed perfectly (with a coat of Mr. Mark setter)
Thanks to all who stopped by for a look and for those who helped and commented!
- 5
Thank you kindly!
Most of the paint work is done and some decal work is in progress, as well, I've added some wear to illustrate the "dirty bird" (A term usually associated with fried Chicken) this is.
Thanks for looking
- 4
lovely work!
love the Matrix droopy spoon meme...that's not a reference to those struts is it?🙂
- 3
very nicely done!
and very clean!!
- 1
well...wait no longer, the masking just came off (overspray mostly polished out where it happened) and beginning to move ahead with assembly again.
I painted the nacelle's two tone blue (both dark blue, one metallic) and mixed the blue with equal parts black
The tape on the bottom is to protect the finish until the wheels can be attached
Thanks for looking
- 4
Thanks for the encouragement and kind words!
A marathon of masking and the overall green is on, I'll let this set up (dry) a bit before allowing my usually impatient self from handling it too much and ending up with a thumb print in the fresh paint.
That's all I've got for now
Thanks for looking
- 5
Yaaaaaa, those struts wouldn't stand a snowballs hope in he.....(you know where) of supporting the model.
- 1
Such attention to detail and watch making skills, inspires me to try to strive to a higher level in my own work...I’ll never do it but it does inspire!
seat belt and life vest on...
- 1
I got the ugly seams dealt with and the gloss white paint touched up, I began getting the gloss dark green on where I could (no masking) I will leave the fresh gloss white another day before masking to put apply the green hull bottom, wing tips etc.
The engines with .020" solder for push rod tubes;
The fuselage, patched up and re-painted. I really need to start taking pics with my phone, the camera is much better than my Canon DSLR
The "Brunswick" green...or at least my version of it.
Thanks for looking
- 10
Thanks guys!
I was looking at reference images, the instructions call for "Brunswick green" for the green areas, and "Marine blue" for the engine nacelles. My reference pics seem to be burnt black on the engine nacelle tops and dark green below...I guess it's not the first time color call-out's have been off. I also noticed I made a mistake in using the recommended fold away underwing landing lights, the plane I'm building is supposed to have rectangular lenses in the wing leading edge with two landing lights per side (drat!) also, the plane has spinners (not included in the kit, but thankfully the scrap Twin Otter I used for parts on the one I completed are surplus. I cut off the prop hubs and drilled out the spinners to fit these props. Work continues with sanding, I found a few issues that appeared with the gloss paint on that weren't apparent previously.
The props in progress;
I've also painted the engines and have begun adding some detail to help them look a bit better, push rod tubes are being made right now. (pics later)
- 6
Thanks guys!
It is an awesome little kit!!
and great fun to build.
50 minutes ago, dnl42 said:
She looks excellent!
What scheme are you going for? My 415 is yellow with red--gloss yellow took oh so many coats.
Thanks
the decals offer an option for a white with green trim Saskatchewan C-FAFO (where I live) so it’s going to be that one.
- 1
1/72 Anigrand C-17A Globemaster III - Updated 1 March 22
in Work in Progress - Aircraft
THATS AWESOME!!
and the minute you put on the final pieces and set it in the display cabinet the Kinetic one will become available...well I’m still hoping anyway, there’s no way I could do what you’ve done to get as good a C 17 from this kit
