Sturmovik
Members
  • Posts
    2,440
  • Joined
  • Last visited
Posts posted by Sturmovik
  1. 8 hours ago, Valkyrie said:
    Great looking skyhawk. I really like the finish, and great brush paint work. I'm embarking on a bit of a Skyhawk marathon and there will be a good deal of Argentine versions including this one. Good research thread too.
    I can give you the links I´ve bookmarked if you want to, all of them are in Spanish, but the pictures speak for themself.
    1 hour ago, Simon382 said:
    Nice looking Scooter. Having been down South for work some 10 years after the conflict I just can't seem to bring myself to model an Argentine airframe, strange but a little personal for me I guess.Very nice result mind
    Same but backwards, I don´t see myself making a Harrier, and I´ve been three times in the UK.
    • Thanks 2
  2. It was nice to finally open again Revell Germany´s rectangular blue box.
    I had built this model twice in the past, both times I ended up with a mess instead of a plastic model (the second time I ended with melted plastic because I used too much glue on my weight in the nose), but this time I got a fully assembled aircraft without much trouble.
    Time has not been kind to the model, the moulds are worn, resulting in a lot of flash, particularly in the lower nose assembly.
    Instructions forget to mention to open holes for the lower antennae and the circular one over the fuselage. I was able to open the hole for the circular one, but the lower one won´t be present on this model.
    Tomorrow I´ll try to begin and finish painting it, so I can decal it the next day.
  3. @FAAMAN it´s the Hobbycraft kit in 1:48.        I had a struggle with the colours, I tried following Airfix´s colour guide, but I thought the model would end up looking like a Spitfire, so after sleeping on it for some time, I decided to use RLM 70/81/65, because it looked good to my eyes. The glossiness is because of the matt varnish.
    The A-4s lined up on this LINK look similar in colour to mine but faded, so let´s assume this was a freshly painted example        I literally had no idea about the colour of the slats (the flaps are painted in the fuselage colour), I just used RLM 02 because I didn´t want to buy red paint just for that detail. Another clue is that it doesn´t have the colours of 1986.
  4. Here are some photos of what I consider the joy of my current collection, Hobbycraft´s A-4B Skyhawk. This is my only post-WW2 jet.
    It was an easy build, I almost ruin it because I trimmed the nose landing gear, not thinking about the nose up stand the aircraft should have.
    I also managed to lose the pitot tube while handling it, so I replaced it with a bent staple glued with CA.
    The model was brushpainted with Revell colours 46, 40 and 65.
    • Like 21
  5. These three models were built when I was younger (15-17 I think), then they were thrown into the garbage because a shelf fell above them and broke them, without a repair chance. The Fw 190A-8 was specially fragile because I had swapped, once glued, its early style wheels for the late ones of Hasegawa´s newly tooled Fw 190A-5.
    Revell´s 1:32 Junkers Ju 88A-1.
    At this time I wasn´t too sure how to sand the paint ridges, so the aircraft was decaled over them. I used Scale Aircraft Conversion´s metal landing gear for this one.
    Hasegawa´s old tool 1:32 Focke Wulf Fw 190A. This was the first aircraft I tried to seriously mottle. It was also painted using bluetac as a guide for the camouflage. Academy has the same colour scheme on its 1:72 Fw 190A-8.
    Hasegawa´s 1:32 Me 163.
    The photos were uploaded to the "1:32" contest in Modeling Madness, you can find them here: https://modelingmadness.com/contests/1-32/1-32pix.htm
    I´ll try to find the photos of my old models, they´re scattered throughout many other websites.
    • Like 14
  6. Sorry for not answering before, I always arrive home too tired to open my PC and check my social media.
    Judging by everyone´s opinions, I´ll give the Airfix kit a try, I have five Fw 190s and only one Bf 109.
    On 18/4/2018 at 11:04, Artie said:
    It even gives you the chance to build Galland's personal plane, with his "custom" telescopic gunsight...don't know anything about the lighter he asked to install in the cockpit...:D
    Cheers..
    That´s the sole reason I´ll be buying it, I´ve always wanted to build Galland´s plane.
  7. Someone offered me this kit as an alternative to the more expensive Hasegawa 109E with a Galland resin body, so I wanted to know your opinions about it regarding the type of plastic, the quality of the decals, fit, and particularly the size of the sprue gates (if you had any troubles removing the parts from the sprues).
    Any comment is appreciated.
    In my effort to build the kits with as little changes as possible/effort, I´ve decided to build the A-6 as Gerhard Vivroux´s aircraft, because it doesn´t need any modifications for the lateral armour plating (White 20 was in fact an A-7 and White 1 needs to have a panel line added to the armour plating).
    The Fw 190A-8 will be built as the tiger striped mount of Ernst Schröder following Tamiya´s painting instructions.
    And last but not least, the Me 262 will be built as White 19 from Kommand Nowotny, Achmer, 1944. I´ll guide myself from a couple of black and white photos and some colour profiles found on the internet.
    The Me 262 will be built first because of its simplicity and smaller size, perfect for a 4-day holiday. It´ll also serve as a test bed for my seam filling and weight to use (when I added weights the first two times the plastic melted, totally my fault).
  9. I bought Revell´s Me 262A-1a, and I´m inclining to build the aircraft as the mount of Erich Mikat, but I have doubts about the camouflage.
    Revell´s instructions show an aircraft with high fuselage demarcation line of RLM 76 with several squiggles of RLM 81 and a splinter pattern in RLM 81/82 on top, however, Osprey Aircraft of the Aces "German Jet Aces of World War 2" show the same aircraft with a solid RLM 82 (or 83) camouflage and several RLM 76 squiggles on the fuselage.
    There´s one real life photo of the aircraft, but its too small to figure something out.
    Anything is welcome (and if I can´t convince myself, I´ll go with the second camouflage option).
