Sturmovik
Members
  • Posts
    2,440
  • Joined
  • Last visited
Posts posted by Sturmovik
  1. Made some more effort today and glued the wings and filled the speed brakes to backdate the kit to a true Meteor F.1.
    As written above, Tamiya copied the Meteor "F.1" exhibited in the RAF Museum Cosford (now in Hendon I think). As such, they added the speed brakes of the Meteor F.3, and kitted the plane as an F.1 with speed brakes. Tamiya later retooled their original kit and issued a true F.1, plus an F.3 later with the speed brakes.
  2. Looking online for the instructions of the Hasegawa Fw 190A-7 in 1:32, I can see one of the black stripes is of the same size as the engine bulge on the aircraft's side. You could measure the size of the bulge in your 1:72 kit. With the measurements of the black stripe, you will also have the correct size of the white ones.
    Hope this helps.
  3. First efforts on Tamiya's Meteor. When Tamiya first issued their Meteor F.1 in 1997, it was done after reviewing the Meteor on the RAF Museum in Hendon (London). As such, it had speedbrakes, a device that was added starting on the Meteor F.3. Because I didn't want to look lazy, I glued the speedbrakes shut and filled them with CA.
    Here you can see the fuselage and other small parts painted black. The wheels were painted steel and will have the tyres painted today.
    Here you can see the area to be filled surrounded by masking tape.
  4. I finally have the kit and the decals! Now I'll be able to start the build.
    As far as I know Tamiya tooled this kit with the wing of the Meteor F.3, which had speedbrakes, whereas the F.1 didn't. I'll glue the speedbrakes in place and then fill the recessed detail of the brakes. I'll also be filling any gaps that may appear while building the kit (unions etc...). This is going to be a first for me, because I usually don't fill gaps on my models.
    Here's the boxtop:
    The bottom of the box with the nose weight (included in the kit).
    Instructions:
    Sprues inside the bags:
    A 1:48 painting guide:
    And finally, the decals. The idea of buying this kit was to make it Argentinian from the start with a set from Aerocalcas. ID will be C-104.
  5. On 28/08/2022 at 01:45, Hoops said:
    took me a while to dig out the decals and put them next to eachothe
    One thing I can say about Aerocalcas is that they conform to the model's surface without the need of softening solutions. Calcas del Sur, though nice to work with, are impervious to softening liquids and are prone to silvering, even after being applied over a gloss base.
  6. Finished this kit yesterday. The model came with bonus resin tyres from Hasegawa, which also came with the regular plastic ones.
    I used Revell Aqua colours and several brushes to complete this aircraft.
    The original kit decals were completely unsuable, cracked beyond redemption. Luckily I was able to count from my spares box to complete this paint job.
    • Like 26
  7. 3 minutes ago, exdraken said:
    more of te Fightinghawks?
    Sadly no. C-927 was the only one attending the show.
    4 minutes ago, exdraken said:
    The historical A-4C is fantastic  by the way!
    Amazingly it's still in the original 1982 camouflage. I wonder, would it be able to fly again if properly checked and had an engine change?
  8. Earlier this month I went to the Argentina Vuela 2022 at BAM Morón. The air show lasted between 13 and 14 August of this year. There were several aircraft in exhibition, plus an air show performed by the Fuerza Aérea Argentina. Here are the photos of said show:
    Beechcraft 200 1-F-43:
    Beechcraft T-45 Mentor(s):
    Battle worn Douglas A-4C:
    Bristol 170 Mk.I LV-AYC (TC-330):
    C-130H:
    Austral Líneas Aéreas MD-81 LV-WFN (MD-81 with the most flown hours in the world):
    Avro Lincoln B-004. Currently the MNA is gathering money to carry out a restoration of the aircraft:
    S-2T Turbo Tracker 2-AS-23:
    Westland Sea King 43
    SAAB 340 TC-32:
    Beechcraft B-45 Mentors of the Escuadrilla Histórica:
    Mirage IIIEA I-007:
    Drone with the A-4AR C-927 in the background:
    Mig 15UTI LV-X216:
    EMB 314 Tucano:
