rossm
Gold Member
  • Posts
    1,906
  • Joined
  • Last visited
Posts posted by rossm
  1. 4 hours ago, BillF67 said:
    Thanks, Rossi. There are 2 shown in-line on the centre line. The third is slightly forward of these and offset to starboard. I would assume the 2 in-line are the ones you identify?
    I believe so and having looked around some more I can't find any clues for the offset one. There is a flare chute but that is to the port of the navigators entry hatch so it's not that, I can't even tell if that was fitted on all versions.
  2. On 9/10/2021 at 1:04 PM, alhenderson said:
    I *think* I have seen a picture of a 19 or 92 sqn Lightning in bare metal.  May have been a T-bird, though.  Or, I may have imagined the whole thing.. 😲  I'm still trying to get stencil decals for mine after I bought the starter kit which has a very basic decal sheet.  The Xtradecal Lightning stencil sheet has been out of stock at Hannants for at least a year 😞
    Al.
    Hannants have stock of Modeldecal sheets 78 (NMF) and 94 (Green) which give a good selection of stencils, I'm not a Lightning guru to know if they're complete.
  3. 1 hour ago, Giorgio N said:
    There is plenty of photographic evidence showing repainted sky bands on DFS finished RAF aircraft in Italy. And at the same time there is plenty of photographic evidence showing RAF aircraft retaining the sky band over the DFS finish, sometime even showing aircraft within the same unit with and without band.
    Interestingly, there are pictures of Luftwaffe and ANR aircraft in the same theatre and same years wearing the white band and others showing the band repainted or even not present from the start. Identification must have been a bit tricky in those 2 last years of the war !
    In general pictures seem to show that initially RAF aircraft tended to have the band removed, while  at the end of the war practically no Axix aircraft retained the band while RAF aircraft did,
    To add to the confusion, RAF aircraft in Southern France generally seem to have retained the band and at a certain point the boundaries of ETO and MTO became very blurred
    I may have misunderstood some of the posts - I agree with you about complete overpainting, it's the partial overpainting I wasn't sure about.
  4. 2 hours ago, Phoenix44 said:
    I'm not sure you can draw any conclusions from that photo. There's obviously a quite large line of overexposure crossing the ID band, which suggests areas either side shouldnt be trusted as its not clear why there's such an overexposure there. It  appears to be a very bright day judging from the shadows. That means areas of curvature are going to show significant variation in tone. To illustrate, compare the DG ahead of the cockpit with the DG below and to the right of the fuselage roundel or the grey of the underside of the wing from leading edge to trailing edge. And compare that leading edge with the lower cowling - but both are almost certainly the same colour but they tones are very different. Finally also look at the aircraft behind, which appears to have a standard ID band.
    I agree it's hard to draw a conclusion - the band appears to be lighter than the underside colour for a start.
    Moreover, although clearly a panchromatic film we don't know if any filter was used on the lens. It was quite common to use a red or orange filter to darken blue skies and this would affect the relative tones of colours on the aircraft as well. Some experiments I did a while back suggest a red filter makes Sky and Dull Red much the same tone, both slightly lighter than Azure Blue or MS Grey. Also the grass/scrub on the ground looks dark and you might expect it to be more like straw during an Italian summer.
    I'd be interested to see the source of the overpainted sky band being common in the MTO statement - is it true or is it an erroneous conclusion based on a misinterpretation of a monochrome photo that has been published somewhere and then repeated iin multiple places? I don't know and I would believe in it more if there was documentary evidence.
  5. On 9/4/2021 at 11:41 PM, Troy Smith said:
    I think @rossm was/is in Cornwall, or nearby.
    Sorry to hear of this. I was in Cornwall, now in Devon. There was a trader - T7 models - in Truro but he closed down a couple of years back. There used to be someone trading secondhand kits in Plymouth market on Fridays & Saturdays but I haven't looked in since the pandemic hit. Even so, that's not particularly handy for Helston. There is a club in West Cornwall https://sites.google.com/site/cornishscalemodellers/home
    I guess you'll be travelling down the A30 but if you prefer the A38 then I can let you have some packing boxes left over from my move if you need them.
    There are traders other than Kingkit who deal in secondhand kits, I can recommend them and https://www.modelsforsale.com/  based on purchases, I've not used either of them for selling off kits. There are others like Plastic Pastimes, Kit Krazy............and others who usually advertise in modelling magazines and Aeroplane  etc. who might be worth contacting if they happen to be in a convenient location for you.
  6. 6 hours ago, Dave Swindell said:
    There were 3 sizes of tanks as you say, but the question isn't about the tanks, it's asking about the mounting bracket which as far as I know was the same for all 3 sizes.
    Er, yes, I was being dim, sorry :oops:
    Do these help?
  7. On 8/28/2021 at 8:20 AM, rossm said:
    There was an article on Intruder Hurricanes in Model Aircraft Monthly Jan 2008 which gives more detail of the trials, including the note that 12 Group ran their own trials independently of the Fighter Command ones. No mention of Bostons though.
    Having now seen that photo - just to muddy the waters - the Fighter Command trials mentioned in the article found Dark Green and Dark Earth gave the best results! The article does say it was decided not to use this scheme though and Beaufighters seem to have been the aircraft used for the trials.
  8. There was an article on Intruder Hurricanes in Model Aircraft Monthly Jan 2008 which gives more detail of the trials, including the note that 12 Group ran their own trials independently of the Fighter Command ones. No mention of Bostons though.
  9. "Silver Wings" says "The Fury's airframe was similar to that of the Hornet but had been modified and slightly strengthened in places. The radiator area was greater.........."
    Looking at photos again the Hornet cowling is slightly different with the panel line for the upper part below the exhausts as opposed to above them for the Fury.
  10. Airfix error is my gain as I want to build a TT35 of 3CAACU. I have an Aeroclub ML winch but need to know the exact location on the bomb bay. Also I think I need the buffer unit - a sprung pole with a triangular support - but I don't know the dimensions for that. I don't know if there's anything else.
    Please can anyone fill in the gaps?
  11. Ducimus Camouflage & Markings for the Blenheim suggests RO-X of 29 Squadron had sky undersides in a photo caption and the port underside is definitely pale.
    Paul Lucas "Battle for Britain" has colour profile drawings of BQ-O from 600 sqdn and L8740 NG-Q both dated July 1940 with Sky undersides. I think I've seen photos of both but it's not easy to tell the difference between White and Sky in fuzzy period photos and both were starboard side photos so the Sky is probable from the date but not confirmed by a photo.
    Graham Warner list a number of Fighter Command losses in July-September 1940, all bar one were Mk.If - don't know how many were all black though.
