Posts posted by Bullbasket
You're making a really good job of this so far, but there again, it's what I expect of you. Great work Ed.
John.
- 1
13 hours ago, echen said:
The PE was fiddley so far but I have yet to fold and fit the PE birdcage gunsight and the antenna frame - which I'm not really looking forward to.
Good luck with that. It was bad enough doing it in 1/35th scale. It's looking really good though.
John.
12 hours ago, Hamden said:
More and more detail of extremely high standards being added making this into a superb replica.
Bar most definitely raised!
Stay safe Roger
Very nice of you to say so Roger. Thanks a lot.
John.
7 hours ago, John Tapsell said:
You know John - this is all your fault
Glad to have been of some use John. I've actually got the 3" gun conversion, but never got around to using it.
John.
Approximately the first 450 T23 turrets manufactured, were made without a rear ventilator, and if the Sherman Minutia page has it right, this was down to an oversight on behalf of the manufacturers. They were also made with an additional antenna point on the front LHS of the turret and a 2 inch bomb thrower. The tank which I'm building had such a turret, but for some reason, although this is the turret which Dragon provide in their Cobra kit, it is equipped with a ventilator (which I've already taken care of). Fortunately, Dragon have depicted the turret with the antenna base and the bomb thrower hole, which they've shown as if it has been welded closed.
Just in front of the additional aerial is the two inch bomb thrower hole. As I said, Dragon have depicted this as being welded closed, but I wanted to show it as still being there, so a small circle was cut from the end of a piece of stretched sprue and glued in place where the opening would be. A small length of etched brass chain was then bent to shape and super glued in place as a retaining chain.
The base for the additional aerial was missing from the kit, so I had to make a new one. The return rollers of a VVSS unit are the exact diameter of the hole in the turret. So using a razor saw, I cut off a thin circle and once cleaned up, it was glued into place. I smeared some putty over the top, and when it had hardened, it was blended into the roof of the turret. I bent a piece of scrap etched brass into an inverted U shape. To the underside I glued a small piece of tubing, and into that I inserted a piece of .31mm nickel silver wire. I drilled a hole into the roof of the turret, and then the whole lot was super glued into place over the aerial base. On the top I glued an aerial base from the kit.
Another item that was missing was the additional “lifting ring”, just in front of the loader's hatch. This was a left over from the T23 days and was not a lifting ring as such, but a support for the boom, used to lift the power pack. Fortunately, there was one in the Meng M4A3 kit.
This turret is taking me longer than I anticipated, but it's all good fun. I'll be back when I have some more progress.
Thanks for looking.
John.
- 12
Not one that I've come across before. You've made an excellent job of it Pete. Nice and dusty.
John.
Hi
in New Members
You're about to receive a terse reply from one of the mods because you haven't read the pinned title. This is for introducing yourself. Nothing more, nothing less.
John.
- 1
In the past, I've built models for which there are no decals, and the way that I've got around that was to contact Pedinghaus decals, and they printed them for me. I had to provide either photos or profiles of the actual tank and then they printed them. Not expensive either. If I remember correctly, they charged me 15 euros for s sheet of decals for RMASG Centaur in 1/48th scale.
John.
- 1
This is certainly moving along at a fair old pace now. I like the work with the wiring. Very nice Simon.
John.
- 1
54 minutes ago, Keeff said:
Wow ..... just WOW! 😲
I can't believe the detail you're adding here John ....it's superb! 👌
Keith 😁
That's very nice of you to say Keith. It's much appreciated.
John.
- 1
Many thanks Ed. I only get a couple of hours in the modelling room, due to being chief cook and bottle washer, but in all, those brackets took about five or six sessions to get them done. And I'm relieved that they're finished. Comparing them with a photo that I have of the real thing, I'm fairly happy with them.
John.
- 1
12 minutes ago, edjbartos said:
That looks smashing John, very nicely done, super paintwork and very nice additions too. well done...
Ed
'Morning Ed, and thank you very much. Yes, as old as it is, it's still a good kit and can hold it's own against the Airfix and SKP offerings.
John.
- 1
1 hour ago, Retired Bob said:
.Now you can join the fun in the Tiger STGB.
And I was just beginning to like you Bob. I'll build a Tiger when the Pope gets married!
Thanks for the comments Bob.
John.
- 2
It just goes to show that you've had these modelling skills for a long time. Nice one Milan.
John.
31 minutes ago, Jasper dog said:
Very nice John, really really good.
Glad to see the top secret velcro rope is still holding on. 😉
The simple base really enhances it too. As does the photography, I rather like the black background, sets it off very nicely.
Great work
Darryl
Thanks a lot Darryl. It was either velcro or a liberal dollop of PVA glue.
John.
- 2
14 hours ago, Valenstitch said:
Not bad, not bad at all, in fact it`s rather good, it`s that good it`s stirred my Mojo, like a slop jockeys ladle in a "Norgie" of range stew!
Granto
Hi Granto. Glad to see you putting your head above the parapet,and I hope that it does get you building again.
Many thanks mate.
John.
- 1
15 hours ago, Stef N. said:
A cracking update/revamp. Very nice work John.👍👍👍
14 hours ago, Milan Mynar said:Excellent work.
14 hours ago, Keeff said:Well thats very nice .... it's turned out great! 👌
Keith 😁
Thanks to all three of you for the comments, and I'm glad that you liked it.
John.
16 hours ago, IanC said:
Nice work indeed. Those pots and pans hanging on the back remind me of a real photo from the NW Europe campaign. And the improved smoke dischargers look good too.
I may have the same photo. It's of a couple of Cromwells disabled by mines.
Many thanks Ian.
John.
14 hours ago, Hamden said:
Great work around the mantlet John.
Stay safe Roger
31 minutes ago, Jasper dog said:Looking good John, super attention to detail!
Atb
Darryl
Thanks to both of you. I appreciate it.
John.
25 minutes ago, edjbartos said:
I've always been a fan of their box art, It's probably what attracted me to their kits in the first place...
That's basically what it's supposed to do, and what Airfix failed to realise when they started putting photos of completed models on their boxes. At least they've got the message now.
I must say that multi part hulls, if well engineered, can give you a really squared hull, as opposed to some one piece one, where the sides slope inwards. Good start Ed and I'll definitely be watching this build. On you go.
John.
- 1
- 1
I'm looking forward to the masking tape coming off. Should look really good. Nice work Roger.
John.
- 1
I've even got an account with them! I assumed that because Panzerart were in an EU country, the P&P wouldn't be so high. How wrong I was. Anyway, too late now as I've ordered the Italeri Mk.ll from JadarHobbies. You live and learn. Well, some do.
Thanks for your help Jack.
John.
Welcome aboard Jeff. Enjoy your time here and most of all, enjoy your modelling.
John.
- 1
Vickers Light Tank VIB (Vulcan 1:35) ***Finished***
in Work in Progress - Armour
It's all looking good Simon, especially Tea Pot Tom. I take it that the tea was made the traditional way, ie; with condensed milk?
John.
