Antoine
Members
  • Posts
    5,652
  • Joined
  • Last visited
Posts posted by Antoine
  1. I've added the missing front light, after a quick mod to figure a broken glass. I'll try to add some wires later.
    It's primer time, and I choose a rottbraun acrylic-polyurethane from Vallejo.
    Perfect to make a difference with the light gray of the sprues, and the final colour of Kure arsenal gray (kind of German grey), as indicated by Tamiya. And beside, I've one bottle in my primer collection!
  2. The build is really straightforward, and take about a single day.
    I've decided for three sub-assembly, that is the hull, the dozer blade and the tracks.
    Here's the hull, nearly finished.
    I'll spare the seat for the end, to ease the paint job.
    I've got small mods to do with the front lights, too.
    But I won't go into extensive modifications or detailling, as I'm poor on documentation.
  3. Hi there!
    As a lot of us, I've started 2020  with a full bag of good resolutions, and among thoses, trying to finish one (or more) build.
    After a quick glance at more than a dozen false starts from the last decade, I've decided to go for a fresh kit.
    My choice? The unexpected Komatsu G40 from Tamiya, released a few years ago, a very very nice little 1/48 kit, perfect for a little vignette together with an aircraft. And this is exactly what I plan to do, but let's concentrate on the bull only for the moment.
    Let me take you on a quick visit inside the box.
    Starting with the sprues. There are two, if I'm not wrong.
    :smartass:
    Instruction sheet.
    Only one camo option.
    The decals.
    All those stencils...
    A handfull of metalic dry transferts.
    And... that's all!!!
    :penguin:
  4. On 5/11/2019 at 9:11 AM, Antoine said:
    Proud mom
    Remember?
    Five kitten, a male and four female.
    I'd gave one to my sister, and kept the other four.
    So here's black & white Tomcat, with one of his sister, Blue, both checking the comfort of my Windstopper jacket!
  5. 13 hours ago, Mike said:
    From the size of the stars and bars I'd suggest 1:72?  They're 1.8cm wide from one end of bar to the other.  A shade under 1cm tall. :)
    In cm, whow!!!!
    Appreciate that.
    Any pics together with any of your lattest build? So that we can have a clue about the size (I know, size didn't matter, but...).
  6. Thanks Mike
    Funny, As these days, I was wondering how a "kit" like that would look like, due to an Egg GB happening right now on a French forum.
    Got my answer, and you know what? I might have a go at it!.
    By the way, I suppose that there is no aftermarket for this, no decals ?
    Which scale would suit them best? 1/48 maybe?
  7. They're five, born on the 9th, the first one at about 9:00 PM, with the rest following at the rate of one every 30mn.
    All are in good shape, I even witnessed a kick boxing session, two of them fighting for the same tit.
  8. Hi Larry,
    I've heard that there's also a lenght issue with the tanks.
    Can check if you like.
    About the paint, if you did check the link, you've seen that the Etendard did get at least two schemes in its early life, the one with EDSG being the first. So make your choice.
    This one is also cool.
    And as Sikkens is still in existence, you can even contact them about 59278, they might send you a sample!
    Quote
    -Revêtement Supérieur :
    Gris bleu clair brillant (Sikkens/ Astral 59278)
    -Revêtement Inférieur :
    Blanc brillant
    As usual with French paints, it's difficult to find the equivalent FS, and each modeller over here will make his own kitchen.
    You just have to do the same!
  9. So, everything seems to be already set?
    A few points, if you don't mind.
    5 hours ago, ReccePhreak said:
    I think we are pretty much set on using modified/corrected fuel tanks from the kit on the middle pylons, and a 68mm rocket pod on each outboard pylon.
    It would be nice to have something on the inboard pylons, as long as it was used operationally.
    There's no such thing as a middle pylon, as each wing has only two points. I'll try to find and check the instructions, as I suspect a mix-up from KH
    with the Super Etendard.
    - Inboard, to be set either with an Alkan 504 for heavy load (fuel tank), or Alkan 257 for lighter load (bombs up to 250kg/500lb)
    - Outboard use Alkan 257 only.
    For your choice, neither fuel tank nor LR Matra 150 for 18 SNEB 68mm rocket need an adapter to fit under the Alkans
    6 hours ago, ReccePhreak said:
    The only store for the centerline pylon is the Douglas Refueling Pod. I don't know if an armed jet would be carrying one of those into combat, unless it was also carrying some AAMs.
    As you know, the refueling pod is a Douglas D-827-A, replaced in the early 80's by a Intertechnique D-827-B (under licence).
    Honnestly, I don't know the difference...
    All the IVP (and PM) can play tanker, but for the IVM, you start from n°51, plus n°5 as it was used for trials.
    Also, there's a need to have the IVM fitted with the "chassis engin" to carry the Douglas pod. "Chassis engin" is used with A/G missiles and contain all the wiring and switchology needed for AS20/30. In this case, and so for aerial refueling, the aircraft carry no guns, as they come with the "chassis canon", which is more common, and used for A/G work with bombs and rockets.
    Beside, the IV is a bit short-legged, so there's no room for AAM or bombs or rockets when the pod is present. Fuel tanks and that's all.
    On 4/27/2019 at 4:49 AM, ReccePhreak said:
    Since I doubt the Sidewinder was a common fit
    11 hours ago, Des said:
    AIM-9 Sidewinder but not specified whether inboard or outboard
    Sidewinder WAS a common fit. Outboard pylon only, Alkan 257 with an Aero adapter.
  10. I've got the big Bible in two volume for the Etendard, and with this I'll be able to answer all of your questions (hopefully).
    But.
    Do you want to read about ALL the weapons cleared for use with both aircrafts? That will be a huge list.
    Or do you want to know about those found in the kit's boxes? If so, I'll try to find a picture of the sprues.
    Maybe you're interested by the aftermarket option?
    Please tell me, so that we can reduce the scope of our search.
    About the AIM-9, it's still an option to me, it's just that the aircraft never used it in combat.
  11. 9 hours ago, ReccePhreak said:
    Unfortunately, I have not found any photos of the Etendard IVM carrying the Barracuda or Phimat.
    For sure, as the IVM was no longer in service when they were first delivered to the Aéronavale
  12. Hi guys,
    Just a few words to let you know I'm out of this.
    I've to admit that I haven't glued a single part so far, and for this I've a truck load of bad excuses you don't want to hear about.
    Whatever, the fact is that I just can't build anything at the moment.
    I know the mojo will come back, the question is: When?
    • Sad 1
