Circloy
Gold Member
  • Posts
    312
  • Joined
  • Last visited
Posts posted by Circloy
  1. 1 hour ago, RobL said:
    You're talking nearly 3ft long with a Phantom...
    Around the size of a 1/72 Concorde & how many of those do you see built?
    If you were to look to Airfix to do a 1/24th jet the selection criteria would probably be  British, WWii (if possible), Small, Iconic/Milestone, Popular.
    British, WWii & Milestone                         Meteor,
    WWii & Milestone                                     Me262
    British, Small, Iconic/Milestone, Popular   Harriers (revisited)
    British, Small, Popular                                EE Lightning, Gnat, Hawk (last two as #iainpeden said have the added popularity by virtue of the links with the Red Arrows)
    & as rank outsiders                                    NA Sabre MIG 15
    Anything bigger you'd probably not be able to manhandle, have room to display, or be able to reasonably afford.
  2. 7 hours ago, zigster said:
    probably due to a large stock of that paint in stock, with - that's what you wanted
    Doubt there would be large stocks of paint in stock. Supply difficulties & high demand more probably resulted in a situation more like today's Just In Time philosophy and that stocks were limited. Delay's in applicaton would be a result of lengthy & slow supply chains.
  3. If you're only using it as a straight edge for cutting you could do what I've done & use a length of Aluminium 'T' section. (approx 20 x 25 mm & 1 m long)
    Attach a length of 'Wet & Dry'/Emery paper to the flat with double sided tape to make it none slip.
    T section makes it virtually inflexible.
    It has proven sufficiently resistant to damage when cutting with a scalpel, the upright protects the finger tips from acidental slicing.
    The length and abrasive also caters for flattening large areas or filing long straights.
  4. I can also recomend the really usefulbox range and rarely use anything else for general storage.
    Try Gemini Storage Solutions - they do (did)  many shows and I understand do mail order too. Pricing at shows is extreamly competetive.
    www.facebook.com/geministoragesolutions
    No connection except a very satisfied customer
  5. Ulikely to get custom sizes as they're generally injecton molded.
    In the past I've seen some of the display cabinet makers (picture pride etc) offer acrylic display covers.
  6. 4 hours ago, RobL said:
    RAM doesn't generally "burn out" or degrade over time, but you never know.
    Recently defraged a couple of hard drives, came to the SSD (Solid State Device) and was warned that to continue could cause the drive to fail  so maybe electronic memory does have a life span.
  7. 2 minutes ago, pigsty said:
    If that’s the case you should have a word with your seller, because models and bits for models aren’t supposed to be liable for duty, only VAT.
    It's the importer, or apointed agent, that is legally responsible for ensuring the correct code is used not the seller.
  8. 5 minutes ago, Noel Smith said:
    I can remember there being a plastic kit available of the  Mk 1 Transit back in the 80's.  I think maybe ESCI or Italeri may have made this kit as a Ford Promo.
    The current Italeri kit is straight from the Esci moulds - a Mk 2.
    I probably built 3
           Standard (except for driver side load door converted to panel), Long wheel base using 2 rear sections (twin rear wheels, extended wheel arches & split read doors), & box van from spare cab.
    Still have a couple of originals still stashed pending conversions - 1 for a tipper & one to be decided upon.
    Had plans to back one date 1 to a mk1 - can't be sure how far that got.
    Still have the Transit promotional brochure for the Mk.2 available somewhere.
  9. With older well used tins it's usually a build up of dried paint, with new tins I've put it down to larger lids /smaller openings.
    In the factory lids are fitted by machine so will be applying some pressure, I've taken to tapping lightly with a small hammer.
  10. Technically the AEC Regent III was a running chassis offered by AEC upon which varous companies (Park Royal, Cravens, Roe, Wemann ...) built their own style of body. The nearest style to that of the Routemaster (RM) was the London Transport RT which was a Park Royal body on the AEC Chassis which as Park Royal built the RM body is not surprising.
    There are however substantial differences in the body, for example the front upper deck rakes back more on the RT than the RM which affects the first upper window and more importantly the front dome. And of course Revell models the extended version of the RM so a section requires removal to represent an RT.
    If you want to model a Regent III that is representative of one operated by one of the municipalities then it would be debateable about how much of the body could be used.
    I don't want to put you especially as its something I've too considered doing If I lay my hands on a cheap offering
    Best starting point would be to find suitable drawings which are available on the internet
    https://www.the-blueprints.com/blueprints/buses/various-buses/40287/view/aec_regal_iii_red_bus_double_decker/
    https://drawingdatabase.com/aec-routemaster-london-bus/
    https://www.bing.com/images/search?view=detailV2&id=8B34D7252ADE36EA91979A138B0B695901B9C81B&thid=OIP.oTkydnwS5VRaoltP-FMwhAHaES&exph=742&expw=1280&q=AEC+bus+Blueprint&selectedindex=2&qft=+filterui%3acolor2-bw+filterui%3aimagesize-large&vt=0&eim=0,1,2,3,4,6,8,10
    https://www.flickriver.com/photos/23875695@N06/tags/plans/
    Low height version
    https://timebus.co.uk/rlh/diagrams/index.htm
  11. Few on the historex site to look at  - No connection & links only direct you to the home page due to site software so you will have to 'find' (not search)
    1/35th NEMROD (N35-035 )
    1/35th RESICAST (R355578)
    1/35th RESICAST (R355634)
    1/35th ROMEO MODELS (RMWW005)
    1/35th SOVEREIGN 2000 (S2KW005)
    Found this fellow in the stash who looks like he's trying to impress http://www.bestsoldiers.com/gallery_dougsoriginal/DO__35006_135_Scottish Officer.jpg
    Probably many others that could be addapted
  12. Many is the time i've put stuff in the pile of storage cluttering up the work area where it's resided for months, sometime years, until that one moment it's required when it's suddenly nowhere to be found, only to turn up again, where I thought it was originally, after a replacement or alternative has been sourced.
    I put it dow to ghosts.
    :ghost:
