Malc2
Members
  • Posts
    707
  • Joined
  • Last visited
Posts posted by Malc2
  1. Hi,
    Great to see you post this up, I saw your post on Silvers thread and look forward to your progress.
    For the throttle linkage I would use small scraps of Evergreen or Slaters plastic card and plastic rod which come in a wide variety of thicknesses and diameters.
    Alternatively Albion Alloys sell a variety of micro metal tubes, the advantage is they are sized to fit inside each other as the diameters reduce.
    Solder wire and copper electric cable core is also cheap and easy to get in a wide variety of diameters and can be wound round drill bits to make springs.
    Hope all this helps!
    Malc.
  2. So where was I, oh yes the front…….
    From the top:-
    Brake calliper and wheel nut/spindle
    Embryo new spring (because kit springs are like biro springs) and kit damper
    In/on the lower wishbone - home made PE bracket for lower shocker mount, pin for roll bar link
    New driveshafts, because - white metal, poor fit and round bits not round
    Original driveshaft
    Holes drilled in body to take wishbones and driveshaft. The steering rack and roll bar holes still to be made.
    The ever evolving jig now with shims to hold the front lower wishbone at ride height.
    It aint pretty but it does the job
    With that little lot in place and the car at the correct ride height, oh surprise quelle surprise the damper don’t fit, this time its too long.
    Wheel centre close enough – you can just about see here that the hole in the middle of the wheel is, well, not in the middle of the wheel, I see this as an advantage as I can rotate the wheel in the event of a three legged stool event occurring after final assembly. As long as we can keep that between all of us kids here, no one will ever spot it.
    Rolled aside
    Next is the roll bar, it has to squeeze below the upper wishbone and above the driveshaft, so about 0.5mm each side clearance – no pressure then.
    This is what the kit provides. Surprisingly the drop links are exactly the right length but the upper eye is too small to go over the roll bar, so replacements will be scratched.
    In position - albeit should be under the body, so it’s a bit short.
    No matter - plenty spare to be had from a MK1 rear rollbar of which several iterations were made, this one was not wide enough.
    The Ace kit instructions were suitably vague about the position of the calliper round the brake disc, according to the Hiro instructions the brake callipers are on the rear of the disks.
    First up the calliper did not fit fully over the disk
    A bit of filing the internal surfaces sorted that
    Next the calliper did not fit the intended position either way round, this is how I thought it was going to go
    Flipped over it looks more promising, but still fouls the body and pushes on the disc
    You can’t really see it here, but the corner radii need removing to allow the calliper to fit
    Removed, coincidentally now mirroring the actual car…..
    That along with removing the unwanted spigot and hey presto, much better
    The front dampers and springs were shortened to fit
    All parts test fit in place
    New roll bar links were made, the eyes were made by squishing the end of the rod with a pair of pliers and adding a couple of small pieces of card each side, sanding it round, then drilling a hole through all 3 pieces.
    Finished roll bar link in place. The upper rear wishbone mount was shaped to be more accurate, I also realised I had glued the lower damper mount 90deg out, luckily having used superglue it could be just pinged off (technical term) and re glued.
    Which completes the front suspension, just some final polishing to remove file marks and the parts will be ready for paint. Lots  of subtle bending of the upper and lower W/bones had to be done to get it all to fit properly.
    The brake duct exits were made from litho plate to replace the REALLY thick kit parts, the tabs fit in the duct hole and give something to glue to the body rather than just the edge, fortuitously the radius on the edge of my model knife handle was perfect to form the ducts around.
    Test fit - looks good compared to kit part.
    Second part made and dry fit
    Thanks for looking,
    Comments welcome!
    Malc.
    • Like 11
  3. Hi Jörgen, this is great - as usual!
    I appreciate the time you take to choreograph your photos with a clean and tidy background, having tried to do the same I know the effort it takes.
    What did you use to fill the rear axle opening? Most fillers I have are too soft to create a durable edge like this.
    Looking forward to the next instalment when you get your 3D parts from the printer.
    Malc.
  4. Greetings all, next update.
    Now that the whole of the rear drive train was located together positively in the jig, and the height of the rear upright centres established, I could make the roll bar link, the top connection is made from more 5thou litho plate.
    Having done that, the dampers were next, and came up a bit short, the top should locate on the pin projecting from the roll bar mount
    Same, from a different angle
    Using the kit top and bottom, new middles were made from brass and plastic tube.
    Complete with new 0.6mm dia wire copper springs, the collar at the top was a late addition to locate the top of the spring concentrically with the top mount
    Continuing towards the back, the exhaust mount was PE, it lacked a bit of 3Dness and the hole for the exhaust does not reflect the original bracket, so using more 1mm copper wire and a strip of PE brass cut from the edge of the fret a new one was fabbed up.
    PE part as template and a forest of pins holding the parts ready for soldering.
    After filing a location groove in the bottom of the gearbox and receiving holes in the upper casing,
    Voi et La
    With end casing temporarily in place
    And with end end casing in place - scratched as I lost the kit part – bloomin' carpet monster again, it got it somewhere between 2005 and now.
    image upload
    First trial with exhaust bits, after some tweaking to fit and a lot of sanding to remove mould lines and improve the shape, looks promising as a start.
    So now the rear is pretty much complete, Well – apart from some additional struttery that connects the roll bar mounts to engine block and head, which I will leave until the main parts are painted and glued in place, otherwise its all just too fiddly chasing parts round the bench as they roll off to be consumed by the carpet monster or sping off in to oblivion.
    Thanks for looking, comments welcome!
    Malc.
  5. Hi Ian,
    You ask a good question, I believe that on Blower Bentleys the pump outlet you are asking about is either blocked off, or the pump had a single outlet on the right hand side. I have yet to find a picture of a blower with this pipe connected to anything.
    However, some models did use this outlet as here which goes to the thermostat housing as mentioned by CMathewbacon above:-
    I have one other pic showing that the pipe you mention is not used and blocked off, I realise the image below is not conclusive as the engine is in pieces and so could have been blocked off as part of the strip down.
    Hope these help, and I look forward to hearing your replies from Bentley!
    Malc.
    PS, does this mean you are resurrecting your Bentley build😀?
  6. Those seats have come out really well, great job!
    Agree on the ign wires, real HT leads are between 8 and 10mm diameter, so in 1/24 should be between 0.3 and 0.4mm.
    You may be lucky and find some copper wire in electric cable that is the right diameter, or your local Hobbycraft centre may have some fine aluminium wire in the jewellery section the right diameter?
    If you know a BT engineer, or find one doing some work at an exchange box on the pavement (as you do.....) they use pretty fine wire in a multitude of colours.
    M.
  7. So Guten Tag meine Leiblings, lets get caught up some more.
    The sides of the body by the radiator were further refined to lower the join between body and rear floor
    Floor in place, it looks like a gap at the front, but its filled with superglue.
    To provide a positive and repeatable location for the engine, a pin was added to the body, matching an existing hole in the front of the engine. Much marking out and procrastinating over the height of the engine ensued, as it became clear that there is not enough room for the engine under the body if the sump is flush with the underside of the tub. I removed as much of the body as I dared, but still had to sand a bit off the valve covers to get it all to fit. Once it is all together you can’t see the top of the engine, so I’m not going to worry about it too much - curbside!
    The rear bulkhead evolved again to make it flat across the entire width providing more robust mounting points for the 4 trailing arms. Cut outs for the cam cover mounts were made preventing the engine rotating round the locating pin.
    Apart
    Together
    The gearbox also had the same treatment, it was filled with Milliput and a pin pushed in while it was soft. When hard the procedure repeated on the engine side, the pin being removed while the filler was soft. Reassembly when it was all hard showed we were in the ball park.
    A shim was added to the trans flange to correct an angular misalignment in the casting. The pin is still removable from the trans so it can be easily sanded across the whole face to get the correct alignment.
    Now the whole lot could be positively dry fit without rolling all over the bench every time I breathed out. The trailing arms were bent to shape and located in the body, this is not strictly correct as the top arms should locate to a bracket on the cam cover and the lower ones on the main roll hoop, but again as it can hardly be seen when assembled, life span and all that.
    The aim of all this is to get the rear wing positioned in the right place relative to the body, and the struttery made to join the two.
    So bring on another jig. Some graph paper was pritt stuck (other glues available) to the lid of the now redundant Lotus 101 box, and after several rounds of measuring and cutting, various bits of balsa were stuck down to locate the body, engine and trans at the correct ride height and square to the centre line. The one bit of truly useful info on the kit destructions are the dimensions to the underside of the body to set the front and rear body height.
    No body
    Some body
    Starting to look like an 006 – just look at those mahoosive rear tyres. The point of adding the wheel/tyre assembly was to establish the height of the hub carriers which is fixed by the wheel centre height, so then the lengths of the shocks and roll bar links could be accurately worked out.
    At this point I became aware that some clown had stuck the rear triangular fairing on far too low, (remember I mentioned this at the beginning?) so muttering curses at past me for not paying attention, I carefully cut it off and reglued it to follow the top line of the intake box.
    This then meant that the lower edge of the triangular fairing was too high, so several layers of Milliput were
    added and faired in. It should also have slightly concave sides and a thinner spine, so I ground the
    back of an old model knife blade to a slight curve and scraped the sides until I got a much more svelte looking rear fairing.
    Removing just a little to go from convex to concave makes a big change to the appearance of the fairing
    Surface looks quite scored after scraping away the excess
    But providing it has been done evenly, a few swipes with sandpaper gives a smooth surface, the colour change in the filler is old Milliput (bought circa 1995) Vs new (2019) Milliput, (my second ever box of Millput, I’m not their best customer….) the new is much softer out of the packet so easier to mix, it seems about the same hardness when set.
    After much trial and error and checking period photos, the rear wing position was established and fixed with suitably positioned pillars of balsa. Much care was taken to ensure wing to body squareness and parallelosity, after much studying of period photos, the bottom edge of the rear wing end plates appears to be on about the same plane and at the same angle as the top surface of the body.
    Once this was done the rear wing support could be scratched - the white metal kit parts were not worth bothering with.
    While I had the filler out for the rear fairing I added some to the tips of the front wheel fairings to extend them backwards and give a slight radius following the curve of the front tyre.
    Finished wing support
    On its own with errant pin for location to the gearbox. The barely visible litho plate brackets at the bottom right are for the wing end plate stay.
    Coupla gratuitous shots of the body as it currently is
    Full side
    Front fairing tip additions
    And the underside of the body showing the additions and mods to date
    (Nearly) Original
    Now
    Thanks for looking,
    Malc.
    • Like 9
  8. On 2/27/2021 at 8:11 AM, silver911 said:
    Another classic build in the making Malc...and a favourite of mine too :)
    Ron
    Thanks Ron
    On 2/27/2021 at 8:58 AM, Bengalensis said:
    Very nice work!
    Cheers Jörgen
    On 2/27/2021 at 12:33 PM, Stu_davros said:
    Awesome work, your rear wing looks 100% better than the kit parts.
    I have a number of ACE kits and they need a lot of work, particularly the white metal parts so I can see the work you have put in just to make them useable is amazing.
    I look forward to your progress, it may inspire me to break out my Brabham BT45C.
    Stuart
    A BT45C would be great to see, so when do you start!?😀
    Malc.
  9. I bought this model when it was first released in 2005 as it is pretty much my favourite F1 car of all time, short and stubby with pugnacious looks and in conjunction with the great Jackie Stewart bagged the 1973 drivers world championship which marked the end of his career.
    Needless to say I started the kit as soon as it arrived, but being a bit disappointed by the fidelity of the castings, it was almost as quickly put aside in lieu of a Tamiya BT46.
    In the meantime MFH released their 006 in 1/20 and 1/12 scale, the instructions proving very useful in discovering hidden details, and if you can afford them, MFH are far superior. But where is the fun in that??!!
    I better get a move on as Ebbro keep threatening to release their 1/20 005 and 006, it will be interesting to compare the two and you can be sure it will be released just before I finish this one…
    So it languished in its box until the Lotus 101 was almost complete, and while I was waiting for filler/glue/paint to dry I got it down from the SOD and poked the bits around, and got inspired – at least for a bit.
    So this is what you get in the box. The PE is great, nice wing end plates, seat belt ends, radiator screen and vented disks. The kit represents Stewarts pole position and win at Monaco in 1973. This was also the first F1 race for a certain James Hunt.
    Unusually for a resin kit the main castings were almost totally bubble free, but as we all know they will be lurking under the surface to be revealed just as soon as the modifying starts. The proportions look good, but the bad bits are blurred detail, very thick edges where they should be waffer thin and the interior only bears a passing resemblance to the real car – which to be fair is the same as all the interiors of the resin F1 kits I have come across.
    However there is one area that really lets the kit down and that’s the instructions – down right misleading and or vague in important areas. You really need good ref photos for this.
    However, challenge accepted and nothing a bit of sandpaper, plastic card and filler can’t fix
    Apparently…..
    Apart from the tyres, one rear had a crack and kudos to the kit supplier, a complete replacement set was despatched promptly without question and at no cost.
    The part I started way back in 2005 was the rear wing, which suffered from some serious mould collapse, the photo makes it look better than it is.
    So I set to and made a replacement from plastic card, a drawing was prepared, prob a bit OTT, but just because……
    Part cut
    And with a bit of boiling water, a suitable diameter pen, clothes pegs and some glue, the wing was folded over and the reflex fixed in.
    I made the wing from 20thou plastic card which turned out to be too thin and flexible. The filler flaked off when I was sanding it, even though I scored the plastic to provide a key. For plastic card this thin what is really needed is a solid balsa core a la Harry Woodman. So as I was living abroad at the time and had limited access to raw materials, it got put back in its box.
    And so it sat on the shelf of doom - until now.
    I pulled out the original cast rear wing and made a new one from Ureol, (a grainless easy to sand composite used for pattern making) cut the support slots on the underside, added the PE end plates and flow straighteners, added a coat of primer and Bobs your neighbour – or something like that.
    I primed the wing first just to see how the paint took (not great – had to go round again), then added the PE and primed again.
    2nd coat of Primer
    Howie held it while spraying
    Buoyed by that easy win, I perused the other kit parts, and picked out the three piece rear roll bar as the next candidate for a makeover. The manufacturer appeared to think that the ends could be butt jointed to the main piece, I didn’t think this would work very well.
    Original
    So break out some 1mm electric cable relieved of its plastic overcoat (core straightened by rolling on a flat table under a block of wood – don’t do it on your best dining table), a few pieces of plastic card suitably massaged to the required shape, tack the engine and trans together, add some 0.5mm steel pins to the gearbox casing to hold the roll bar support in place, a quick look at some ref matl and Robert is your moms brother.
    At the same time I drilled the rear uprights to accept more 1mm copper wire as radius arms. Tried and failed to turn one driveshaft on the lathe to restore its roundness, - the tool tip dug in and twisted the shaft off the inboard joint, so I had to make a replacement shaft and outboard joint, then drill the upright to accept it and repeat selected highlights for the other side. The top links were drilled and fit, they govern the camber angle by sliding the inboard end mountings in and out along the roll bar support.
    Just for fun I added some detail to the bottom of the transverse links, copying the part from a Tamiya P34
    The rear uprights were milliputted (is that even a word?) about 3mm wider to match the width of the transverse link
    Meanwhile I spent a LOT of time refining the body. The cockpit side strakes (which were to prevent the hot air from the radiator outlets in the nose cooking the driver) were sanded to the correct triangular profile from the as cast square shape. All the body edges were thinned to about 0.5mm from the 3 to 5mm as cast. Panel lines were straightened and refined, the body sides straightened and edges sharpened up.
    The white metal engine intake opening was drilled out and it plus the rear fairing were superglued to the body and the whole lot given a couple of coats of primer. Two things to note here, the rear fairing is too low (oops) and the top of the seat is part of the main body casting. Despite washing in soapy water, several fisheyes appeared, the trick is to let the paint fully dry, sand, and lightly mist over again two or three times, waiting 48 hrs between coats.
    Cockpit interior – the 5mm thick radiator housing floors were cut off and replaced with 1mm card, the supports for the instrument panel were added and some large gaps in the floor to body were filled with strips of card and a piece of card added to square up the rear face of the tub and two other pieces to fill the empty voids on each side that would otherwise be visible when viewed directly from the rear.
    It occurred to me at this point that the finished body/seat assembly would result in an unsightly join across the shoulder area of the seat, so I took a couple of brave pills, broke out the thinnest PE razor saw I possess and separated the top of the seat from the body.
    Initial lengthways cuts along coaming sides.
    The solid block of resin above the engine intakes was savaged from underneath with a dremel until light could be seen through the casting walls and then the vertical cuts were made below the intake (through the now 1mm ish thick walls), releasing the top of the seat.
    Which was immediately superglued to the top of the seat, later some filler was added to cover the join.
    The underside of the body below the intake was flat across the whole width of the rear deck – You can see below how much I ground out and how thick the outer radiator surround was before I sanded the tapers in, I did not go any thinner otherwise the radiator PE mesh would be too narrow, I am hoping the final SG black finish and the mesh screen will hide the over scale thickness!
    While the mad scientist was loose with the dremel, he ground out the clearance for the drivers hand/gear lever. Here you can also see the card additions to positively locate the rear floor vertically and the thinning of the cockpit sides.
    At this point I did consider removing the cockpit surround from the tub to be able to improve the cockpit interior/tub, but I want to finish it in this century - SABLE and all that.
    Moar soon mes amis.
    Malc.
    • Like 13
