Rob G
Posts posted by Rob G
5 hours ago, Morantbay said:
Has anyone actually attained "Constant Member"?
Chuck Norris got that just for signing up.
3
That Rangie looks like an extra from a low budget Mad Max rip-off...
2
8 hours ago, ElectroSoldier said:
It now seems its official that Trumpeter have finally pulled out the tooling and shot the F.1A/F.3 Lightning kit again.
Regardless of scale, that news should not excite anyone, with the possible exception of those whose reason for existence is the selling of resin replacement bits.
5
On 11/15/2022 at 10:57 PM, Tyas said:
... as a proof of concept that you can do a 250-mile round trip in a Taycan without having to worry about topping it up again.
LOL, that wouldn't get me to work and back home. Glad I can't afford one.
1
If accuracy isn't an issue, the otherwise ghastly offerings in 1/72th from Trumpeter should be available relatively cheaply and from my memory of investigating the 2 that I had (donated them to my model club as raffle prizes, IIRC, because anyone who gambles deserves bad luck occasionally), they don't seem to be too difficult to build. (Borne out by the reviews I just looked up).
The old Hasegawa/Frog/Revell F.6 kit scrubs up well, although it is a child of its times. It should also be cheap in a Revell box, with Revell's usually good decals.
1
5 hours ago, Stickframe said:
I have no idea why the chain drive winch is used, versus hydraulic You can see the chain drive in the two pictures on the right - both front and rear winches. I do recognize that some of this is likely defined by era specific technology, but have seen that chain driven parts are still used.
Like the real thing, I made up a cage for the winches. I'm not altogether sure why these are used, but they seem to be pretty universal.
Chain drive because 1. it's not complicated and it works, 2. it's easy to fix at 2am in the rain and 3 feet of mud and 3. it was what they had laying around when they built the truck in the site workshop! Hydraulics, while wonderful, are also dangerous - look up what happens due to hydraulic injection injuries. It'll give you nightmares.
Also, putting a cage around anything that moves is a Very Good Idea. Especially if said thing can grab your glove or sleeve and pull you in - heavy machinery doesn't care about your all too fragile flesh, and at 2am in the rain, it's easy to make mistakes that will last a lifetime (which can be very short if things go awry). Safety is sexy.
1 hour ago, keefr22 said:Nick, I'm going to show my ignorance, and I should have asked before, what's a 'gin pole truck' ?
Keith
Come on Keith, it's a truck for a gin pole. Not that difficult, surely?
(Yes, I'm TTP)
A gin pole is a simple (and ancient) way of making a crane. One or two sheer legs, braced with ropes and used to move loads via ropes and tackle. While limited in mobility and capacity, they're simple to erect and pretty rugged - no complex engineering to go wrong (which is exactly what you want at 2am in the rain...).
This may be of interest. https://www.pinterest.com.au/Ftruckn/gin-pole-truck/
2
1
1 hour ago, Mike said:
Another stalk grows from the centre of dash, almost out of range of the driver, and I will admit to having no idea what that is.
Turbo boost pressure regulator knob aka the 'Fun Control'.
over the Bight, causing
that sounds like Morse
Python's a coding language
1
, beer in hand, fries
than meets the I
(that's 'I', not 'l'. Or possibly, 'i', not 'L'. Stupid typeface.)
2
50 minutes ago, hairystick said:
Looks like a nice long hot summer ahead. This "global-warming" nonsesnse is superb!
I was up at the head of the valley this morning, before sunrise, camera in hand (on tripod actually, but let's not split hairs), and there was no sign of any 'global warming' - it was 14C with about 5C of wind chill. The water vapor in the air was condensing on its way up the side of the range and turning into clouds... It will be summer in 3 weeks. For reference, I live at 21 degrees South, so well into the tropics. Global warming, pah.
My mower's at the point of needing either some work, or replacing. Decisions, decisions.
And to stay on topic, on my way home I stopped in and bought a sausage roll, a mushroom pie and a large flat white for breakfast. How's them for latest acquisitions, eh?
3
1
to blow my nose
3
medal for distance running
2
needs lots of chlorine
2
Unleaded fuel, 91 octane, 5 litres, lawn mower for the use of. Sadly, summer's on its way, and that means that the verdammt grass will need regular attention again. I hate mowing, it's such a waste of time.
2
1
your Nikes for wellies
I have to admit to a bit of a Primus thing right now. (Snowflakes look away now!)
Les Claypool is a genius.
1
of your lollypop, plop
1
The Wingnut Wings instruction sheet for their 1/32 version may be of use. Find it here
http://www.wingnutwings.com/ww/productdetail?productid=3039&cat=4
of missed opportunities, disappointments
1
Motor advice
in Modelling Tips
Add a normally closed magnetic reed switch into the circuit. To turn it off, place a magnet next to the switch's location, remove it to turn it on. If you're putting it into a diorama, the magnet can be concealed inside a crate or barrel (or even a figure, if the scale's large enough) so that it's not an eyesore when things are static.
