stevej60
Gold Member
  • Posts
    20,949
  • Joined
  • Last visited
  • Days Won
    89
Posts posted by stevej60
  1. On 23/02/2023 at 09:09, Grandboof said:
    Nice choice on the Atlantic Scheme
    Martin H
    Best laid plans Martin,once again that awful join just looked terrible under the white primer so cutting my lossed after a second lot of filler and sanding I went for the Sea Blue
    scheme which is OK as I've never modelled a Wildcat in this later scheme and it fits nicely with the finished Corsair and upcoming Hellcat.Anyway she was brushed in Sea Blue
    and later some breaking up of the solid colour with medium blue both Tamiya colours.
    20230226_105830
    A coat of Humbrol gloss brushed and an hour later yet more hairy moments with HB's decals,the 6's both cracked up so spares were sought.HB would have you leave of
    the fuselage stars and even had me checking photo's of this unit's aircraft but they were painted on the real thing as was the small 6 on the cowling which are not supplied
    so again came from spares.
    20230226_114712
  2. Hi folk's,with the Fury done and the Mosquito only a few jobs away from completion time to restart the Hornet so after a touch of filler here and there I primed in white then
    masked the wheel well's.
    20230222_151714
    I then criss crossed  fine lines of black with the airbrush before a few coats of thinned light Gray.
    20230222_200845
    After the darker gray upper surface was sprayed I oversprayed in lighter gray then oversprayed one light coat of a third shade to blend it all in.
    20230222_200856
  3. 45 minutes ago, PeterB said:
    Hi Steve,
    I did one of their F4F-4 versions a while back and it went together well - the only problem I recall was that the decs stuck too well and don't like being manoeuvred into position without tearing so use plenty of water/Microsol etc. I guess yours is the later General Motors produced FM-2? The Atlantic finish will make a nice change.
    Pete
    Hi Pete yes I've built the other two boxing's but not this version with the taller tail.I find the wing to fuselage join can be troublesome at the under fuselage to tailwheel join
    if it looks poor I can swing over to the Sea Blue scheme which will hide it better.
  4. 5 hours ago, Dermo245 said:
    Great stuff and it's a lovely kit - I won't hijack your thread with the two I've built.
    One mod I did do was to shorten the main gear by a few mm; otherwise, it has a 'nose up' attitude when built out-of-box.
    Look forward to seeing these!
    All the best,
    Dermot
    Thanks Dermo.Pop a couple of photos on never seen these built.
  5. On 16/02/2023 at 11:17, Biggles87 said:
    So you like a challenge then?
    I’ll be interested to see the ‘ highly detailed ‘ cockpit.  😜
    John
    As requested John,the highly detailed cockpit.
    20230220_110736
    Anf for good measure the highly detailed wheel bay.Some work needed on both me thinks.
    20230220_112149
