Black Knight
Gold Member
  • Posts
    6,370
  • Joined
Posts posted by Black Knight
  1. 5 months later;
    more done on this
    The top of the lower wings, the tail planes and the fin have all got a coat of Humbrol 188 Chrome Yellow. The fuselage has been painted Xtracolor X-22 RFC Green, which I like for USAAC green. The paint colours match the plastic colours as well. Just needs some paint touch-ups
    Next, drill some more rigging holes and fit the top wing. The engine & prop and cowling are ready for fitting
  2. 43 minutes ago, jenko said:
    I think the term "cash cow" comes to mind.  And of course there will  be something totally left field............................. 1/48 Beaufighter .....Gannet.
    They did have some of the artwork done a while back. This is from a real box. not edited or 'photoshopped'
  3. The fuselage all joined up. It needed a lot of fillers
    Matchbox%20Hawker%20Hunter%20T.%20Mk.7,%
    I blanked off the insides of the intakes. See firther down for the reason for the black semi-circle
    Wings on, more fillers and aluminium paint to even out the colours and prepare the wing tips for white paint
    Pilots are ready
    Tail planes on, wing tips got a first couple of coats of white paint
    Fuselage and tail planes have a first coat of Humbrol 25 enamel paint
    The black semi-circle in the intake along with some black on the fuselage tricks the eye into thinking there is a deep hole there, if anyone bother to get down and that close!
    When the fuselage paint is dry I can put the undercart on, its all ready painted and just waiting its turn to get glued on, and mask off the white wing tips and then paint the wings
  4. On 30/09/2022 at 10:41, Black Knight said:
    When I was a postie in early 1980s I was periodically given a big tin of Humbrol 19 and had to go round all the local letter boxes and touch in the paint on them. 19 was a perfect match for them but it was too bright for my vans. The red on them was closer to post-WW2 RAF roundel red
    btw, even though Humbrol 19 was too bright for our vans that didn't stop us using it on them, to cover up rust, scratches and dings
  5. Number 6, and maybe the last of this series.
    Ugandan COIN Gnat
    You want a story?
    I'll tell you a story;
    The RAF Red Arrows had been on a visit to South Africa. They were staging their return home through various African counties. One was Uganda. When one of the Gnat landed at Kampala two of its tyres punctured. The support team had no spare tyres left so it was decided that that one Gnat, its pilot and some ground crew would remain there. The support team would get the tyres and return.
    But in the meantime Idi Amin seized control of the country in a coup. On the advice of a friendly army officer the RAF personnel left Uganda by road very quickly. The Gnat was left behind. It was later written up that this one had crashed, to cover up its loss.
    The new administration fixed up the Gnat, fitted it with rocket pods and used it to supress opposition in COIN operations
    Folland%20Gnat%20Whif,%20Ugandan%20Air%2
    Folland%20Gnat%20Whif%2C%20Ugandan%20Air
    • Like 26
  6. On 04/09/2022 at 10:50, Black Knight said:
    I used to cast car club badges for my vintage car club members. These were made in white-metal, i.e. a lead/tin alloy.
    On these, as well as on other copies of the badges previously made in brass, I used Humbrol enamels to paint in the details. I used Humbrol numbers, 2. 3, 14, 15, 11, 16, 21, 22. I never used a primer or undercoat, just a few coats of the Humbrol gloss paint
    Just a wee up-date;
    Last Saturday my car club had it autumn rally
    I looked for club badges I had made and painted. I found only one
    The Humbrol enamels on it have dulled, i.e. they are no longer glossy, the colour has faded a bit but its still the same colour. That badge was made and painted about 2007
    Of the repainted brass badges I could not discern which were mine or were the very original badges, all the colours looked good
  7. 35 minutes ago, Corsairfoxfouruncle said:
    Well this is an interesting choice, Ive seen all sorts of colors on Napoleonic era uniforms. Ranging from Reds, Greens, Blues, but never heard of yellow.
    It was usual for the musicians to wear reversed colour uniforms. Their 'facings' were the main uniform colour and their uniform was the regiment's facings colour
    In this case the 13th's facings are yellow, thus the trumpeter wears a yellow jacket
    Just as today in the British Army the musicians were the stretcher bearers and field medics. Having a reversed colour uniform made them stand out and be found easily
    • Thanks 2
  8. Get yourself some green FIMO or Sculpey polymer clay.
    If you don't know it, it is a by-heat hardening plastic clay. Its like plasticine, but after you make your shape you cook it in an ordinary oven for a about 15 to 30 minutes to harden it and then the shape is permanent
    Shape up your lily pads and cook them
    Cut a big circle type shape, use your fingers and modelling tools to form the rim, add veins et cetera. When you are happy with it, cook it
    If you don't like the way it is forming, just squeeze the polymer clay together again and start over, as often as you want. It will only harden when you cook it.
    The clay is available in a multitude of colours and these can be mixed together as well
    A 58 or 60g block costs around £3 and will make many dozens of lily pads
    When hard the polymer clay can be painted with acrylic paints as well
  9. Its easy peasy to make one yourself. Especially as you are tackling an F-14!
    some rod, brass, acrylic (clear or coloured) a bit of nice wood for the base,
    Paint or colour stain the piece of wood. Dill a hole in it. Insert rod. On t'other end of rod put the F-14. A hole drilled in it would help too.
    Rod you can get in the metals section of B&Q. you might be able to an off-cut of MDF there as well. Last time I was in I got a big load of off-cuts for 50p
