Bengalensis
Gold Member
  • Posts
    4,190
  • Joined
  • Last visited
  • Days Won
    9
Posts posted by Bengalensis
  1. The route number box is not glued yet, just checking how things fit. That red handle under the roof sits at a slight angle outwards on purpose.
    Body number decal.
    The front and rear route blinds are on.
    Front and rear sections are also coming together.
    The rear license plate is somewhat of a compromise as Revell’s recess does not seem to have the correct dimensions. That could possibly have been reworked, but I really didn’t notice until working with the decal art work.
  2. I’m making good progress with the sub assemblies now.
    At this point I strongly recommend to only glue the body section with the bonnet hinges along the inner edge to the front interior wall. I found during my taped up dry build that it is good to be able to tweak this section just a little back and forth. It may be more important in my case as I have cut up and messed with so many parts in the RM-conversion process, but this way the side wall does not have to fit against two firmly fixed body panels when time comes for that.
    Here is stupid mistake not to repeat if you are building an older bus like me. The panel on which the black seating capacity is written should have been removed and sanded flat. I only discovered that when all paint etc was done, and never worked up inspiration to start all over again… There will be some light weathering to the handles and the rest when the model is more complete.
    More interior sections.
    If you are building according to the instructions, watch up here. Revell has drawn this handle pointing backwards in the bus which I never see in my references. It fits well the way it’s supposed to sit so I guess they messed up the drawings.
  3. The drivers cab is finished, I think. I have scratched some extra details. The seat got a backside so it looks ok from behind. On all windows I run a black marker pen along the edges to get rid of the edge glint you otherwise get. That makes a difference to the better to me.
    Some more details; emergency exit handle, crank for route blinds (I think…) and the low pressure indicator with its stop-flag.
    Since the Leyland O.600 in my model is shut off and it’s standing still the flag says “STOP”. When read from inside the cab. ;)
  4. K63 contains the gear selector, I thought K60 was the starting handle, albeit somewhat oversized?
    Good to see progress Gordon. Revell Germany have always been kind to me when I have asked for a spare part and even extra parts over the years, so you could try contavcting them.
  5. I have been dry building a little with the painted seats and interior sides, and quickly it became clear that I couldn’t leave the seat backs “open” as they come in the kit. So now I have cut 27 seat backs from plasticard… spraying grey tomorrow. They go up under the seat frame on top and rests on the bottom crossmember. Will try to get a picture comparing with an without when they are painted.
  6. I have now done all decals I need except the exterior adverts. Or not completely, the art work for the block of interior ads I found on a Flickr group (I have the link somewhere if anyone wants it), so they are not mine, but the rest of the artwork are my own. The license plates will have a second go after period pictures rather than the restored. The destination blinds are measured as best I can, but we will see if I must adjust them some more once I start applying.
    Unfortunately I just can’t take a good picture of the white prints. There is a lot of stuff on that piece. It will show once it finds it way to various parts.
  7. So the current state of this project is more or less endless rows and bags of painted parts, more or less finished. Painting all parts before any definitive assembly starts has taken more space and time than I thought. Still I prefer this way when possible.
    I finished all the seat decals tonight. Next they will have a matt clear coat over the decaled tissue areas, then some soft dark lines to separate the different cushions from each other and some light weathering to finish.
    I’m quite happy with my Leyland O.600 engine. Good we found that one out in time…
    I really look forward to applying detail decals to all interior parts and starting assembly.
  8. I'm painting painting and painting... and I've done most new decals, actually all except the exterior adverts so far. What's left to paint is basically the brush painted details of the body panels, some more weathering on the floors and seats, after the sest decals are on, and the wheels. Hope to get some pics up tonight.
    I still also have to decide if I should leave the body panels in their relatively "new-shine" glossy appearence and do some very light washing/weathering, or spray them with a more semi-gloss clear coat. Don't know. The bus I'm trying to build has only been in traffic for maybee a year or so, probably around -64 when I assume the daily and weekly care in the garages where much higher than perhaps 10 or 20 years later? I don't know if that was really the case, it's just my perception on how things have evolved around me... Any thoughts on this are most welcome.
  9. Nice ^_^ . Memories from those who rode with these buses on regular basis back then makes a build more interesting.
    I found out that the drivers seat should be black. But still wonering about the drivers cab interior walls lower sections, black like everything else, or brown/burgundy red? I see the coloured versions in some photos, but I'm guessing it might be from later overhauls?
  10. I did some detailing for the wire running under lower deck roof. What is it for? “Stop at next stop please”? Some details from the PE-scrap box were used.
    I also formed the small lamp shield for the left front interior light bulb. I will have to glue it straight after painting and not as clumsy as I rigged it here…
    The paint work has started. All body panels are primed and will now have some rest before a final sanding. Here is the black base coat before Alclad chrome. This model takes up so much space to paint that I’m running out of clamps, and the usual places where I store painted parts for drying gets full at once…
  11. I wonder about the drivers seat. How was that covered in vehicles delivered early to mid -60's? Was it a black leather like material, or the same fabric as the passenger seats? I thougt it would be black as that is what I see in most pictures, but I'm not sure. I would appreciate any help here.
    The same goes for the colour inside the drivers cabin. All black, or the lower sections of the walls a dark burgundy red or brown?
