Bengalensis
Gold Member
  • Posts
    4,190
  • Joined
  • Last visited
  • Days Won
    9
Posts posted by Bengalensis
  1. I have been researching and drawing various adverts for what seems like a small eternity now. And when I more or less gave up finding color photos of that Cinzano I wanted a friend of mine sat down searching for hours, finding exactly what was needed. I can never figure out why he finds things I never find by typing the same word in Google as I do, it’s always like that… Then I did simple paper test prints to see how it looked, finding out it didn’t satisfy, or that it was the wrong year after all…
    Finally we found everything and all the drawing fell in place and it gave me the look and feeling I wanted. Here the final choice is printed and have received a semi-matt clear coat. They may not be perfectly accurate but certainly close enough. Now I just have to apply them without messing things up. Sure I can make new ones, but now I want this part of the build finished. Can't wait to get them on.
  2. I thought about doing one of these some time, but judging by what i have seen of the builds on here, i don`t think i will now
    as the bar has been set too high.
    Oh it's well worth building it not least for your own pleasure, regardless of where you want to place your bar. And that's the only bar that's really important, that's how I try to build my own models. It's a nice kit that will build a nice model OOTB and provide a good time for the builder doing it.
    I see many Routemasters being built now, both here and on other places on the web, with very varying goals, ambitions and results, but I'm quite sure that everyone building them have a good time doing it. At least I hope so. Go for it. :)
  3. Here is how the model is right now. All bodywork installed and all seams taken care of. I’m very surprised how my RM1699 decals look in these photos. They are printed with gold foil and looks bright in real life, matching the other gold decals very well, not at all dull like these pictures show. Oh well. There are now only a few exterior details to fit, and many many windows. But first there are other things to address.
    I really need to finish the exterior adverts. I had an idea which I wanted, and I have created all artwork except one that I can’t pin the colours on, a Cinzano advert on the rear panel. Maybe have to consider another one. Then I realised that the pair I had planned for the front probably are from 1962 and therefore too old for my model. Back to the drawing board… Also I’m wondering if my trusty old Alps MD5000 will be up to the task.
    Then there is a lot of washing and light weathering to do. So lots of work remains.
    About the bodywork, take your time and work slowly and carefully, test fit several stages ahead during the whole build and make fine adjustments if necessary. The parts do fit very well in my case, even after extensively cutting it up to make an RM. I felt it was good to really know exactly how every panel would be installed before it was time to do it “for real” so all the dry fitting early on probably paid of.
  4. And so the major assemblies start to go together. I always try to test fit a few stages ahead at this point to ensure that the coming parts will fit well and that necessary touch in painting is not missed.
    With the lower roof installed I made sure that the left side wall will fit perfectly to the front and rear wall.
    And the top deck in place. Suddenly the model grew conciderably.
    It looks quite terrible like this, naked with no bodywork. As I have test fitted everything all the time I know it will change though.
  5. Perhaps the responsible conductor would never leave his ticket machine and his badge unattended on the shelf like this, but anyway. I liked the detail and wanted it in the model. Maybe he or she is just outside?
    I have tried to add some more life to the interior with some added details. Tickets, news papers, cans, forgotten stuff…
    Our driver has tucked away his copy of todays paper under his seat.
  6. I think you really need to fit the frames to the seats first so that they will be stable in the correct shape. That will also help to correct the shape of those that might be a bit bent.
    You will know that the seats are reasonably ok on their tabs on the side wall if the seats are well aligned from all views, and the alignment is more important than exactly how they sit on the tab. This was not much of a problem for me, with all the seats assembled with care they did fell nicely in place in even rows with some slight trimming.
    I first placed a tiny dap of 5 min epoxy in each leg recess and one on the side wall “shelf”, then put the completed seat in place, put a small weight on the seat cushion to hold down the seat, adjusted its alignment and lastly put a drop of super glue where the frame tab comes out (or almost out) through the outside wall.
    I think that it comes down to working slowly and carefully and let the job take the time it needs. Well build seats in nice even rows will set a bus interior apart.
  7. It seems to be coming together nicely.
    I did my seats this way. It worked well for me and I would do the same again if I built another one.
    1. Paint all parts separately, after thorough clean-up of seam lines and sprue attachment points.
    2. Decals on the seats.
    3. Matt varnish on seat decals.
    4. Thin black wash between the two seat cushions.
    5. Attach frames to seats, be careful and accurate in their fitting. Let glue dry (I used instant super glue).
    6. Attach legs to seat bottoms, dry fit all first to ensure a perfect fit. Many legs will need trimming in their little slots so they slide down well in the correct position, this is important. Let glue dry.
    7. Install scratched seat backs if this is opted for.
    8. Now the finished seats are ready to install.
    Be careful to find out exactly how the frames and legs shall fit to the seats before starting, and ensure to assemble all seats likewise so ideally they can’t be told apart. If the parts are fitted correctly with the all legs sitting all the way into their correct position the completed seats will fit well. I only had to slightly trim all six right hand grab pole frames at the bottom where they sit on the side wall to get a good fit and nice even rows when I installed my seats.
    It does take a good deal of time to build the seats, but when they are fitted in their rows it pays off to having done it well. And yes, I’ll admit they did tension my patience… ;)
  8. Could it be moisture that shows up here? How long did the decals dry before the varnish went on? What happens if you give one of the affected seats a thin coat of clear gloss varnish, once the current is thoroughly dry? If that works you might be able to have second go with another flat varnish afterwards. BTW, I used thin flat water based acrylic varnish on my seat decals.
    However, Revell have always been helpful to me with both parts and decals over the years, so I think you have good chances to get a replacement if you can't save them.
  9. I’m very happy, and even humbled if my build is an inspiration to you guys. Great to hear. It is a very inspiring build, certainly one of the most rewarding and interesting I’ve done the last few years.
    More detail work on the interior have been done, and the top deck is now attached. The stage to fit the exterior body panels have arrived. I should have new pictures coming up soon.
    Regarding the rear hubcaps, the base for them is a 3D-print. I wish it was that simple, but it isn’t. They require quite some work after the printing process. My plan though is to make some little improvements on the current 3D-model and then make new to form the base for a mould for resin copies for dedicated RM-builders. But I can’t give a specific time plan tonight.
    ScalecCentral; you have PM.
  10. The Carpet Monster is an unforgiving creature... Try fitting a brand new bag in the vacuum cleaner and go over the whole area, a lot easier to fin the part in the cleaner then. Or make a filter over the hose end of a nylon stocking. Both works.
  11. This is superb modelling work. Well done. Immaculate.
    You must be representing a bus recently put into service, or re-furbished, because I vividly remember, in the mid 70s in London, most of these that were in use for a few months developed a horrible sticky tar residue on the upstairs ceiling from all the cigarettes consumed up there. It was quite gross and on some, it even began to form small stalactites!
    David
    Thanks a lot. Yes, you are right, this bus is relatively new. It left the factory new in september -63 and was taken into service on route 14 in november that year . I tend to think my model is perhaps summer -64 or a bit later, in quite good but used condition. Some areas of my weahtering may be a bit too much for that, but never mind. Although I should perhaps try and do something to that upper deck roof.
  12. This really is amazing work and brings back lots of great memories of time spent on these buses including the No. 14 route, however does Euston really have an extra e on the end?
    Graham
    No, there shouldn’t be an e there in the end of Euston, my mistake. Glad it was found out now and not at a later stage. Here are the new blinds I printed tonight.
  13. I have spent the better part of the day fitting the seats and trying to get some realistic look to it all. When you come to the point of seat fitting, take your time and dry fit every single seat in the position it will be installed in to ensure all line up nicely. I had to slightly trim all six right hand “pillar” frames at the bottom where they sit on the small side wall “shelf” to get a good fit and nice even rows.
    I have tried to give the whole thing a slightly used look with some variation according to different seat popularity and what they may have been subjected to, drawing inspiration from some real photos. I’m not sure how trustworthy it really is, but I don’t really dare to mess with it too much either.
  14. Jorgen
    Fantastic modelling, i have really enjoyed building the kit myself.
    One point, please note that Euston does NOT have an e on the end (Eustone) as per your model.
    Regards
    John
    Damn, you are right. My two reference photos of this blind are slightly blurred, but I should have checked this better. I have fitted the glass already, but only with Kristal Klear... with some luck I can get them off... I will have to try and correct it directly. Good that you spotted it.
  15. Driver’s cab section joined the chassis. Here I choose to only glue it against the bottom floor at this point, again I hope to gain some possibility to slight adjustments when fitting the body panels together.
    Some thin black wash lines between the different seat cushions help up the look. Once all are installed I hope to be able to create a little wear and some more life to them.
    Here I hope it shows clearly why I add rear panels to the seats.
    The seat factory has now closed and the work force now have to recover the whole evening with a good bottle of whine… The seats are tedious repetitive work.
