Rodders154
Gold Member
  • Posts
    946
  • Joined
  • Last visited
Posts posted by Rodders154
  1. WARNING
    Whilst reading WKENNERLEY's post on his compressor woe's http://www.britmodeller.com/forums/index.php?/topic/235006510-compressor-tank-blown-has-anyone-got-a-spare-please/ I have the same compressor and I thought that /i would drain off my tank to stop the same happeng to me and I place a cup under the drain plug (didnt know it had one until I looked and it still had a little pressure (so little it didnt read on the gauge) and about 1/4 pint of brown rusty water shot out and has gone all over the carpet.
    Pease drain the tank outside my carpet is now ruined I did not expect so much water Be aware when you do yours. I drain the little water trap on the front after every use but there is now brown gunge in the water trap as well.
    Be careful I would imagine this applies to all compressors that have a tank Maybe I should have known to drain the tank but I didnt and I bet others dont as well.
    Rodders
  2. when i try to send pictures of the Westland Wasp I get this :-(
    'photo@italeri.com' on 19/08/2016 14:29
    552 Z1Uq1t0030k93Wz011UrFV message rejected due to spam or virus. If you believe this is in error please login to your portal or contact your ISP support team.
    Rodders
  3. I decied to build this kit as a what if because the kit is for a prototype and to bring it up to latest standard would involve a lot of work. I did however cut out the window by the front door and even though you cannot see it the seats and consoles are in there.
    Painted using modelair paints and Kleer with decals cobbled togeather from kit decals, modeldecal and spares box decals. The actual painting was done with a cheap £6 chineese badger 150 copy it hasen't come out too bad.
    I am pleased with result and reckon that it could actually be done on the full size aircraft. There is presidence as there was a MK5 done in a simaliar scheme a few years ago.
    Normal 5ft viewing distance please.
    And with a proper HAS2
    Thank you for looking
    Rodders
    • Like 11
  4. I havent seen this version finished so I thought I would put mine up. I do like the yellow RAF rescue helicopters as the last picture wll testify. This is a superb kit and the interior detail is very good shame a lot cant seen if the doors are shut. I have however opened the aircraft up I did the kit version but have just notice that i missed off the directional spot at the rear of the fusalage. Too late now. I had a spare air filter from a revell kit so I used that instead and when the airfix decals went on and the microset had done its job I was rather pleased with the result. Otherwise all straight out of the box Very good value kit will be buying more. Normal rules view from 5ft
    Rodders
    ooops that blade nees bending down
    A theme is developing here :-)
    • Like 53
