QUOTE (Graham Boak @ Jul 30 2010, 03:36 PM)
More detail please. Are you talking about Hurricane DH spinner compared to Spitfire DH spinner, or Rotol compared to DH? The DH spinner(s) is basically conical, fairly pointed, whereas the Rotol spinner is basically hemispherical, and on the Hurricane overlaps the nose slightly - that's why later Hurricanes added an oil spill ring behind the spinner. Possibly that's why you think it oversize?
Strictly speaking, I gather each type had individual spinners, probably because the Spitfire has a slightly larger nose than the Hurricane. However, for modelling purposes you can normally think just of DH or Rotol.
The propellors are differently shaped. Just switching spinner may not be enough.
I believe there are two issues in play here. Treat all this with caution because it is based on what I've read elsewhere raether than my own primary research...
1. As Graham says, the Hurricane's 'natural' spinner diameter is smaller than the Spitfire. I believe, but have no documentary proof handy, that the Rotol prop seen on some Mark I Hurris including those represented in the Airfix kit, was in fact a Spitfire II prop, rather than one tailor made for the Hurri, and this is why (as Graham points out) it is visibly too big for the Hurri nose, requiring the oil spill ring to be added.
2. The Airfix Hurricane is said by some to have a fatter than scale nose in any case. I can't vouch for this as I have yet to compare it with measurements of the full size.
If both these are true, it follows that the Airfix Rotol spinner supplied with the Hurri is bigger than it ought to be. It is also likely that a Spit DH spinner will look right on an Airfix 1/24 Hurri. The Spit DH spinner will be wider than a Hurri DH spinner ought to be, but will most likely match up with the oversized Airfix Hurri nose.
I will have a play with my stash of 1/24 kits later this evening...
