First review of the Saitek yoke is out and its looking pretty good, the problems everyone has with the sticky non centring shaft on the CH yoke seem to have been resolved with the Saitek's steel shaft, only downside is the mention of the feel on the rocker switch's ... if I found it bad I'd replace with metal ones from electronic suppliers like Maplins.
Not mentioned in the review or maybe I missed it? I read elsewhere that the bottom notch on the throttle does have a distinct notch for idle and if you pull it below this it will engage thrust reverse, have noticed that unlike the CH Yoke that is curved and sloped, the Saitek is flat, so you could put your keyboard on there,
Saitek Yoke ReviewNow ... I wonder when they will be available in the UK?
