Help - Search - Members - Calendar
Full Version: Hawk canopies made easy
Britmodeller.com > Aircraft Modelling > Work in Progress - Aircraft
Jonathan Mock
The Airfix 1/72 Hawk canopy. The MDC is moulded in place, how can it be improved? Easy, paint it!
The chord is actually engraved on the inside of the canopy, so the trick is to make a thin mix of water-soluble paint and flow it into the recesses. Don't worry if you overshoot the detail, let the paint touch dry for a few minutes and then...
Taking a clean cloth, remove the excess. If there are any stubborn spots, moisten the cloth. Take care not to crack the canopy.
Job done! An easy improvement over the unpainted MDC chord.
Gary West
Definately gonna give this a go next Hawk - looks pretty good.
Mike
MUCH less hassle than the PE one that I fitted to my vacformed CMK canopy... that was a heart in mouth moment. unsure.gif
Leigh
Have you dipped the canopy in Future first?
Jonathan Mock
QUOTE (Leigh @ Jul 8 2007, 11:55 PM) *
No, for the simple reason that in trying to remove any excess paint from the MDC chord you might scuff through the Future, or use a paint that might react with the Future. Better to get the MDC done, give the canopy a good polish (I prefer Model Wax) then dip it in Future.
Bill Clark
Great stuff..additionally on my Hawks I reduced the thickness of the canopy from the outside by gentle (VERY gentle!) sanding down using wet n dry then progressing on to Micro-mesh. This also removed the raised centre frame (which in reality is the sealant INTERNALLY between the rear seats blast screen and the canopy.). As a result the MDC seems (for some reason!) to appear with a finer outline........................................
Airfix should be congratulated in attempting to mould in an MDC on a canopy.....and doing so remarkably well. I've certainly struggled with Hasegawa's decals and etched MDC's in the past.....
Andy K
What a cracking tip! I'll try that when I get around to building a Hawk...erm....sometime this decade.......or not! biggrin.gif Speaking of which is the warp in the wing where the sprue is attached easy to get rid of? When I first got the Airfix 1/48 Hawk I was quite alarmed by it!
bigbadbadge
Many thanks Jonathon
That is really handy, I am currently doing one of the 100 series Hawks from Airfix and this is really handy. Although it is a long way off before the canopy goes on.
All the best and cheers for sharing.
Chris
Nev
Yep, certainly does work - even a muppet like me can do it! :cool:
http://www.britmodeler.com/forums/index.php?showtopic=3442
WolvoWill
Tried this myself recently on a 208sqn T1 build, and it worked an absolute treat! Photos to follow quite soon - the airfix Hawk is quite nice to just throw together and if you use fast drying paints and doing go all 'advanced modeller' with aftermarket bits its possible to build one very quickly indeed!
EE Lightning
Hi Jonathan,
Nice one - thanks for the tip. Never thought of that and it seems to come out very well - so will give that a go when I get to my Hawk. Thanks again.
Wayne Beattie
I followed your instructions and this is how mine turned out.
Thanks,
Wayne Beattie
markc
Good job no your canopy Wayne, looks great!!
MarkC
Jonathan Mock
Had to delete links to my pics guys because the links had gone dead and I can't find the originals, sorry.
Wayne's excellent photo does show the results better than mine did anyway!
dahut
SO as I make it, the MDC cord is and incused design and not a raised relief detail. That IS a nice touch and way to go Airfix. The decals look good, too, when shown in your other post. I think I may have to hunt up one of these kits. This leads me to two questions:
1. Why is Airfix so little represented here in the States, compared to the other brands?
2. What does MDC stand for?
Jonathan Mock
QUOTE (dahut @ Jan 5 2008, 09:23 PM) *
Down to the distributors!
QUOTE
Micro (or Miniature) Detonation Cord.
Andy Mullen
Thank you for the tip Jonathan, mine turned out fantastic
Mattlaker
Superb trick there! I did the same, only instead of a water-based paint, used a pastel wash... figured if it went wrong, i could clean it up easier!!!
mikeew
I dipped the canopy in Klear, let it dry and used thinned Citadel Skull White and cleaned up the excess with a moistened cotton bud - simple!
Doug
Are MDC's White or Grey, if Grey which shade?
Doug
Kirk
Kinda lead coloured. IIRC it is actually lead tube filled with bangy stuff??
Scarlet
Don't know exactly what it is made of, but it aint lead, very plasticy to the touch. The colour in Andy Mullen's post is just about spot on.
Did a see-in on a Hawk at Valley with a very pale looking student pilot in the front seat, the live MDC had disbonded and was hanging around his neck.
Doug
Cheers Scarlet, missed that.
Doug.
Scarlet
No probs. Found my Hawk Composite Servicing course notes in the garage the other day - have'nt seen them since 1989! Spent six happy years at Valley fettling the little buggers.
martin s
What a great tip tried it worked and will do it again what more can i say
WARDOG
My method is to carefully paint the MDC with a fine brush using acryllic paint and to the use a common, un-colored wooden tooth pick to carefully scratch away the excess paint around the edges. Works every time!
WARDOG
HOUSTON
Jonathan
GREAT tutorials and nice simple easy steps too..
Thank you
Spooky56
So simple, yet so effective. Have a couple to do when I get some time, will definitely use this technique
harriermad
nice trick will this work on the revell 1/32 model too
chris
dylan the rabbit
Thanks Jonathan... Just used that now on my 1/72nd Hawk, and it worked a treat.
markmarples
QUOTE (harriermad @ Jul 1 2011, 01:24 PM) *
chris
no the dec cord on the 1/32 is a decal, i wish it did
Blackie
QUOTE (Jonathan Mock @ Jul 8 2007, 08:08 PM) *
Hi folks, New to this site so please excuse if I get the posts wrong. How do you go about the cream coloured canopy sealant? That always gets me.
Darby
Just tried it and it works. Even for me.
Billy BigBoy
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2012 Invision Power Services, Inc.
