May 12 2010, 06:44 PM
Post
#41
Proud dad Group: Root Admin Posts: 8,388,607 Joined: 23-March 07 From: Chester, UK Member No.: 1 |
I was sat idly at my bench after lunch, feeling a bit spaced out and listless. It must have been the space that did it... I began my first sci-fi build since I was a teenager. The new Millennium Falcon from Finemolds.
Have a quick read of the review here to see my initial thoughts on the kit if you like. I don't mind waiting Well... first item for work was to clean up the central sprues that sit in the middle of the two hull parts. Easy to do, and so I moved on to snippiing off a couple of the round equipment bay inserts on the cargo jaws up front. Because of the way they're sprued up, all you have to do is nip them close to the attachment lugs and clip them in. They really are THAT good a fit. A little dribble of liquid glue, and some pressure for a short while, and we're done. The same process was used for all of the many inserts, the detail of which is excellent! No shadow of a doubt, the detail is the crispest (as previously mentioned in the review), and extra spruelets have been added around the edges to ensure that the detail gets a full fill of styrene during the moulding process. Well worth the effort of nipping them off. I had a few misgivings about simply gluing the side walls into the bottom of the hull, as I felt that if I didn't get them perfectly square, it could cause fit issues with the upper hull when it came time to close it up. As a precaution, I installed a few parts, and did a test fit - no problems encountered at all, as the mounting lugs are precise, so I ploughed on. Here you should take the time to remove any mould seams on the edges of the parts, as although you can't see some of them, others are on view. The instructions show you attaching the big round endy things (yes, those again) being attached later in the build when the hull is joined. I didn't want to have any hull parts lying around to be painted off the hull, so I joined them to the bottom half, again, checking alignment by test fitting the top hull as I went along. Everything fits beautifully, and I will be able to keep the two hull parts separate until after painting, so I can paint the cargo jaws insides easily with my airbrush. The cockpit amd crew tube would also be able to be click-fitted later if you so choose, but I suspect I'll be attaching mine once I have the cockpit painted, which fits INSIDE the tube parts, so can't be left off until later. So how does it look so far? Good... the build has been a breeze, and I think has taken me about 30 minutes so far. The quality of the moulding really shows in the speed and ease of construction ![]() ![]() That chunk of blutak was just there to hold a joint closed while the glue set. ![]() The front panel of the jaws locks the two halves of the hull together, so would have stopped me from splitting it for painting, so I lopped off the lugs from the top of the hull to solve that issue. I clipped the hull halves together while the glue set though, just to make sure they ended up in the right place. ![]() I've also built up the antenna and am working on the cockpit area now. Just need some refs... Jeff? |
Mike Millennium Falcon (1:144 Finemolds) May 12 2010, 06:44 PM
Andy Mullen Looking good Mike
Slightly dissapointed you are n... May 17 2010, 12:45 PM
markmarples thats cool nice find andy, come on mike some more ... May 17 2010, 01:09 PM
Obi-Jiff Kenobi QUOTE (markmarples @ May 17 2010, 02:09 P... May 17 2010, 02:54 PM
markmarples no just trying to convince the wife to let me buy ... May 17 2010, 04:54 PM
Mike I'm currently running my PC on Ubuntu, so can... May 17 2010, 04:59 PM
markmarples are we nearly there yet!!!
... May 17 2010, 05:01 PM
Smiffy QUOTE (Obi-Jiff Kenobi @ May 17 2010, 03... May 17 2010, 06:26 PM
Mike Ok... flipped back to Windows so I could get a fix... May 17 2010, 08:43 PM
daz greenwood Looking very nice Mike! May 17 2010, 08:44 PM
markmarples looking good, is it as easy to build as it looks, ... May 17 2010, 08:46 PM
Mike Thanks guys
Mark - it's a piece of cake to b... May 17 2010, 08:54 PM
markmarples ok im convinced, as soon as pay day arrives im ord... May 17 2010, 09:00 PM
Mike Make sure you do and don't forget a WIP threa... May 17 2010, 09:02 PM
markmarples QUOTE (Mike @ May 17 2010, 10:02 PM) Make... May 17 2010, 09:07 PM
Mike The cockpit will be very fiddly to light - it... May 17 2010, 09:08 PM
Mike @ Two Mikes Resin Looking very nice Mike! I can't wait to se... May 17 2010, 09:10 PM
Mike QUOTE (Mike @ Two Mikes Resin @ May 17 2010, ... May 17 2010, 09:40 PM
markmarples ill see what its like but fiber optics only need t... May 17 2010, 09:11 PM
periklis_sale looking great mate! May 18 2010, 05:17 AM
Mike The first round of weathering was done this evenin... May 21 2010, 08:56 PM
TonyT Actual model for reference
http://www.starshipmod... May 21 2010, 10:27 PM
denstore Nice! May 21 2010, 08:58 PM
Tabio Cool, she's the fastest hunk of junk in the ga... May 21 2010, 09:22 PM
Mike @ Two Mikes Resin The color looks spot on from my recollection of th... May 21 2010, 10:04 PM
Mike Thanks guys - plenty more weathering left to do May 22 2010, 08:59 AM
The Sheene Machine Loving that - weathering has already added some ni... May 22 2010, 11:19 AM
Mike Stage 2 of the weathering process was done this av... May 22 2010, 03:42 PM
Smiffy Coming along nicely.
This ship's all about ... May 22 2010, 04:01 PM
Mike Cheers Paul - another 3 or 4 stages left yet, incl... May 22 2010, 04:31 PM
daz greenwood Looking good Mike I can't wait to see it all w... May 22 2010, 04:34 PM
Mike I cheated this avo and did stages 2 and 3 together... May 23 2010, 04:02 PM
Obi-Jiff Kenobi Looking great, Mike. The weathering is really brin... May 23 2010, 06:06 PM
markmarples looks great mike, keep it coming May 23 2010, 06:11 PM
Antony Robertson Looking good Mike, cant wait to see her finished... May 23 2010, 06:13 PM
Mike Thanks guys Makes me wish I'd got a 1:72 scal... May 23 2010, 07:02 PM
gunpowder17 Fantastic Mike. Its more complex to weather than y... May 23 2010, 08:36 PM
Mike QUOTE (gunpowder17 @ May 23 2010, 09:36 P... May 23 2010, 08:41 PM
gunpowder17 Thats the problem. Look too closely at the props a... May 23 2010, 09:05 PM
TonyT I never ever follow references for paint and weath... May 24 2010, 01:18 AM
Smiffy "Allllmost there"
QUOTE (Mike @ M... May 24 2010, 09:55 PM
Mike Oh yeah, I'm sure they've been thru hell ... May 24 2010, 10:51 PM
daz greenwood Hi Mike!
This is the Star Wars Chronicles boo... May 24 2010, 11:04 PM
Obi-Jiff Kenobi Some people find solace and meaning in the Bible -... May 25 2010, 07:38 AM
Mike Never even seen that book. When was it released, ... May 25 2010, 09:32 AM
Obi-Jiff Kenobi It was originally a Japanese book, mid-1990s, then... May 25 2010, 11:24 AM
Mike They go for silly money now... £300 on Amazon thro... May 25 2010, 11:25 AM
Obi-Jiff Kenobi Despite having no money to my name, I'm not ev... May 25 2010, 11:27 AM
Smiffy I'm with you there, would never sell my copy e... May 25 2010, 05:47 PM
Obi-Jiff Kenobi It's extremely comprehensive - it's the on... May 25 2010, 07:03 PM
Mike QUOTE (Obi-Jiff Kenobi @ May 25 2010, 08... May 25 2010, 07:19 PM
Obi-Jiff Kenobi Always two there are; Ewoks: Caravan of Courage, a... May 25 2010, 07:33 PM
daz greenwood Yup and I have both on DVD May 25 2010, 07:35 PM
Mike Strewth... I'd have thought one was bad enough... May 25 2010, 07:44 PM
Obi-Jiff Kenobi Mike, did you know there was an Ewoks cartoon seri... May 26 2010, 07:32 AM
Mike QUOTE (Obi-Jiff Kenobi @ May 26 2010, 08... May 26 2010, 07:57 AM
Madmonk Mike,
I hope you have not stopped this excellent ... May 26 2010, 08:53 AM
Mike QUOTE (Madmonk @ May 26 2010, 09:53 AM) I... May 26 2010, 09:15 AM
Mike She's done
The rest of the pics can be fou... May 26 2010, 06:07 PM
Obi-Jiff Kenobi Nice work, Mike. Now all you need is to scratch bu... May 27 2010, 07:36 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd September 2010 - 04:17 AM |
