IPB
Welcome Guest ( Log In | Register )
> Millennium Falcon (1:144 Finemolds), #### Finished ####
Mike
post May 12 2010, 06:44 PM
Post #21
Proud dad
Group Icon
Group: Root Admin
I was sat idly at my bench after lunch, feeling a bit spaced out and listless. It must have been the space that did it... I began my first sci-fi build since I was a teenager. The new Millennium Falcon from Finemolds. happy.gif
Have a quick read of the review here to see my initial thoughts on the kit if you like. I don't mind waiting wink.gif
Well... first item for work was to clean up the central sprues that sit in the middle of the two hull parts. Easy to do, and so I moved on to snippiing off a couple of the round equipment bay inserts on the cargo jaws up front. Because of the way they're sprued up, all you have to do is nip them close to the attachment lugs and clip them in. They really are THAT good a fit. A little dribble of liquid glue, and some pressure for a short while, and we're done. The same process was used for all of the many inserts, the detail of which is excellent! No shadow of a doubt, the detail is the crispest (as previously mentioned in the review), and extra spruelets have been added around the edges to ensure that the detail gets a full fill of styrene during the moulding process. Well worth the effort of nipping them off.
I had a few misgivings about simply gluing the side walls into the bottom of the hull, as I felt that if I didn't get them perfectly square, it could cause fit issues with the upper hull when it came time to close it up. As a precaution, I installed a few parts, and did a test fit - no problems encountered at all, as the mounting lugs are precise, so I ploughed on. Here you should take the time to remove any mould seams on the edges of the parts, as although you can't see some of them, others are on view.
The instructions show you attaching the big round endy things (yes, those again) being attached later in the build when the hull is joined. I didn't want to have any hull parts lying around to be painted off the hull, so I joined them to the bottom half, again, checking alignment by test fitting the top hull as I went along. Everything fits beautifully, and I will be able to keep the two hull parts separate until after painting, so I can paint the cargo jaws insides easily with my airbrush. The cockpit amd crew tube would also be able to be click-fitted later if you so choose, but I suspect I'll be attaching mine once I have the cockpit painted, which fits INSIDE the tube parts, so can't be left off until later.
So how does it look so far? Good... the build has been a breeze, and I think has taken me about 30 minutes so far. The quality of the moulding really shows in the speed and ease of construction smile.gif
That chunk of blutak was just there to hold a joint closed while the glue set.
The front panel of the jaws locks the two halves of the hull together, so would have stopped me from splitting it for painting, so I lopped off the lugs from the top of the hull to solve that issue. I clipped the hull halves together while the glue set though, just to make sure they ended up in the right place.
I've also built up the antenna and am working on the cockpit area now. Just need some refs... Jeff? smile.gif
Go to the top of the page
+Quote Post
Posts in this topic
- Mike   Millennium Falcon (1:144 Finemolds)   May 12 2010, 06:44 PM
- - Obi-Jiff Kenobi   Great links, Paul. I think they supercede my refer...   May 14 2010, 07:52 AM
- - Mike   Will do Jeff.   May 14 2010, 08:27 AM
- - Mike   Funny... I've just had a look through all the ...   May 14 2010, 12:43 PM
- - Madmonk   Mike, Damage looks good and ties in with shot in ...   May 14 2010, 01:28 PM
- - Mike   Polly S and the brand Floquil are now owned by Tes...   May 14 2010, 02:55 PM
- - daz greenwood   Hi Mike! When I built the old AMT one I paint...   May 14 2010, 02:56 PM
- - Mike   I'll have a look at the various light gull gre...   May 14 2010, 03:04 PM
- - daz greenwood   Go for it Mike!   May 14 2010, 03:06 PM
- - Mike   I bit the bullet and painted the cockpit today - a...   May 14 2010, 03:57 PM
|- - Pilgrim_UK   I though one of those special "sculpting a ga...   May 14 2010, 05:54 PM
- - Smiffy   QUOTE (Mike @ May 13 2010, 10:13 PM) Chee...   May 14 2010, 06:31 PM
- - Mike   Thanks Paul - I've added a scraggy looking str...   May 14 2010, 07:40 PM
- - Mike @ Two Mikes Resin   WOW!! I didn't realize Fine Molds made...   May 14 2010, 07:50 PM
- - Mike   Dumbass... Seriously though, it's a very easy ...   May 14 2010, 07:59 PM
- - Mike   I got round to putting the first layer of paint on...   May 15 2010, 09:22 PM
- - Obi-Jiff Kenobi   Impressive, most impressive. Obi-Jiff   May 16 2010, 09:04 AM
- - Smiffy   "I want that ship"   May 16 2010, 04:37 PM
- - The Sheene Machine   This is looking very nice Mike - good call on the ...   May 17 2010, 07:37 AM
- - Mike   Cheers guys - I've started putting the decals ...   May 17 2010, 11:13 AM
- - Madmonk   Mike, shouldn't that be unsurprisingly good, t...   May 17 2010, 11:27 AM
- - Andy Mullen   Looking good Mike Slightly dissapointed you are n...   May 17 2010, 12:45 PM
- - markmarples   thats cool nice find andy, come on mike some more ...   May 17 2010, 01:09 PM
|- - Obi-Jiff Kenobi   QUOTE (markmarples @ May 17 2010, 02:09 P...   May 17 2010, 02:54 PM
- - markmarples   no just trying to convince the wife to let me buy ...   May 17 2010, 04:54 PM
- - Mike   I'm currently running my PC on Ubuntu, so can...   May 17 2010, 04:59 PM
- - markmarples   are we nearly there yet!!! ...   May 17 2010, 05:01 PM
- - Smiffy   QUOTE (Obi-Jiff Kenobi @ May 17 2010, 03...   May 17 2010, 06:26 PM
- - Mike   Ok... flipped back to Windows so I could get a fix...   May 17 2010, 08:43 PM
- - daz greenwood   Looking very nice Mike!   May 17 2010, 08:44 PM
- - markmarples   looking good, is it as easy to build as it looks, ...   May 17 2010, 08:46 PM
- - Mike   Thanks guys Mark - it's a piece of cake to b...   May 17 2010, 08:54 PM
- - markmarples   ok im convinced, as soon as pay day arrives im ord...   May 17 2010, 09:00 PM
- - Mike   Make sure you do and don't forget a WIP threa...   May 17 2010, 09:02 PM
|- - markmarples   QUOTE (Mike @ May 17 2010, 10:02 PM) Make...   May 17 2010, 09:07 PM
- - Mike   The cockpit will be very fiddly to light - it...   May 17 2010, 09:08 PM
- - Mike @ Two Mikes Resin   Looking very nice Mike! I can't wait to se...   May 17 2010, 09:10 PM
|- - Mike   QUOTE (Mike @ Two Mikes Resin @ May 17 2010, ...   May 17 2010, 09:40 PM
- - markmarples   ill see what its like but fiber optics only need t...   May 17 2010, 09:11 PM
- - periklis_sale   looking great mate!   May 18 2010, 05:17 AM
- - Mike   The first round of weathering was done this evenin...   May 21 2010, 08:56 PM
|- - TonyT   Actual model for reference http://www.starshipmod...   May 21 2010, 10:27 PM
- - denstore   Nice!   May 21 2010, 08:58 PM
- - Tabio   Cool, she's the fastest hunk of junk in the ga...   May 21 2010, 09:22 PM
- - Mike @ Two Mikes Resin   The color looks spot on from my recollection of th...   May 21 2010, 10:04 PM
- - Mike   Thanks guys - plenty more weathering left to do   May 22 2010, 08:59 AM
- - The Sheene Machine   Loving that - weathering has already added some ni...   May 22 2010, 11:19 AM
- - Mike   Stage 2 of the weathering process was done this av...   May 22 2010, 03:42 PM
- - Smiffy   Coming along nicely. This ship's all about ...   May 22 2010, 04:01 PM
- - Mike   Cheers Paul - another 3 or 4 stages left yet, incl...   May 22 2010, 04:31 PM
- - daz greenwood   Looking good Mike I can't wait to see it all w...   May 22 2010, 04:34 PM
- - Mike   I cheated this avo and did stages 2 and 3 together...   May 23 2010, 04:02 PM
- - Obi-Jiff Kenobi   Looking great, Mike. The weathering is really brin...   May 23 2010, 06:06 PM
- - markmarples   looks great mike, keep it coming   May 23 2010, 06:11 PM
- - Antony Robertson   Looking good Mike, cant wait to see her finished...   May 23 2010, 06:13 PM
- - Mike   Thanks guys Makes me wish I'd got a 1:72 scal...   May 23 2010, 07:02 PM
- - gunpowder17   Fantastic Mike. Its more complex to weather than y...   May 23 2010, 08:36 PM
|- - Mike   QUOTE (gunpowder17 @ May 23 2010, 09:36 P...   May 23 2010, 08:41 PM
- - gunpowder17   Thats the problem. Look too closely at the props a...   May 23 2010, 09:05 PM
- - TonyT   I never ever follow references for paint and weath...   May 24 2010, 01:18 AM
- - Smiffy   "Allllmost there" QUOTE (Mike @ M...   May 24 2010, 09:55 PM
- - Mike   Oh yeah, I'm sure they've been thru hell ...   May 24 2010, 10:51 PM
- - daz greenwood   Hi Mike! This is the Star Wars Chronicles boo...   May 24 2010, 11:04 PM
- - Obi-Jiff Kenobi   Some people find solace and meaning in the Bible -...   May 25 2010, 07:38 AM
- - Mike   Never even seen that book. When was it released, ...   May 25 2010, 09:32 AM
- - Obi-Jiff Kenobi   It was originally a Japanese book, mid-1990s, then...   May 25 2010, 11:24 AM
- - Mike   They go for silly money now... £300 on Amazon thro...   May 25 2010, 11:25 AM
- - Obi-Jiff Kenobi   Despite having no money to my name, I'm not ev...   May 25 2010, 11:27 AM
- - Smiffy   I'm with you there, would never sell my copy e...   May 25 2010, 05:47 PM
- - Obi-Jiff Kenobi   It's extremely comprehensive - it's the on...   May 25 2010, 07:03 PM
|- - Mike   QUOTE (Obi-Jiff Kenobi @ May 25 2010, 08...   May 25 2010, 07:19 PM
- - Obi-Jiff Kenobi   Always two there are; Ewoks: Caravan of Courage, a...   May 25 2010, 07:33 PM
- - daz greenwood   Yup and I have both on DVD   May 25 2010, 07:35 PM
- - Mike   Strewth... I'd have thought one was bad enough...   May 25 2010, 07:44 PM
- - Obi-Jiff Kenobi   Mike, did you know there was an Ewoks cartoon seri...   May 26 2010, 07:32 AM
|- - Mike   QUOTE (Obi-Jiff Kenobi @ May 26 2010, 08...   May 26 2010, 07:57 AM
- - Madmonk   Mike, I hope you have not stopped this excellent ...   May 26 2010, 08:53 AM
|- - Mike   QUOTE (Madmonk @ May 26 2010, 09:53 AM) I...   May 26 2010, 09:15 AM
- - Mike   She's done The rest of the pics can be fou...   May 26 2010, 06:07 PM
- - Obi-Jiff Kenobi   Nice work, Mike. Now all you need is to scratch bu...   May 27 2010, 07:36 AM
Reply to this topicStart new topic
3 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 3rd September 2010 - 04:16 AM
