AnonymousDFB1 Posted August 4, 2011 Share Posted August 4, 2011 Hi Peter, This was the first engine I have ever wired and it was very simple. First I drilled the ignition ring where the ignition wires run from, then I drilled out the spark plugs front and read. Next I CA glued some sleeving from some thin wire into the cylinders to represent spark plugs, then I run some 0.4mm lead wire from the 'spark plugs to the ignition ring. It really is as simple as that. Link to comment Share on other sites More sharing options...
oldhouse Posted August 7, 2011 Author Share Posted August 7, 2011 Hi Peter,This was the first engine I have ever wired and it was very simple. First I drilled the ignition ring where the ignition wires run from, then I drilled out the spark plugs front and read. Next I CA glued some sleeving from some thin wire into the cylinders to represent spark plugs, then I run some 0.4mm lead wire from the 'spark plugs to the ignition ring. It really is as simple as that. Hi Mish, thank you very much for your help, will try do do it on the next Kit !! Peter Link to comment Share on other sites More sharing options...
oldhouse Posted August 7, 2011 Author Share Posted August 7, 2011 Is there anything I could teach you Pierre?Nice engine. I especially like the crankcase painting. Dirt, grease and scratches - perfect. I've been forgetting that brown grease personally, and it does make a difference. Hi Don ! yes there is somethig to teach me.... a little bit more of patience !!!! anyway, if you ever stay in Switzerland you are welcome in my house !! Peter Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted August 7, 2011 Share Posted August 7, 2011 Hi Don ! yes there is somethig to teach me.... a little bit more of patience !!!!anyway, if you ever stay in Switzerland you are welcome in my house !! Peter I'd love to see Switzerland one day. I will make a note of your invitation. You are welcome here also, though you may find the Derbyshire hills a little tame! Link to comment Share on other sites More sharing options...
oldhouse Posted August 14, 2011 Author Share Posted August 14, 2011 Hi Folks, after priming, engraving, sanding and washing my model , the lady is ready for the make up ... nearly finished the underside using Gunzes Mr Color Japanese Aircraft grey-green Nr 128 the first layer i use was a darker color as the Basic Color, so i can more and more work out the lihgts and the shadows on the plane brighten up the Base Color. Cheers Peter Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted August 14, 2011 Share Posted August 14, 2011 That's an interesting and varied underneath. I like that a lot. Link to comment Share on other sites More sharing options...
oldhouse Posted August 18, 2011 Author Share Posted August 18, 2011 Hi all just finished the Base Color of the upperside of my model !! Colors used : Base Coat Coat : Gunze 304 Olive Drab FS 34087 darkened with Gunze 77 Tyre Black Shadows : Gunze 77 Tyre Black Light : Gunze 304 Olive Drab with Vallejos 35 Light Brown and 33 Vallejo Ochre Peter Link to comment Share on other sites More sharing options...
oldhouse Posted August 30, 2011 Author Share Posted August 30, 2011 Hi all. the painting of a model is always the magic moment for me, the plastic comes to live !! for the first time i used Gunze Acryl and Gunze Mr Color Enamels and must say the looking great ! The Hinomarus were sprayed with the help of some Montex masks !! Hope you like it Peter Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted August 30, 2011 Share Posted August 30, 2011 Wow! What a transformation. The Hinomaru are brilliant with the pre-shading. They really look like blood. Painted markings are so much better than decals aren't they? I think I might send off for some Frisk film and do some more experimenting with this. Link to comment Share on other sites More sharing options...
Moofles Posted August 30, 2011 Share Posted August 30, 2011 beautiful looking model, cannot wait to see it finished. Link to comment Share on other sites More sharing options...
oldhouse Posted August 30, 2011 Author Share Posted August 30, 2011 Wow! What a transformation. The Hinomaru are brilliant with the pre-shading. They really look like blood. Painted markings are so much better than decals aren't they? I think I might send off for some Frisk film and do some more experimenting with this. Hi Don Yes i agree with you, the painted markings looks much more lifelike and realistic in comparison with Decals !! Regards Peter Link to comment Share on other sites More sharing options...
oldhouse Posted August 30, 2011 Author Share Posted August 30, 2011 beautiful looking model, cannot wait to see it finished. Hi Moofles, thanks a lot for your kind words. Sad to say that you must wait to the finished model a little bit, because i will enjoy my holidays in Greece next week !! Cheers Peter Link to comment Share on other sites More sharing options...
jimbuna Posted August 30, 2011 Share Posted August 30, 2011 Coming along nicely. Link to comment Share on other sites More sharing options...
Ian Posted August 30, 2011 Share Posted August 30, 2011 Like peas in a pod ! Ian Link to comment Share on other sites More sharing options...
oldhouse Posted September 16, 2011 Author Share Posted September 16, 2011 Hi everyone !! Started the weathering on the Topside yesreday, wil ltray to work out a battered outfit on this aircraft !! Cheers Peter Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted September 16, 2011 Share Posted September 16, 2011 Wow! That's the way to do it! Link to comment Share on other sites More sharing options...
oldhouse Posted September 18, 2011 Author Share Posted September 18, 2011 Wow! That's the way to do it! Hi Don, thanks for your support, i really need it, this work is on a very thin line !! too much or to less thats the question !! hope to finish it tomorrow !!! Cheers Peter Link to comment Share on other sites More sharing options...
oldhouse Posted September 23, 2011 Author Share Posted September 23, 2011 Hi all , just finished the painting and weathering of my Hayate Fighter !! Hope you like it !! tomorrow i take part on the IPMS Swiss Nationals in Basel ! Wiil make som pics for sharing on BM !! Cheers Peter !! Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted September 23, 2011 Share Posted September 23, 2011 Very very good painting. I like the way you are weathering the hinomaru. It looks very real. Link to comment Share on other sites More sharing options...
smuts Posted September 24, 2011 Share Posted September 24, 2011 great weathering,looks great! Andy Link to comment Share on other sites More sharing options...
Chris FFZ Posted September 24, 2011 Share Posted September 24, 2011 Pre-shading with the airbrush really is a powerful technique, there is just no easy way to get that effect without it. Link to comment Share on other sites More sharing options...
CliffB Posted September 25, 2011 Share Posted September 25, 2011 Well this is turning into something rather special! Cliff Link to comment Share on other sites More sharing options...
oldhouse Posted September 25, 2011 Author Share Posted September 25, 2011 Hi Don, Andy , Chris and Cliff !! Thank you yery much for watching and your words !! It is done and the result is finally ok for me !! think i will finish the model till the end of next week !! A little appetizer from the IPMS Swiss Nationals in Basel this weekend just for you !! will share more pics of this event next week !! Kind regards Peter Link to comment Share on other sites More sharing options...
oldhouse Posted September 29, 2011 Author Share Posted September 29, 2011 Hi Folks, after 3 fine layers of Erdal Clear i just finished the setting of the Topside Decals. as you can see the color of the Decals is darker as the indicated color i sprayed with the Airbrush. there are to ways to go, i spray the correct color or i lrt it like it is ! Whats your opinion ?? Peter Link to comment Share on other sites More sharing options...
jimbuna Posted September 29, 2011 Share Posted September 29, 2011 Looking very nice. Link to comment Share on other sites More sharing options...
