LanceR21 Posted May 12, 2011 Share Posted May 12, 2011 Good evening, A few hours ago, I started another MiG-21... tihs time, it's a Condor kit, not so bad. I'm working on this kit just because I want to test Hasegawa Trytool. So far, so good... Cheers, Nenad Link to comment Share on other sites More sharing options...
Deon Posted May 12, 2011 Share Posted May 12, 2011 Massive improvement with the rescribing and good luck with this project Link to comment Share on other sites More sharing options...
mrcooljules Posted May 13, 2011 Share Posted May 13, 2011 looking forward to seeing this develop. always wanted to rescribe a couple of kits with tools like that Link to comment Share on other sites More sharing options...
Miroslav Posted May 14, 2011 Share Posted May 14, 2011 Extra work. Bravo! Link to comment Share on other sites More sharing options...
LanceR21 Posted May 15, 2011 Author Share Posted May 15, 2011 Thank you Miroslave! What's going on with your MiG-21? Any progress? Panel lines are almost complete, next time pictures of the cockpit and the landing gear... Cheers, Nenad Link to comment Share on other sites More sharing options...
Muller Posted May 17, 2011 Share Posted May 17, 2011 I've never rescribed a whole kit, only what I've sanded off, what kind of tool did you use to scribe the lines? It looks great so far! Link to comment Share on other sites More sharing options...
sig226 Posted May 17, 2011 Share Posted May 17, 2011 I've never rescribed a whole kit, only what I've sanded off, what kind of tool did you use to scribe the lines? It looks great so far! Nenad.......maybe you should do a quick 'How to' as regards the scribing......looks very impressive mate Regards Simon Link to comment Share on other sites More sharing options...
Muller Posted May 17, 2011 Share Posted May 17, 2011 Should have read the 1st post a bit closer, Nenad mentions a Trytool I have a MMS-USA scriber, it's not great for scribing circles, the Hasegawa tool looks better for doing them. I'm interested 'cos I have a 1/48 Revell Marauder I want to rescribe. Link to comment Share on other sites More sharing options...
LanceR21 Posted June 21, 2011 Author Share Posted June 21, 2011 Ok, finally some progres, I used two types of riveters and single needle. I tried to convey the details from tech. drawings to model as faithfully as possible. Well, seen from the other side, I just wanted to test new riveter and some new techniques of engraving panel lines. I'm satisfied with final result... I have a spare canopy from Zvezda Bis, so I'll use that one... Cheers, Nenad Link to comment Share on other sites More sharing options...
Deon Posted June 21, 2011 Share Posted June 21, 2011 Looking very nice, professional quality Link to comment Share on other sites More sharing options...
Andrew Posted June 22, 2011 Share Posted June 22, 2011 Great progress, Nenad. You've done a wonderful job on the rescribing; it really adds to the 'look' of your model. I'm keen to see how the rest unfolds, if your work thus far is any indication! Would you mind illustrating or describing what work you've done on the intake? Cheers, Andrew. Link to comment Share on other sites More sharing options...
gfurm Posted June 22, 2011 Share Posted June 22, 2011 Good job so far. Just one question: how do you remove the dust from rescribed panel lines? I'm doing Condor Foxbat at the moment and can't get rid of all that dust from rescribed lines. Greg Link to comment Share on other sites More sharing options...
LanceR21 Posted June 23, 2011 Author Share Posted June 23, 2011 (edited) Great progress, Nenad.You've done a wonderful job on the rescribing; it really adds to the 'look' of your model. I'm keen to see how the rest unfolds, if your work thus far is any indication! Would you mind illustrating or describing what work you've done on the intake? Cheers, Andrew. Thank you! Work on intake, well... nothing special, I just lost the original part, so I made new one from plastic. Good job so far. Just one question: how do you remove the dust from rescribed panel lines? I'm doing Condor Foxbat at the moment and can't get rid of all that dust from rescribed lines.Greg After rescribing, I used to sand panel lines on dry, without water until they are completely white, as you can see on previous pictures. Then i left them for 24h and rescribe again, just to remove the dust. Final step is with Tamiya glue, I just get across them with it and let to dry 48h. Hope I helped you. Cheers, Nenad Edited June 23, 2011 by LanceR21 Link to comment Share on other sites More sharing options...
LanceR21 Posted June 27, 2011 Author Share Posted June 27, 2011 These are latest pictures of sanding and bonding process. Next step, preshading and painting... Cheers, Nenad Link to comment Share on other sites More sharing options...
