Airliners / Hasegawa 1/200th
Hello,
It's a long time since I haven't put anything down here.
Some might have wondered what I was doing.
After working on this :
http://www.britmodel...showtopic=28962
Then more with this :
and this :
The old 737-200 was missing in the series.
So I carried on cutting and filing until I came to this result.
Here is what I managed to do, trying to build how this tricky system works.
More here :
or here :
http://www.britmodel...showtopic=27888
http://www.britmodel...showtopic=27699
and here :
http://www.britmodel...showtopic=27684
http://www.britmodel...showtopic=27926
http://www.britmodel...showtopic=27663
http://www.britmodel...showtopic=27617
http://www.britmodel...=modern trijets
Edited by AV O
  • Like 18
like them :)...and in 1/200 scale
ever thought of opening some doors and putting some interiors in?
  • 2 months later...
  • 1 month later...
Good evening all !
The Airbus A300 is now completed. It has not been without trouble.
This one being the first one, I fumbled to decide how to handle the wing and set which order to fix the elements on :
Every little movement causing a piece previously glued to fall down (Slats and spoilers have a very small contact surface) !!!
Holding it too tight causing the finger prints miserably printing !
Edited by AV O
The 737-200 has landed too. (Hasegawa 1/200 - decals : Jet Decals)
I messed up with the reverses (on the pictures above), so I reworked them.The exhaust body was too short and the buckets were intermeshing with the flaps.
I had to work on the flaps as well. On the 737-200 a small part remains attached to the engine pylon while moving back.
Yes, the landing is very short this time again.
It is because the buckets were not visible on the runway, but are on the stripes background.
Thanks to Richellis and cuprar who contributed and helped me in the to the process of matching painting colours.
Edited by AV O
are the leading edge slats temporary?
the gap between the slats and wing looks a bit too much.
Yes, this fit is temporary. The fuselage is not painted : adjusting the rods length is necessary, as is putting two engines of the same kind before completion !
  • 5 months later...
A few more pictures of the 777-200.
You will certainly notice as I did that I have inverted the engines (the strake being outboard instead of inboard as on the real aircraft) :
Edited by AV O
  • 1 month later...
  • 3 months later...
Following on :
A loooong time ago, Daco granted us with a B-737-300 in 1/144th scale and to go along with it, beautiful sets of decals for Western Pacific airplanes. They were also released in 1/200th scale. The major problem is that, as it has been said, Hasegawa released the B-737 in both -500 and -400 types, but as no Japanese airline used the -300, this type never came out.
The solution was to customize and shorten a -400. The method proposed in an other thread may be a good one. I used my own, having been satisfied with it when I made the Aéropostale 737-300 (see above).
I am not fully satisfied with the result, as the decals are rather thick (and tend to break when drying on sharp curves) and have quite a lot of overlapping areas.
Softening liquid is required.
Daco instructions apply for its own version (1/144), and he probably had no chance to try them on this model !
Therefore, concerning some areas, these instructions are not suitable for the Hasaegawa’s.
Unfortunately, I realized it to late, the decals already wet and on the kit, which explains they are a little wrinkled and damaged at some places as I had to remove them (with the damages and the rage you can imagine).
So the result in the back part around the fin and the back door is not accurate if you compare it with a picture of the real airplane. The orange shape aft of the wing is also set too low.
But I was satisfied with the way I made the fuselage cuts as the windows and other decals fit on the fuselage.
On this very type, the problem with the decals occurs in the back part. On this kit, the horizontal tail is one piece and is set through the fuselage, while the vertical tail comes last to lock it from the top.
The tail decals must be applied first with the vertical tail on, then cut around the base of it, make the slots for the horizontal tail to go through, remove the fin and then assemble the tail elements back together. This last stage can wait until the end. This will apply for other decals such as The Simpsons.
The decal sheet is full of tiny details and you'll need a lot of patience to look out for the numbers and the order they must be put on.
I have a spare set and intend to make the next one a perfect one. But Broadmore seems to be a nice option too. What about the Simpsons ! You just the need too many 737s.
I can reassure those who made this kit before on one point : the rings removed from the -400 can be used on a -500 to build a-300.
Edited by AV O
  • 4 weeks later...
There looking good.
How many have you built now?
In the full flap configuration, one of each type as you can see.
For others, see the links mentioned in the top message.
  • 2 months later...
Superb creations...not sure about the 'runway' though.
