RICHW Posted December 29, 2010 Share Posted December 29, 2010 (edited) i have had a Zvezda Boeing 767-300 in my stock for quite a while , when i ordered a set of decals last week through drawdecals he sent me the wrong set and i ended up with this set below instead of the Delta Skyteam one which was meant for the 767-400 i already have painted up so that got me decided on starting another 767-400ER conversion , last time i used the Braz Models conversion , but this time im going for the cheaper option using pieces of plastic pipe that fit inside the fuselage to make the extensions i needed to add 24mm in front of the wing and 21.5mm behind the wing onto those lengths i added 30mm so i have 15mm either side to push inside the fuselage i found 1" PVC pipe to be perfect for the job the two pieces of PVC pipe cut and ready i first laid them inside the fuselage to see what kind of a fit they were the nose section with the first plug in position i now have to glue up the sections and line them up , then fill the gaps with milliput and sand them flush, i also need to get some raked Wingtips made for the wings IF ANY OF YOU HAVE A GOOD PAINT MATCH FOR THIS PINK PLEASE LET ME KNOW WHAT IT IS More to follow Richard Edited June 30, 2011 by RICHW Link to comment Share on other sites More sharing options...
atdb27 Posted December 29, 2010 Share Posted December 29, 2010 Looks nice so far and a nice 'scheme'! Have sent a note to Delta for info on the paint. Adrian Link to comment Share on other sites More sharing options...
RICHW Posted December 29, 2010 Author Share Posted December 29, 2010 Looks nice so far and a nice 'scheme'!Have sent a note to Delta for info on the paint. Adrian thanks for that i didnt even know there was a decal for that scheme untill it turned up with the Frontier sheet Richard Link to comment Share on other sites More sharing options...
RICHW Posted December 30, 2010 Author Share Posted December 30, 2010 managed to get the fuselage built back up today using the extension plugs front nose section now attached to central section of Fuselage the whole 767-400 glued back together just needs the gaps filling now and sanding back flush and also the windows skimming over with some filler , i did blank some of the windows off using the clear parts that Zvezda provide had to leave some out near the joins otherwise the pipe would not fit inside the fuselage I actually like the way Zvezda do the wings cause it enables you to line the fuselage up more accuratly when gluing the fuselage back up cause you can have the wings clipped in place when glueing Richard Link to comment Share on other sites More sharing options...
RICHW Posted January 1, 2011 Author Share Posted January 1, 2011 Fuselage joined and filled using Milliput needs sanding back Richard Link to comment Share on other sites More sharing options...
RICHW Posted January 8, 2011 Author Share Posted January 8, 2011 Got the raked wingtips made this week from a template i already had these are the finished tips cut out of 2mm thick Stainless steel sheet made them thinner than the thickness of the wing so i could fill them and sand them back flush to the wing i then attached them to the ends of the wings using loctite super glue closer view of the tips attached and sanded back i have also sanded back the filler on the front fuselage plug to make it flush to the rest of the fuselage got the back one to do now more to follow Richard Link to comment Share on other sites More sharing options...
RICHW Posted March 6, 2011 Author Share Posted March 6, 2011 Hi i have got a bit more work done on the 767-400ER over the past couple of weeks given it a coat of white paint and had to add a bit more filler in places hopefully the next coat of white should be the last Richard Link to comment Share on other sites More sharing options...
RICHW Posted March 21, 2011 Author Share Posted March 21, 2011 Painted the Fuselage just got the tail to do decided to paint the model in UNITED livery ( i am going to use Drawdecal set) as i already have a Delta one Richard Link to comment Share on other sites More sharing options...
richellis Posted March 22, 2011 Share Posted March 22, 2011 nice, just seen a set of these decs on e-bay and Im so tempted! Link to comment Share on other sites More sharing options...
cuprar Posted March 22, 2011 Share Posted March 22, 2011 nice, just seen a set of these decs on e-bay and Im so tempted! Lol hands off Richard, they are mine. They are from this Richard. May the best man win Link to comment Share on other sites More sharing options...
RICHW Posted March 26, 2011 Author Share Posted March 26, 2011 Just finished painting the fuselage now attached some of the landing gear today i have to say they Zvezda Landing gear seems to be a lot easier to attach than the Revell Ordered the decals from Drawdecal the other day along with the Delta Skyteam 767-400 so i can finish that one i have had built nearly 2 years with no livery on Richard Link to comment Share on other sites More sharing options...
cuprar Posted March 26, 2011 Share Posted March 26, 2011 Very nice Richard, how many watchers on your delta set on eBay? Still think you should let me have them now, I am the only bidder on them as well...lol Link to comment Share on other sites More sharing options...
Graeme H Posted March 27, 2011 Share Posted March 27, 2011 Loooking very good so far, I have to hand it to you, sanding off all that Milliput on the fuselage plugs, looked like some weird growths. I take that is the new United scheme you are doing? Graeme Link to comment Share on other sites More sharing options...
Kev1n Posted March 27, 2011 Share Posted March 27, 2011 must be....continental/united merger as UA dont have any 764's do they? Link to comment Share on other sites More sharing options...
FLCH Posted March 27, 2011 Share Posted March 27, 2011 (edited) No UA doesn't have 767-400's ours are slowly being assimilated into the UA fleet, we've been told that we are getting rid of our 767-200's so those will be a thing of the past too, pity as they were the rocket ships of the 7576 fleet. Edited March 27, 2011 by FLCH Link to comment Share on other sites More sharing options...
RICHW Posted March 27, 2011 Author Share Posted March 27, 2011 Loooking very good so far, I have to hand it to you, sanding off all that Milliput on the fuselage plugs, looked like some weird growths.I take that is the new United scheme you are doing? Graeme Yes it is the New United scheme i am doing Link to comment Share on other sites More sharing options...
RICHW Posted May 10, 2011 Author Share Posted May 10, 2011 Just got my new set of Drawdecals United 767-400ER decals after totally messing the first set up just about finished doing the right side the reason for the gold stripe not meeting is cause there was not enough supplied with the decal set i have informed Greg at Drawdecal and he has allowed more gold stripe on the new set Right side just about finished more to follow Richard Link to comment Share on other sites More sharing options...
RICHW Posted May 14, 2011 Author Share Posted May 14, 2011 Hi Guys got the left side decal on this week just need to put another coat of paint on the main wings close up on the tail logo Richard Link to comment Share on other sites More sharing options...
RICHW Posted June 30, 2011 Author Share Posted June 30, 2011 Finally i have finished the model here are a couple of pics Richard Link to comment Share on other sites More sharing options...
cuprar Posted June 30, 2011 Share Posted June 30, 2011 Looks sweet Richard. Another great build buddy Link to comment Share on other sites More sharing options...
