Candyman Posted November 14, 2010 Author Share Posted November 14, 2010 Thanks mister I think i got it, So cut this piece down quite a bit as the screen kept catching on it (so little room in here) attached the sprngs to the front of the U. A lot of work in here, lot of trial and error. The screw on the end of the brass bar stops the bar going to far. The little screw up by the screen end just clears the 2 on the bracket (holding the bar in place) when the screen is retracted it passes them then catches the recess in the U shaped piece, pulling it back. Then when the brass bar is all the way back it meets the back of the head where the cut out is and the U shaped bit is pulled back against the head. This is enough to pull the doors shut with a little tension on them. Just bellow where the brass rod is there is a hole that I can fit the tube... like so, had to trim the U piece even more as it'd catch on the tube. The wire feeds out and attaches to the pivot on the end of the brass rod. As the wire feeds out it pushes the brass rod out, then it extends fully it pushes on the pivot and flips open. Bottom line is it kinda works, just need to refine a little more then i'll get a video up. Link to comment Share on other sites More sharing options...
Candyman Posted November 15, 2010 Author Share Posted November 15, 2010 test video of the head Link to comment Share on other sites More sharing options...
Skii Posted November 15, 2010 Share Posted November 15, 2010 test video of the head You Sir are a freakishly talented individual. That mechanism looks spot on, I can't believe you have got that mechanism to work in that confined amount of space . Amazing fella, amazing. Link to comment Share on other sites More sharing options...
Obi-Jiff Kenobi Posted November 16, 2010 Share Posted November 16, 2010 This is really terrific stuff. Obi-Jiff Link to comment Share on other sites More sharing options...
lexesbeanz Posted November 16, 2010 Share Posted November 16, 2010 I'm drooooooooling Please for the love of god tell me that you are planning on making a few copies of this for sale? I have been looking for a Cain kit for 13 years with no luck. And then I saw your astounding work!! Link to comment Share on other sites More sharing options...
Cimmerian Posted November 17, 2010 Share Posted November 17, 2010 Seriously, are you doing all the fabrication with just that lathe and that mill? Incredible!! Cant believe I never saw this thread until now, Cain is one of my fav robots, and you sir are an incredible talent. Cant wait to see him finished up! Link to comment Share on other sites More sharing options...
Candyman Posted November 17, 2010 Author Share Posted November 17, 2010 Seriously, are you doing all the fabrication with just that lathe and that mill? Thank you, yes I am. Link to comment Share on other sites More sharing options...
Cimmerian Posted November 17, 2010 Share Posted November 17, 2010 I wish I had a lathe and a mill, and a studio scale cain Link to comment Share on other sites More sharing options...
Candyman Posted November 17, 2010 Author Share Posted November 17, 2010 moving onto the other end of the cable, gong to make a sort of worm drive to move the wire up and down got me a little motor and a pully from somewhere. Motor turns the big pully which is on the thread/screw. The lump of metal on the right has a thread tapped in it and is stopped from spinning round by the 2 poles, it has no alternative than to move up and down the thread. had to do some more work on the colar to get it to meet the head flush, even though it'll be lifted off the collar. in place and nearly working, had to modify again, needed a lot more tension on the rubber band thing. It was a bit loose, lost traction and spun, the pulley on the motor got so hot it melted! so now made a lottle alloy pully you can just see it, good huh? Link to comment Share on other sites More sharing options...
MakingModelsAgain Posted November 18, 2010 Share Posted November 18, 2010 It's rare to see a model that actually looks better than the real thing, but that's what's unfolding here! Link to comment Share on other sites More sharing options...
Candyman Posted November 18, 2010 Author Share Posted November 18, 2010 thanks, appreciate that Link to comment Share on other sites More sharing options...
Candyman Posted November 20, 2010 Author Share Posted November 20, 2010 I took the head apart and started to rub down all the rough edges and smooth the surface out, taking out all the machining marks. test fitted to the torso, started to turn the cylinders for The back of the head, im going to fit them as close to the head as I can. and drum roll please! I got my screen! This is the OLED (organic LED) from Australia, took me hours to get to grips with the software and finally get a proper image on the screen, now I know it works I can get on with editing a longer sequence and editing the colours down a bit. I know this looks a little odd but its good for a trial run! hey cain, whats happening! Link to comment Share on other sites More sharing options...
Skii Posted November 20, 2010 Share Posted November 20, 2010 oooh WOW !! Where did you get the animation from ? Link to comment Share on other sites More sharing options...
xffw45343tg Posted November 20, 2010 Share Posted November 20, 2010 Outstanding! Link to comment Share on other sites More sharing options...
Candyman Posted November 20, 2010 Author Share Posted November 20, 2010 oooh WOW !!Where did you get the animation from ? cut a little bit from the film, will do a full sequence soon. Link to comment Share on other sites More sharing options...
Mike Posted November 20, 2010 Share Posted November 20, 2010 Fabulous! Link to comment Share on other sites More sharing options...
Candyman Posted November 21, 2010 Author Share Posted November 21, 2010 Had to re mount the plate in the collar since re-shaping the collar. mounted more securly now with a proper joint so I can adjust the head, also finished and mounted the head hydraulics, considering they attach to the bottom of the head ather than inside the head I think they look good! you can just see the front cylinders here, they should be more promanent but with the screen moving in and out here its just not possible so this is as far forward as they can come. made another armour plate for the back of the neck Onto a job I was putting off, having to cut the grooves in the head for detail, this was done with a hacksaw blade and a razor blade (no really) looks a bit more real now Link to comment Share on other sites More sharing options...
Mark M Posted November 22, 2010 Share Posted November 22, 2010 ive just found this and well what can i say its cracking!!! Link to comment Share on other sites More sharing options...
Candyman Posted November 24, 2010 Author Share Posted November 24, 2010 head back together and mounted up remaking the screw drive for the head, old plate on the left new in the middle. I wanted to mount the unit sideways in the middle of the chest but for this the cable had to do a 90 degree turn out of the screw drive and then another 90 in the head, this was too much the wire would kink. So I have to have it pointing straight up into the head, not a big deal, it'll stop the inside of it looking empty, its tucked away out of view from the front. somthing else I missed before, slotting this part of the shoulder back plate. Link to comment Share on other sites More sharing options...
Candyman Posted November 26, 2010 Author Share Posted November 26, 2010 smoothed the chest edges off and re primed Now stripping the torso apart, the top plate is the old one the shoulders were mounted on, now I know exactly where they need to mount I made the plate at the bottom with the holes in the right place. Also re tapping holes and generally tidying up the insides. Link to comment Share on other sites More sharing options...
Carts Posted November 27, 2010 Share Posted November 27, 2010 I would be agog,but my gog has run off and is cowering in the corner,so I will just have to settle for plain old astonishment Link to comment Share on other sites More sharing options...
Candyman Posted November 27, 2010 Author Share Posted November 27, 2010 thank you 2nd leg time. im briefly documenting this as its pretty much the same as the other one got my micro switches through and fitted them onto the screw drive, so it'll cut the power when it gets to the end of its travel. fitted up, made a few little brackets and hangers, one you can see above the motor lump of delrin thats about 8 hours work, getting my head down here. Link to comment Share on other sites More sharing options...
Candyman Posted December 7, 2010 Author Share Posted December 7, 2010 Ok quick update, ive been working away on the leg knee pad ankle bit another bit, just a straight copy glad thats done Link to comment Share on other sites More sharing options...
billybookcase Posted December 10, 2010 Share Posted December 10, 2010 Link to comment Share on other sites More sharing options...
MakingModelsAgain Posted December 11, 2010 Share Posted December 11, 2010 This build is mind-bogglingly exquisite! Link to comment Share on other sites More sharing options...
