How to use Promodellers Weathering Wash
  • This topic is locked This topic is locked
No replies to this topic
#1 Phil @ Flory Models
Phil @ Flory Models
    Very Obsessed Member
  • Members
  • 1,882 posts
Posted 11 April 2007 - 08:51 AM
Step by Step guide
OK panel lines! I think most modelers make to much out of a simple process. It seems to cause no end of problems to the beginner. I think this is because people over complicate the process, this is how I have been doing it for the last ten years and never had a problem. This is a safe way to do panel lines and if you dont like it, it washes off.
It is safe, as it is clay based and has no solvents, alcohol or other chemicals.
Firstly make sure the model is completely dry, this is a must or the mix will weld itself on. It doesn't have to be a gloss finish in fact this works just as well on a mat finish.
Shake well, very well as it will separate. It comes ready to use but you can thin even more if required with warm tap water but remember to mix well.
Posted Image
Then using a soft brush slap it all over the model.
Posted Image
Posted Image
Posted Image
It will dry in about half to one hour, if you get areas that don't dry, a blast from the airbrush speeds things up.
Posted Image
Posted Image
When dry it can be removed, don't worry about leaving this stuff on as I have left it on for three weeks to see if would come off OK which it did.
Posted Image
Posted Image
Next it's time to remove the clay. Using some good quality kitchen roll, which I cut into small squares, I lick to moisten, just a little a wipe off, that simple.
Posted Image
If needed, use circular motions to remove the clay.
Posted Image
Use a cotton bud, again moistened, to get into the corners and tricky areas, then go over the model again to make sure you got it all off. If you do take it out of the panel line just re apply again.
Posted Image
Then the same thing for the rest of the model.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Remember to get it off any areas were you don't want it as when the model is given the required finished coat (Matt, satin or gloss) the clay will darken making it stand out a lot more.
Posted Image
Next its a mat coat to seal the clay and the model for further weathering.
Any problems or questions, Please ask.
Happy Modeling, Phil.
Edited by Phil_flory, 30 September 2007 - 09:05 AM.
