  • Announcements
    • Mike
      Ongoing DDoS Attack causing Forum Slowness   26/04/17
      In case you have missed the announcement, the reason that the forum has been slow at times since the minor version update the other day is due to a Denial of Service attack, brute force attack on our email, and judging by the lag with our FTP response, that too.  If you're feeling like you're experiencing a glitch in the Matrix, you're not wrong.  This is the same MO as the attack in September 2016 that occurred when we transitioned to the new version 4 of the software.  We're currently working with US and UK cyber-crime departments, who specialise in this sort of thing, and we're hopeful that we'll be able to track them down this time by using the accumulated evidence already held.    We are pretty certain that it's a continuation of the same attack last year, only at a reduced intensity to deter people from using the site "because it's terribly slow", rather than taking it down completely, and we're also sure of the motivations of those responsible.  Spite.   Please bear with us in the interim, and wish us luck in dealing with these.... "people".
ConspX
1/72 MiG-25PU "Foxbat-C"
20 posts in this topic
Hello
Does anyone make the foxbat-c version of the mig-25 in 1/72 ?
Yes, Zvezda made a kit. Doesn't seem to be listed in zvezda's catalogue anymore, but modelimex website has it still available.
Condor do the MiG-25 in 1/72. They do the 2 seater and at least 2 different single seats. Not sure which marks though.
The Condor kit is although a bit tricky in places is a nice kit to build. A lot simplier than the similar ICM kit, although they only do the single seaters. My completed kit is Britmodeller somewhere in the ready for inspection section.
Yes Jabba, I saw your built 2-3 months ago, and I was amazed how you managed to hide the panel lines. Did you mask them all, or was it just the kit. Personally I like defined recessed panel lines but yours was done like it was flat, which is amazing in my opinion and pretty hard to do also
So.... how do the Condor, Zvezda & ICM kits stack up against the Hasegawa original issue? Just asking as I have the latter (half-built) in my "pending" tray....
Doug
Hi ConspX, your best bet would be Hannants for prices in the European region. For some reason Aviapress and Hobbyterra are charging outlandishly high prices for the kit. Hannants is out of stock at the moment but should be available not too long for now.
Here's the link:
http://www.hannants.co.uk/product/CDR72014
I'm building this kit at the moment. Fit is average, but you will need to watch out for the fit of the rear fuselage. The tailfins are molded as part of the aft fuselage panels and I managed to wind up with a large gap between the base of the tailfins and top panel. I fixed that with putty but something I suspect will not happen with proper planning. Good luck!
Far off ahead in terms of accuracy. Hasegawa is some other plane, not MiG-25
Doug: Hasegawa's kit is an older one from the 70's based from the first pics took when Beleko arrived to Japan. So the accuracy is not that good (wrong exhausts, wrong fin stabilizers, and other more).
I built it years ago and the parts doesn't come together easily; you must work "a bit" on the fuselage with putty and sanding and the cockpit as you can imagen, very poor.
Some pics of my Hasegawa 1/72 "Foxbat A" took several years ago barely finished:
I tried to represents the Belenko's Mig-25P ;)
Hope this could help you :)
BL.
Thanks for the replies.... BlackLight, yours looks pretty good to me!
So.... which IS the best Foxbat in 1/72nd?
Can open, worms everywhere........
ICM is a good choice for a "P"...muche better than Hasegawa's ;)
ICM=Kondor? IMHO yes...
Cheers :police:
Not quite. Although they look the same the build up of the aft fuselage is slightly different. The ICM model has a lot more parts having 11 against Kondors 4. Having built both kits I found I found the ICM kit to be the bit more of a pain in the backside than the Kondor one.
ICM
Kondor, mainly due to the fact that it has less parts to make up the aft fuselage.
Am I wrong or is the zvezda kit the same as the Kondor one ?
You are not - Zvezda repacks Kondor
