SHAR67 Posted September 9, 2007 Share Posted September 9, 2007 Hi all I have the Italeri 1/48 Tornado IDS and the Airfix Tornado F3,the nose cone from the Airfix F3 is a little large for the IDS fuselage as a nose match.So when i measured the two up the Italeri nose fits inside the Airfix one so i was thinking of using the Airfix nose as a mould,but what resin and where would i get it from so as i could complete the task. Cheers Clive. Link to comment Share on other sites More sharing options...
Mike Posted September 9, 2007 Share Posted September 9, 2007 I use Alec Tiranti, but I'm told they're not the cheapest. A set of bits & bobs to do the job will probably cost you around £50-60, including syringes, measuring jugs, spatulas, resin, RTV, and you'll need some lego-bricks to create the mould box too. I've posted up a thread in the tools & tips forum that goes through some of the basics for us DIYers, so have a peruse of that, and if you've got any questions, post them there Final word for the moment, is it's expensive & messy, but a VERY useful facility to havem especially if you're into scratch-building, as you can stage your work, creating a new resin master each time you make a big change, so if you stuff it up, all is not lost Link to comment Share on other sites More sharing options...
SHAR67 Posted September 9, 2007 Author Share Posted September 9, 2007 Cheers Mike. Link to comment Share on other sites More sharing options...
keefr22 Posted September 9, 2007 Share Posted September 9, 2007 I've bought casting stuff from Sylmasta at IPMS Scalemodelworld & always found them helpful, & their products good. They sell on-line; http://www.sylmasta.com/ but because the stuff is so heavy, postage is quite expensive - hence I'm waiting till November to restock my supplies! I was also given a link from someone on another forum to a model railway (I think!) supplier, who stocks the American alumulite stuff (which I believe is very well respected over that side of the Pond); http://www.nigellawton009.com/PayPalCasting.html You could also try searching on e-bay for resin casting supplies - there's a couple of suppliers on there, but again postage is expensive. HTH Keith Link to comment Share on other sites More sharing options...
