Mike Posted August 16, 2007 Share Posted August 16, 2007 Just "won" one off eBay with a Neomega cockpit kit, as it's one of my favorite older(ish) Russian airplane jets What have I let myself in for? I've seen a few builds that just criticise the cockpit, and warn the builder to test fit everything before glueing... anything else I should worry about? Cockpit green... Don't suppose there's an equivalent color in the Xtracrylics range is there? or one I could mix up (I've got the lot - even the tank range, I think). If not, which acrylic range does have one that I'll be able to get from Bill, Graham or Steve? Link to comment Share on other sites More sharing options...
dswoofie Posted August 16, 2007 Share Posted August 16, 2007 Mike, I've never found a Soviet Interior Green in Acrylic. The closest I've got before is a Vallejo Emerald Green with some mixing involved. If you find one, let me know! Karl. Link to comment Share on other sites More sharing options...
Gary C Posted August 16, 2007 Share Posted August 16, 2007 I've got one in the stash to do soon, looks decent enough in the box and seemed to dry fit OK, granted it's no Tamiya kit but with a Neomega tub I'd say you've cleared the biggest hurdle. Need to pick one up myself along with some decals, probably these Fitters over Afghanistan and I shall be making a start. As for paint the only out of a can interior green I know of is Hannants enamel X629 but mixing one shouldn't be difficult, Gary Link to comment Share on other sites More sharing options...
Mike Posted August 16, 2007 Author Share Posted August 16, 2007 I've got one in the stash to do soon, looks decent enough in the box and seemed to dry fit OK, granted it's no Tamiya kit but with a Neomega tub I'd say you've cleared the biggest hurdle. Need to pick one up myself along with some decals, probably these Fitters over Afghanistan and I shall be making a start. As for paint the only out of a can interior green I know of is Hannants enamel X629 but mixing one shouldn't be difficult, Gary Thanks Gary... I seem to remember seeing the Linden Hill stuff for sale over here recently, but can't remember where.... any ideas? Link to comment Share on other sites More sharing options...
Sebastien Posted August 16, 2007 Share Posted August 16, 2007 Just "won" one off eBay with a Neomega cockpit kit, as it's one of my favorite older(ish) Russian airplane jets What have I let myself in for? I've seen a few builds that just criticise the cockpit, and warn the builder to test fit everything before glueing... anything else I should worry about?Cockpit green... Don't suppose there's an equivalent color in the Xtracrylics range is there? or one I could mix up (I've got the lot - even the tank range, I think). If not, which acrylic range does have one that I'll be able to get from Bill, Graham or Steve? The interior of the Fitter K is not Russian cockpit green. You'd be better off using any RLM65 you got in stock. Cheers, S. Link to comment Share on other sites More sharing options...
Gary C Posted August 16, 2007 Share Posted August 16, 2007 Thanks Gary... I seem to remember seeing the Linden Hill stuff for sale over here recently, but can't remember where.... any ideas? Hannant's and Neomega both stock them although neither has the Fitter sheet any longer, I shall probably order from Linden Hill direct. Failing that Hannants also have the Hi Decal sheets Su-17 and CE do a sheet too Su-22 Good call on the cockpit Sebastien, looks blue grey to me, Prime portal Gary Link to comment Share on other sites More sharing options...
Honeybee Posted August 16, 2007 Share Posted August 16, 2007 Hi Had no problems building mine. The only area was the lack of positive fit for the undercarriage but mines been built for about five or six years and it's still in one piece. Absolutely no issues with the resin cockpit either Regards Paul Link to comment Share on other sites More sharing options...
Jens Posted August 17, 2007 Share Posted August 17, 2007 Mike, If you do the usual dry-fitting twice before glueing once I think you will be on the safe side. As mentioned the kit cockpit isn't great, but neither was my Neomega cockpit (lots of bubbles etc.). The afterburner could benefit from some details too. Also, you need to watch the wings if you want them fully swept. The leading edge of the outer part will not be nowhere in line with the inner part - this is not correct. Also, the outer parts will need thinning if you want to fit them inside the inner parts for a fully swept wing. Apart from that it's a pretty typical Eastern kit. A bit rough but it makes for an impressive model I think. Regards, Link to comment Share on other sites More sharing options...
Sebastien Posted August 17, 2007 Share Posted August 17, 2007 You can see my build of the Fitter K there. Cheers, S. Link to comment Share on other sites More sharing options...
Mike Posted August 17, 2007 Author Share Posted August 17, 2007 You can see my build of the Fitter K there.Cheers, S. Very nice Squire.... Link to comment Share on other sites More sharing options...
upnorth Posted August 19, 2007 Share Posted August 19, 2007 Good call on the cockpit Sebastien, looks blue grey to me, Prime portalGary Speaking as the one who took those cockpit pictures, I can tell you indeed it was not the typical Soviet turquoise blue. Additionally, that was also the most nicely maintained Fitter I've yet seen in the Czech Republic. I believe its actually property of the Czech military rather than a museum and likely was never allowed to deteriorate. It probably looks just like it did on its retirement day back in the late 90s. Link to comment Share on other sites More sharing options...
Mike Posted August 21, 2007 Author Share Posted August 21, 2007 Well, it arrived today, and I'm quite impressed with the quality, except the cockpit, which is woeful! I'm glad it came with the Neomega replacement, which looks very nicely detailed especially in comparison with the undetailed "planks" of the kit cockpit's IPs. The price tag on the neomega bag is £11.50, so I paid next to nothing for the kit. I'd call that a result, and the beginning of my Soviet/Russian stash Schturmovik is next on the list, when I find one that's going for a decent price Speaking as the one who took those cockpit pictures... Nice walkaround Link to comment Share on other sites More sharing options...
upnorth Posted August 21, 2007 Share Posted August 21, 2007 Thanks for the compliment on my walkaround. Here's an even more extensive one from the same site with more cockpit shots. I suspect the aircraft in that walkaround might have still been in active service at the time. http://www.primeportal.net/hangar/luc_colin3/su-22m4_fitter/ Link to comment Share on other sites More sharing options...
