Richard M Posted September 20, 2009 Share Posted September 20, 2009 I'm building the re-issue of the Airfix 1/144 Saturn V as part of a GB on the Airfix Tribute Forum, hopefully to display on the Airfix Modelling SIG table at SMW this year. Box and sprues - Saturn V. (Clickable thumbs). The new revised sprue. The crew... I've made a start, most of the major assembley is done on the main body - it's just glueing big tubes together! I've found the best thing to do is to remove most of the locating pins, as these are very large (click fit?). As I thought, most of the work will be in the finesse of clearing up seam lines on the parts with stringer detail. The main engine pods are really bad, nasty seams surrounded by stringer detail. From a link provided in the GB references by Steven Pietrobon, I've seen pictures where they are covered in protective insulating material. I'm going to grab that with both hands and run with it - tamiya tape overcoated with future should do the trick. It certainly looks impressive when assembled. The way the sections slot together should make storage and transport a lot easier. Best Rich Link to comment Share on other sites More sharing options...
PHREAK Posted September 20, 2009 Share Posted September 20, 2009 (edited) I'll be watching with great interest. When I get one and build it, I don't think I'll be putting the astronauts in the capsule! Save you seen the umbilical and electrical add-on bits available on the bay of evil? A search using 'Airfix Saturn' will pop them up. Edited September 20, 2009 by PHREAK Link to comment Share on other sites More sharing options...
Richard M Posted September 24, 2009 Author Share Posted September 24, 2009 Picture progress, just prior to adding milliput to the seams. It really does build up into a very impressive model. It does break down into sections easily, and the locking mechanism is very solid when assembled. Seams are a bit dodgy in places, I've applied tape to try to prevent losing surrounding detail in the filling process. The rocket base plate has a sink mark and will require bit of filling around the edge. The rockets themselvesare probably the worse bit, nasty joins and fine stringer detail. One of mine was a bit short shot. I'm basically going to sand them down a bit and cover them in tape to act as the insulation applied to the real ones. Should cover everything nicely. I've glued one half of the new lunar module pod in place after removing the locating pins, this will allow me to glue the service module in place, but still allow the lunar module to be seen. A bit of clean up on the lunar module is needed but the new parts look very nice. The surface texture is a little grainy though. . Filling and sanding next. Best Rich 1 Link to comment Share on other sites More sharing options...
roma847 Posted November 20, 2012 Share Posted November 20, 2012 Hi Richard, nice start so far with the build, have you any progress pics? I've the same kit in my storage and want to build it after I've finished my Launch Pad STS-6 project. Link to comment Share on other sites More sharing options...
GordonD Posted November 20, 2012 Share Posted November 20, 2012 When you come to painting, note that there is an error in the instruction sheet - the black stripes on the first stage only extend up as far as the bottom of the intertank stringers, not the top as shown. This is because Airfix sent Mat Irvine* a poor-quality photocopy of the draft instruction sheet for him to check and he didn't spot the mistake until it was too late. *Mat Irvine is the man to go to when you want to know about space kits. He's written two books about them and it was he who persuaded Airfix to release an accurate version of the Saturn V with a Block II spacecraft. Link to comment Share on other sites More sharing options...
Richard M Posted November 20, 2012 Author Share Posted November 20, 2012 Holy thread revivial Batman! I did get this finished and it went on the Airfix Modelling SIG display at SMW 2009 and then onto Airfix HQ in Margate for display there. I was trying to get several models done including the then new HMS illustrious and didn't really get the chance for many more build shots, the only completed picture I have is from the display! Link to comment Share on other sites More sharing options...
roma847 Posted November 20, 2012 Share Posted November 20, 2012 Hi Richard, thanks for the nice photo, your Saturn V looks great between the rest of the models. Have you started any new real space projects in the meantime? Link to comment Share on other sites More sharing options...
